Question about HP Photosmart D7460 Printer
Missing color magenta and light magenta after test
Hp d 7460
SOURCE: theres missing color on my pixma ip3000
I had a magenta problem and had to replace the print head to solve it.
Posted on Oct 06, 2007
  • 2072 Answers
SOURCE: I have a Xerox Phaser
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Posted on Feb 28, 2009
  • 13 Answers
SOURCE: I have a HP Photosmart C5180 printer.
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Posted on Apr 19, 2009
cyber07x
  • 18 Answers
SOURCE: Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Posted on Sep 01, 2009
pineworks
  • 4041 Answers
SOURCE: My HP C6180 is not printing its magenta color.
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 21, 2010
Testimonial: "Thanks for you good advice. It all made sense to me and it should have worked. I found 9 others reporting the exact same problem. Craig patentQ.com"
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
"Check Color Cartridge" displays even after replacement of cartridge -though I don't think original cartridge was empty- and stops printer from printing. The new cartridge is installed properly, and...
  1. First, check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges.
  2. Second, make sure your paper is not causing the problem. Paper that does not accept ink well can cause your images to smear or bleed. Plain paper is not the best choice for high-density graphics. Click here to see how to pick the best paper for your project .
  3. If the paper is not the problem and you are using genuine HP cartridges, print a clean test to see if the printer and cartridges are functioning properly. Load the printer with clean, plain, white paper and print a clean test page. To see how to print a clean test page, see your printer's User's Guide , or see HP Deskjet Printers - How To Print Internal Tests , or HP All-in-One Product Family - Printing Self-Test Reports .
  4. Evaluate the clean test page. Different printers produce different pages, but you should recognize elements from the examples below on your test page. In general, cartridge and printer problems are indicated by streaks, missing colors, or wrong colors.
    • Examples from a good printer and cartridges (your test page may not look exactly like this): Figure 1: Solid colors that match color dots on cartridge labelc00059224.gif Figure 2: Pattern unbroken, or broken in only a few placesc00059225.gif
      c00059227.gif If your test page looks more like the good examples above than the bad examples shown in the next two sections below, the printer and cartridges are probably not causing the problem. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - streaked or broken bars or lines Figure 3: Fading, missing, or streaked bar - low-ink or empty cartridge, clogged nozzles, or electrical problemsc00059228.gif
      Figure 4: Color completely missing (magenta bar missing below)c00290898.gif Figure 5: Lines broken randomly - clogged nozzlesc00059231.gif
      Figure 6: Lines broken in pattern - dirty contacts or other electrical problemsc00059232.gif
      Figure 7: Color completely missing (magenta pattern missing below)c00290899.gif If your test page looks like these examples, you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - colors do not match the color dots on the cartridge label (Note: do not compare the test page colors to the colors of the examples on this web page. Your monitor may not display the colors properly). c00059234.gif c00059235.gif If your test page looks like these examples, you probably have a cartridge in which the inks have mixed. Click here to continue troubleshooting .
Oct 26, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Not getting pink/red from printer. New Magenta
When the printer is ready with the green light on, you press and hold the resume button until the green light flashes twice and release the resume button. The printer will print a nozzle check page. If colors are missing you may need a new printhead.
Jan 28, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
Have HP3600n over just 1year. Having trouble after startup gets stuck in calibration and won't go any further... any thoughts? Have tried cold reboot w/all unplugged several times...Mike
Start by removing the formatter. Have paper in tray 2.
Print an engine test. You should see repeating lines of cyan, magenta, black and yellow. If any of the colors are missing - run the Disable Cartridge Check. Run the engine test again with the previously missing color in another slot. If that color fails again, replace it. If the issue stays with the slot replace the laser scanner. If the engine test is good now, install a new formatter, power up and see if the calibration hang is gone.
Jan 26, 2010 | HP LaserJet 3600n Printer
Colour problem
If the printer gives magenta instead of red you have a problem with one of the other colors. Magenta needs other colors to print red. Print a cofiguration print and check witch color is bad or missing. Replace the cartrridge of the missing/bad color
Dec 24, 2009 | HP LaserJet 3000n Printer
I have tried to run the light strips program, have one color, magenta which is not filling in.
Use the Jet Substitution mode to compensate for missing jets.
If you have three jets missing in a row the jet substituion won't help
and a printhead replacement would be necessary.
One last thing is it the "SAME" jets missing after each LST (Light stipes
Test) or are they changing?
Nov 01, 2009 | Xerox Phaser 8400 Laser Printer
Hello, I have HP lj 2600n. It does not
the problem is due to scanner mirror dust.you have to clean the scanner mirror.
Oct 26, 2009 | HP Color LaserJet 2600n Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printing problems
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
HP Photosmart D7460 Printer Logo
99 people viewed this question
Seeker5211
Seeker5211
