Hi
Thanks
for using FixYa. Please check that the hoses are not kinked, disposer unit is
not knocked out (if connected with the dishwasher drain hose), filter and drain
pump are not clogged. However, please note that dishwashers do not drain
completely after a finished cycle and this is normal. Dishwashers are designed
to leave some water in the unit to ensure that the heating element doesn’t
overheat. If the amount of water is large then there is an issue. Some of the
most common reasons include that the drain hose isn’t working properly, the
drain pump isn’t working correctly, or possibly there is a plumbing problem in
your home’s drain lines. First check whether the drain is not clogged or
blocked and the line is not kinked. Check all the hoses for blockages &
also clean the air gap. If you have checked the drain hose and can’t locate the
problem, then it is an issue with the drain pump of the dishwasher. Please do
accept the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
