Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I bought the krystal clear saltwater system and have only had it a week.it seemed to be working up till last night the service light came on. i cleaned it like the book said but the light remains on. any ideas what i should check before i take it back?
    Genius:
  • 1,417 Answers
what this means is an indication of a wire bridge or failure disconnection temperature sensor error. There is a chance that there is a loose wire connection on the wire sensor reader
what you need to fix up the problem is to unscrew it and trace the wire down to the board to fix up the loose wire from is position with the basic tools
please note this peace of advice since your krystal is still very new (A WEEK OLD) you can return it back to the store for complain if you did not have the tools for the operation in other to avoid more damage
thank and thanks for using fixya.
Posted on Jun 05, 2010
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater System Model CS8110 service light is on. I have cleaned the unit inside and out, reset all power connections, and no luck. It runs about and hour and then the service light...
i need a part it is the electroytic cell .it got broken when we were winterising the pool last fall. we are both handicapped and on ss and use the pool to help with the arthris and soreness in our backs .if there is any way you can help we would greatly appericate it .
thank you elbert boswell and wife judy boswell
Jun 25, 2011 | Intex Automatic Salt Water System for ...
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
128 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
