Question about Saeco Odea Giro Plus Coffee Maker
The machine odea giro plus whistle while brewing
  • Saeco Master
  • 1,711 Answers
The scale in the pipe system have norrow at some points so while brewing and with hight pressure you here the whistle.
First I sugest to descale the machine and you may try to do it for three days repeatevly.
However if the noise will not decrease then the machine need full desasemble and remove the scale manualy. But I advice only to do the above if you have problem with the coffee quality or if the noise is so strong and can not bair it any more.
Posted on Jun 05, 2010
Testimonial: "thanks"
Grinder problem
try to check the brew group
Jun 18, 2012 | Saeco Odea Giro Plus Coffee Maker
How do I descale my Saeco Odea Giro Plus Coffee Maker
do you have a video on how to operate this machine
Nov 27, 2011 | Saeco Odea Giro Plus Coffee Maker
We have an Odea Giro in the office. When we got it I remember the coffee tasted amazing. After few months the taste started to decline and after some time we stopped to use it altogether. I wanted to...
you are supposed to go through the "before first use" instructions....which include filling the resevoir with water and brewing only water until its all gone. then start using the machine normally...remembering that the machine takes a few brew cycles to adjust properly to the coffee being used (this assuming this is the giro plus model which has the feature-"aroma something or other...)
also, descaling would help and removing the brew group and rinsing it out...
Nov 23, 2010 | Saeco Odea Giro Plus Coffee Maker
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
Saeco odea giro. I can not put back the brewing system
Make sure that the brew unit gears is set on the N, check the little arrow next to the handle. Then check the rotation of the machine, by turning it on closing the door so that it can reset itself. Then look at the gears in the machine and the one that will insert from the brew unit if the big one lines up you're good if not then you will have to take it to your nearest dealer to have it reprogrammed.
Nov 10, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro Plus spare parts needed
The coffee dispensing valve is available at your saeco dealer 1-2 hr job to change...
Sep 27, 2009 | Saeco Odea Giro Plus Coffee Maker
Red ! flashes constantly
The lube is for the o-rings on the brew unit, and the ones on the white plastic valve behind the brew unit. As for the light there might be something a little coffee grounds keeping the door open.
Sep 14, 2009 | Saeco Odea Giro Plus Coffee Maker
Machine stoppped working
Try this remove the brew unit and clean the screen on the unit, then insert unit, and open steam/hot water valve to prime. If that does not work then there might be a malfunction with the pump, I am assuming that the machine is only 2 weeks old?
Jun 25, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro Plus Coffee Maker Logo
381 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
