Question about InFocus Projector Lamp for IN24+, IN26+
How do I open the projector to clean filters - InFocus Projector Lamp for IN24+, IN26+
  • 75 Answers
There are no filters
Posted on Jun 06, 2010
Red warning light
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Turned itself off, can't reset.
Have you been using this projector for some time?
With time, dust gathers in 'air filters' and it hinders the movement of air though the projector. When this happens, projector gets overheated. To prevent damage, it shuts off automatically.
You haven't given much details, but if you think overheating is the problem, open the top cover and clean dust, specially from air filters.
Sep 25, 2011 | Sharp DT500 DLP Projector
It says to Check the air flow
Open the cover. At some ends there will be 'filters', to clean the air entering the projector. If these filters are blocked with dust or lint, air flow will be blocked.
Clean any dust from these filters. Close the cover and check whether your problem is solved.
Sep 14, 2011 | Hitachi CP-X251 LCD Projector
How do you open the filters on a InFocus in24+ to clean?
There are no filters but i would use a vacuum at the case openings
Jun 05, 2010 | InFocus Projector Lamp for IN24+, IN26+
When I turn on my hitachi CP-X205 projector, there is a very noticeable "fan" sound. Yesterday while using the projector it made a sound and then turned it self off. After unplugging it, I plugged it back...
Hi!
You need to clean the projector. Take of the filter and clean it, open the topschell of your projector and clean it.
In time a projector collects a lot of dust inside, if you dosenrt regulary clean the filter the dust pass it and stucks inside the projecotor. Use compressed air for the job but be verry verry carefull so you dont damage anything vital. If you arent sure how to to it i sugest you take it to a electronic repairshop, its cheap and they will clean it properly.
Good luck to you
Nic
Feb 27, 2009 | Hitachi Office Equipment & Supplies
Cleaning my air filters
air flter is on the left of the projector; just click the plastic cover off and then vacuum the filter: if this doesn
Dec 10, 2008 | Hitachi CP-X275 Multimedia Projector
"clean filter" prompt
Hi there
Not at all. This promp automatically appears after a certain amount of hours.
To get this message away , all you have to do is go into the Menu and reset the Filter Timer.
Apr 14, 2008 | NEC VT676 Multimedia Projector
Can't open Filter
Did you remove the two screws on the rear next to the RCA ports?
Tech-no-rom
Mar 05, 2008 | NEC MultiSync VT480 Multimedia Projector
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Displayed massege to check air flow
With most projectors there is a foam air filter behind a grill that is the opening to the cooling channels. A fan ensures air flow to cool the lamp, etc. This filter prevents dust from gumming up the works (and depending on design) may prevent dust getting into the optics. As the filter gets dirty it gradually cuts off the air and at some point a protective circuit kicks in and turns off the lamp.
If the projector is on you will feel a stream of hot air coming out of the exit vent. Projectors vary in terms of amount of air flow, so its difficult to define what is normal for a specific model. However, you can simply hold a hand in front of the vent and see if there is air flow (It will be hot air so, careful). If there is a "good" stream of air things are fine, but if only a very light flow is felt the filter may be dirty.
If the filter has not been cleaned or replaced recently make sure the projector is turned off and cooled down then take off the inlet cover and remove the filter. Clean or replace per the instructions for the projector (and periodically as defined .. but taking into account the operating conditions). Once cleaned turn on the projector and feel the "normal" air current for future reference.
Heat is one of the major causes of projector failure, so make sure cooling vents (inlet and outlet) are not obstructed and filters are kept clean
Oct 02, 2006 | Hitachi CP-S240 Multimedia Projector
InFocus  Projector Lamp for IN24+, IN26+ Logo
121 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
