Question about Hayward S166T Pool Filter System w1 HP PumpS166T92S ()
SAND SHOOTS INTO POOL - Hayward S166T Pool Filter System w1 HP PumpS166T92S ()
    Scholar:
  • 78 Answers
Probably a broken or loose lateral in the bottom of the filter. Do you backwash a lot? One thing you might try if the lateral isn't too damaged is let it run for a day, vacuum the sand out of the pool and see if it stops. If this works, good. But the next time you backwash, you will have to do it again
Posted on Jun 06, 2010
Sand shooting back in pool
If you took "Pump" apart, you wouldn't have found broken laterals. You will need to open up the "Filter" to find laterals. If sand is ending up in the pool, you either have a broken component within the filter or you have an overfilled filter tank and during backwash sand is lifted up into the valve, and upon returning valve position back to "Filter" the residual is blown back to pool via the return inlet. If this is the case that is why always follow label / owners manual directions as to Quantity of media to add. More is not necessarily always better!
Jun 19, 2014 | INTEX Sand Filter Pump
Why is sand shooting back into pool
Inside the sand filter there are laterals that are PVC pipes with many narrow slots along their length. If a lateral is broken then sand will not be stopped by the lateral. Another possibility is that the part these laterals screw into is broken and sand leaks through. I hope this helps.
Aug 07, 2011 | Waterway 22" Swimming Pool Sand Filter W15...
I have a Dreamline sand filter by hayward... it is shooting all debris dright back into pool. It works to put it on waste but not the filter function. Also, if we backwash it is still clean. i havent had...
If the pool filter is blowing sand and debris back into the pool, it is most likely due to backpressure. This is cause by air in the lines. You most likely have a crack somewhere in your system. Start by checking all of your connections and plumbing with your filter and pump. Then start checking your pipes, etc.
Jul 25, 2011 | Hayward SAND FILTER, PRO SERIES
Just installed a hayward pump and followed directions on the pump having problems when we tried to backwash it shoots sand into the pool
Backwash should put no water back into the pool. It should be sending filter dirt to a waste line. Maybe your lines are incorrectly installed?
Secondly, under normal conditions, sand does not go to backwash waste either. Could there be too much sand in the filter?
Gary
May 01, 2011 | Hayward Pool & Spa
When turning pump on sand shoots into pool app. two seconds.replaced diverter and lateral coponents. still does the same thing. twm 19 inch p/n 520-1910
If you don't have a manual you can download one here:
http://www.waterwayplastics.com/manuals/810-0092H.0209.pdf
Are you sure you didn't damage laterals when adding sand. Best to have 1/4 water in filter as you add sand. Be sure o ring is in place in multiport valve that fits on downtube.Be sure down pipe is not too low to enter multiport valve. The pipe should fit snugly into the multiport valve o ring. Be sure you have correct sand (pool filter sand only) IF all this is ok, try backwashing till glass is clear. Run on rinse position for a few min. THen go back to filter and see if it still pumps in sand.
Aug 16, 2010 | Waterway Twm Above Ground Pool Pump and...
Hayward 1.5 hp sand filter
Hi i have a Hayward S-180 sand filter and when i clean the pool green algie shoots back into the pool.
Jul 26, 2010 | Hayward SAND FILTER, PRO SERIES
Pool filter problem
You have a problem ...
Can you see the little tube that bleeds air out of the return pipe? If not ... see if you can find it and get it to the top of the filter.
Still have sand? You may have a cracked lateral ... remove the sand and check all the laterals. Replace any that are broken.
When you refill the sand ... be sure to put water in first to soften the beating the laterals take from the falling sand.
Jun 14, 2010 | Hayward SAND FILTER, PRO SERIES
Back - siphoning when the pump turns off.
Make sure you dont put too much sand it will come back out.Put the correct amount and bump the pump correctly.
Jul 23, 2009 | Water Pik Flow Valve Assy. Series II...
Hayward S166T Pool Filter System w1 HP PumpS166T92S () Logo
169 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
