Question about Dometic Rooftop RV Air Conditioner
The fan will not turn on.i have 110v to circit board on the unit, the unit is one year old. it is a colmon mack 8000
  • 30 Answers
Check the name plate of fan motor if it is 220V or 110V,if 110V but still not running replace the fan motor.
Posted on Jun 05, 2010
Wiring schematic for an old honeywell R8325C1020-8514 fan center relay..
Without a picture Mike, I'm not sure this answer is absolutely correct but.... most of the old fan centers had a multitap transformer so different colored wires were provided to connect to 110v, 208v or 230v. If thats what it is, white was common to the black for 110v. White was common to orange for 208v and white was common to red for 230v.
If you have red and black hanging loose, possibly the center is connected to orange and white with 208v power supply. Of course many times, the orange and red were interchanged with 208v OR 230v.
Another point is that virtually all residential gas furnaces operate on 110v and 208/230v operated electric furnace.
As stated above, without a picture this is just a reasonably educated guess....Conventional furnaces less than 15 years old typically no longer have fan centers.
Nov 29, 2015 | Honeywell Heating & Cooling
Vision pro 8000
First check and see if a code of flashing lights on the fan board relay is flashing any number of flashes. If it is count the flashes and refer to owners manual for code of number of flashes for the problem with furnaces air handling problems. If not flashing any codes on the fan relay board I would think the thermostat is the culprit. I have had alot of these newer t-stats go bad as compared to the old mercury t-stats of the days of gone by.I have seen old Honeywell round T-87 stats as old as 60-70 years old still working when removed.
Oct 01, 2017 | Heating & Cooling
MGE Pulsar EX 10 online UPS doesn't work
With the ones that I have seen the ups units have a relay that routes the 110v thru the unit when it has 110v power applied. If you are saying it has no output on batteries only then you may be right about the inverter. SAFELY I would just verify on the board that the DC input from the batteries is correct to test your install. It seems there may be a RS232 DB-9 connection on them with available software for communication with them, if it does I would try it.
http://www-05.ibm.com/hr/services/nss/pdf/power/ex710uk.pdf
Sep 02, 2012 | MGE Pulsar EX 1500VA (85150) UPS System
My one year old 8000 BTU GE window unit will not turn on. The electricity was going off and on so I unplugged the air conditioning unit off. Now it will not come back on. The green light on the plug is on...
Is the display panel lit up? If not look for a fuse mounted on the board.Take the fuse to radio shack and get another. Unplug the unit before attempting to service it.
Jul 09, 2011 | Heating & Cooling
In home fan puts out air thru vents however the model38ckc060370's fan stopped working and no ac flowing through unit to cool house. Is there a simplle trouble shoot for my problem?? The unit is 7 years...
Make sure circuit breaker for the outside unit is on or the fuses are good whichever you have. If they are on you can check the capacitor in the outside unit. The capacitor will be a round or oval can and can be metal or plastic. You can also look at the contactor to see what shape it's in.
May 03, 2010 | Carrier 38CKC060 Air Conditioner
I have a Maytag microwave model # MMV4205AAB - manuf. 7/2004. The current problem with it is that when it is plugged in, and not running - it will reset itself to the date/time setup, as if someone flipped...
Chances are you have a failing electrolytic capacitor and/or bad connections on the main control circuit board.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to visit here or contact me directly and please include your full model number for more information.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 16, 2010 | Maytag MMV4205 Microwave Oven
Fan roller and grey fins clogged with dust and mould
You can clean Blower wheel one of two ways. !st would be to remove the wheel and clean with the garden hose or if that is not a option for you then you can buy a can of compressed air and clean it that way but you will get a blast of dust and dirt when unit turns on. Make sure unit and/or power is of when doing this. Keeping your filter mainteneced more often will reduce the build up more.
Feb 15, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
WeatherMaker 8000 noisy fan
You can take the parts of and match them at a graingere supply if theres one cloce to ehre you live. I think that it has a 1x1/16th" diameter on the blower bearing and its for a spider type. Try not to tightn the belt so much and the bearings might last longer
Dec 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Mitsubishi MSH12TH heat pump air handler 110v
Wireing this type AC with the wrong voltage, will damage more than the circuit boards. I think the installer wil need to be responsible for the damage he created. The factory will also try to get out of the replacement because of the installers lack of know how.
Oct 20, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Dometic Rooftop RV Air Conditioner Logo
94 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
