Question about HTC Touch P3452 Smartphone
HI, I am using HTC P34ooi from last 1 1/2 yrs. Its battery get nil/dry after full charged. So should I change the battery or there is problem with phone?
I had the same problem, i changed the battery then it was ok
Posted on Jun 05, 2010
After full charge, battery lasts about 1 day, with only "device usage" on the battery.
Hi, when a phone battery is fully charged and it does not stay long to power the phone,You might need to replace the phone battery.
Phone batteries has cells inside them that determines how long the battery life will last..When these cell dies, it will be unabletopower upthe phonefortoo long and the phone will go off..
To solve the problem of charging a battery and notlasting too long,you will need to replace the phone battery with a new one.
You can get a replacement battery battery from nearest outlet store around your area...
Warning before you buy a new battery, make sure that the phone does not get hot when you insert the battery inside the phone...Because that is not a battery fault. It's a phone board problem.
Take care and thanks for using fixya...
May 23, 2011 | HTC Snap S522 Cell Phone
Tip
I have an HTC s640 and it just stopped charging the last time the battery ran...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Apr 04, 2010 | T-Mobile MDA
I have a Canon PowerShot A530 camera which is around 4 years old. till recently it was working great but from last 3 months, it is giving false indication of low batteries and shuts down. Even after full...
if you are using this camera for 4 yrs with the same lithium battery then you might need to try a new battery
any lithium battery cell's capacity diminishes after long use. it reduces the cell's ability to deliver current. the older batteries do not charge as much as new one.
when you charge your battery it irreversibly loses approximately 20% capacity per year.
hope this help
Sep 08, 2010 | Cameras
Battery getting frequent discharged, even after changing with new one
Hi
There are so many fake batteries outside now which cannot last long.
Please, make sure you get the original battery from your dealer and and charge it for six hours before using it.
Regards.
Aug 28, 2010 | HTC P3300 Smartphone
FULL CHARGE DOES NOT LAST, BATTERY RUNS OUT AFTER 6 HOURS
Check out my tip for extending the battery life:
http://www.fixya.com/support/r3607306-battery_tips_sprint_htc_hero
Also, be sure you update your phone. There have been some software updates that was suppose to address a battery issue and the text messaging app.
Good luck.
Jan 17, 2010 | HTC Hero Smartphone
My htc touch dimond consumes the battery all of a sudden. i changed the battery but the problem is there. the battery shws full charge and after 3 4 hours the mobile goes off , and the battery has to be...
Make sure that the WiFi and Bluetooth is disabled unless you need them. Try changing the charger and use the wall charger instead of the USB one. In case after changing the charger, the battery still dries out, then it might be some fault (voltage leak in the mainboard) or it is time to change the battery.
Nov 15, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Fully charged mobile battery goes dry within few hours(3 hours)
If it is 8 Mths. old, it should be under warranty.Have the providwer fix the issue.
you can try Kaiser Tweaks:
http://www.jongma.org/KaiserTweak/
***Copied from this link:
http://www.htcwiki.com/thread/935379/Battery+Life
which will change the settings in the registry automatically:
These WILL work, and WILL improve your performance!
1. HKLM\Comm\AsyncMac1\Parms\DisablePowerManagement
Change Dword value from 1 (default) to 0
2. HKLMComm\Irsir1\Parms\DisablePowerManagement
3. HKLM\Comm\PPTP1\Parms\DisablePowerManagement
4. HKLM\Comm\L2TP1\Parms\DisablePowerManagement
To make these registry changes, I used CeRegEditor. Works from the computer and connects to the phone/PPC while synched. I have noticed an improvement in battery life. Should work with WM5 and WM6.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 15, 2009 | HTC Touch P3452 Smartphone
My K800i battery dies very quick
Dear Friend,
                 U are saying that u have bought this mobile 2 yrs back so check wither ur battery has been expired and change it.Otherwise switch off ur mobile and put it in charge and check it out the normal standby for any mobile is 2 to 3 hrs.Kindly check it and revert back
Regards,
Aysaam
May 06, 2009 | Sony Ericsson K800i Cellular Phone
HTC S710 - Battery issue
it could be either battery or charger, If the charger isn't supplying enough power it will fool the phone..
some 3rd party batteries and cheapo chargers can cause all sorts of problems like this.
best way to test is charge your phone by usb, it takes longer but will give you some idea of weather its the battery or charger.
Make sure that the box at the bottom of the power management window (dont charge by usb) is set to off. Also for best results remove any other usb devices from the computer this will leave more power for the phone.
Best of luck
Jun 05, 2008 | HTC S710 Smartphone
HTC Touch P3452 Smartphone Logo
91 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
