Question about John Deere Garden
Lost spark on my john deere 68. can't figure out why, tried new plug. wondering how to bypass everything to make sure coil is good
  • 10865 Answers
SOURCE: john deere 116 lawn tractor
Call any John Deere dealer directly and they will tell you.
Posted on Apr 06, 2009
wadembly
  • 462 Answers
SOURCE: No spark
did you make sure the gap was set right on coil & flywheel it should be .020 between magnet on flywheel & the coil & the same thing with the points in the open possition between points & condensor
Posted on Jun 08, 2009
  • 218 Answers
SOURCE: blade position for 155c john deere
Hi..my name is Keith...to answer your question..there is no certain position to put the blades and there is enough clearance that they wont hit...but there is a proper torque on the nut when reinstalling the blade..and its usually like 100 foot pounds..i hope this has helped
Posted on Jun 30, 2009
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 425 AWS no start, no nothing???
If engine cranks over and have no spark try a time delay module located under thermostat housing.
Posted on Nov 13, 2009
Can someone guide me through troubleshooting this ie which safety switches to check etc.
try a new spark plug. they breakdown over time. if still no spark unplug the wire under the coil. if it does not have spark now replace the coil. if it does have spark you have a bad switch somewhere.
Oct 30, 2016 | John Deere Garden
John deere tractor has no spark eng is fb460. i put a new spark plug and a new coil still no spark
Make sure you set the gap properly on the coil should be a filler gauge 10. Make sure the flywheel is clean at the firing point. And make sure there are no safety switches that have gone bad. Safety switch that go bad will cause a break in the circuit and will prevent the coil from allowing spark.
Aug 04, 2016 | John Deere Garden
I have a stx 38 john deere and put on a new coil and have no spark at the plug
1. make sure the spark plug lead is connected to the plug
2. check the condition of the plug and make sure its properly gapped
3. test for spark plug making sure engine ignition switch, key switch, or kill switch is in the run position
4. crank and observe
if that doesnt work check where the coil attatches to the engine for rust buildup or moisture. if that is the case clean surface area and let dry in warm dry area for 4-6 hours and try again
Aug 19, 2012 | John Deere Garden
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
Jul 28, 2012 | John Deere Step 2510 2520 3010 3020 4000...
John deere 116 briggs & straton wont get spark. new coil, still nothing. will try to bypass seat safety switch.
there is a black wire a that goes to the ignition on the side of the engine next to the manifold unplug that and see if you get spark with that off if you do follow that wire back to the safety switches
Apr 06, 2012 | John Deere Garden
Lack of Spark
If all of your tests are correct, the thing remaining is the ignition coil. A bit of a pain to get at and expensive too. Parts diagram here. Before you buy a new coil, see if there might be just a broken spark wire or loose connection at the spark plug contact end.
Jul 16, 2010 | John Deere Garden
I don't have spark on my john deere x324 tractor. It was fine the last time I used it. I thought the safety switch for the seat. I made a jumper and no spark. What other switches would cut out the spark?...
X 300 series had 2 known problems.One is the delay module under dash has been an issue scince model came out,it's the first thing I replace when I have one that comes in with no spark.The second issue is the coil grounding/kill wires have a diode in them and when one diode goes bad the engine will only have spark to the strongest coil.If you lost spark to both coils and machine still cranks I would replace the delay module under center of dash.
Jan 08, 2010 | John Deere Tractor 1020, 1520, 1530,...
JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
May 18, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
