Question about GE Cooktops
GE JGP979BEFBB has one ignitor not working. How
GE JGP979BEFBB has one ignitor not working. How to repair?
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 18, 2010
Oven willnot turn on....broiler works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 07, 2010 | GE Profile JGP636 Gas Cooktop
Ignitor does not click
there is no "ignitor" as you would find in an oven or dryer. There is a sparkmodule that many times goes bad after 5 to 8 years. It is a plastic box about 4 to 6 " x 2" wide and wil have 3 to 5 wires or 3 to 5 terminal connector points on it. remember to unplug the range top fromwall electric. these units are not difficult to replace; they are not repairable, you have to buy a new one.
Apr 28, 2010 | GE Profile JGP636 Gas Cooktop
The oven will not heat, but the broiler does work.
Just because it glows that does not mean it is not bad...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Mar 07, 2010 | GE Cooktops
Grill will not ignite-glow pug is bright red
heatman101
Feb 14, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Ge model jgp326 ignitor is giving
you either have a bad licon switch on one of the burner valves or you got water or cleaner in one of the switches.. Unplug it and let it dry for a few days, if it does not work you need a new switch.
Nov 11, 2009 | GE Profile JGP636 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Oct 17, 2009 | GE 30 in. JGP328 Gas Cooktop
The oven for my G.E. gas stove takes forever to reach 350 deg.
Here are the common causes.
1. First check that the bake and broil burners/ignitors are working. If not, you may have a bad ignitor.
2. If #1 is ok, then the burners must be short cycling, that is, they are ON for too short a time then OFF again.
#2 can be caused by either a bad temperature sensor or a failure in the control board.
The temperature sensor needs to be checked by disconnecting and measuring it's resistance.
If the sensor is good, then the problem is in the control board. We repair this particular problem with the controller quite often. If you want, I can have a look at it for you, if you can have it removed and sent to us.
Regards,
Bruce
www.fixyourboard.com
Oct 12, 2009 | GE Cooktops
Ge jgp337 ignitors continue to click after gas ignites
You have a bad ignitor which will have to be replaced. Unplug one ignitor at a time until you find the faulty one.
Jul 24, 2009 | GE 30 in. JGP337 Gas Cooktop
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Cooktops Logo
195 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
