Question about Whirlpool Refrigerators
Bought Whirlpool Refrigerator 2003, couple days ago, the Refrigerator part stopped working while the freezer side works OK,except a liitle frost. what should I check first ?
    President:
  • 1,561 Answers
Before any attempt, make sure the door is sealing all the way. If there's a leak in the seal, things will frost up. You can find a leak by listening carefully for a whistling seal. Also make sure the refrigerator is level. this are the first thing to be chrck.
Take care.
Posted on Jun 05, 2010
  • qxw0215 Jun 05, 2010
    the probelm the the freezer is working fine, but not the Refrigerator.
    if I open the freezer door, I can feel the cold wind going througn to the Refrigerator, if I close the freezer door, the cold wind stopped going through, feel the cycling system is not working OK.
    Please advise.
    Thanks!
    Jean
  • Sulaimon Jimoh Olayemi Jun 05, 2010
    Inspect the gasket for dirt or debris that could prevent
    it from
    sealing. If you find any, remove the large debris, then wash the gasket,
    using a scrub brush and warm, soapy water.
    Check the gasket for
    cracks or tears that can let cold air escape. If
    you find any, replace the gasket. If the gasket appears to be solid, go
    on to step 3.
    Check the seal: Open the door, insert a dollar bill
    partway and shut the
    door on the bill. Try to pull out the bill. You should feel some
    resistance. Repeat the test at several points around each door. If the
    bill slips out easily, replace the gasket.
    If there is any
    circuit breaker, reset it.
    Check for thermostat problems. It
    could be off or won't cool properly
    (too warm,). If it can't be fixed with a simple adjustment,
    call a professional.
    Check for coil problems. The compressor can
    overheat due to dust
    buildup on condenser coils. If so, vacuum the coils.
    The above
    are the likely problem and the solution.
    Take care.
Whirlpool Gold GB2SHTXTS00, I bought it in 2007, but 3 days ago, the cooling suddenly is not working, but freezer and lights are fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Whirlpool Gold Series GB2SHTXTS (219 cu...
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
The freezer fan runs continuosly
It may be because there is some air leak into the freezer. Check if it is closed air tight. Also try defrosting the freezer. Check the fan after that. It may stop working continuously.
Apr 21, 2010 | Kenmore 57029 Side by Side Refrigerator
My freezer stopped freezing a couple of days ago,coil frozen up i defrosted it and now no air is blowing into refrigerator part both freezer and refrigerator are not cold
if the fan is not running then most likely the defrost stat has failed but you should also check the fan for continuity if you have continuity the fan should be ok you can find a defrost stat on parts advantage.com
May 10, 2009 | Amana ARS2661B Side by Side Refrigerator
Whirlpool sidebyside FF stopped working after ? motor stopped ...
this refrigertor is leaking refridgent gas it needs checked by an engineer
Feb 15, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Amana Model ARS2667BW
sounds like the compressor or compressor relay. i would call a technician for this one.
Sep 13, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Refrigerators Logo
29 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
