My Lamona integrated washing machine (HJA8513) willnot drain which means that the spin cycle won't work. My husband has checked the pipe and there does not appear to be a blockage. Any ideas?
SOURCE: Washing Machine not draining
same thing happened to me but the obstruction was in the hose at the back of the filter and coudnt be seen in the filter. i paid 150euro to engineer to fix this. i watched him fix it and can do it myself now. they rob you for something that is so simple to fix.
Posted on Sep 26, 2007
  • 62 Answers
SOURCE: LG wft7014pp wont drain rinse nor spin
do you have a drip-dry function...as this cancels the spin cycle unless you select it yourself
Posted on Jan 03, 2008
AlmostBob
  • 550 Answers
SOURCE: water backing up in the drain pipe
many washers have a lint trap just before the pump
the traps get full of socks, lint, or other small items
those that dont have traps, should.
examine the hose between pump and trap and drum, for trapped small items
to see the hose and trap
kenmore whirlpool & heaps of others
Unplug washer
turn off taps
  • remove trims from edge of control panel
  • remove screws from under bottom edge of trims
  • raise slide forward and flip control panel over, hinged at top, do not dislodge air hose to level control
  • remove brass body clips under control panel, not position for reinstall
  • lift body 1/2inch (locator studs at bottom) and remove, top front and both sides come away as one piece
motor pump gearbox tub suspension is now exposed
reassemble in reverse order
Posted on Oct 02, 2008
ned_san_jose
  • 234 Answers
SOURCE: wont agitate,but does spin/drain
you have worn out dog agitation ears. it's a very easy fix. parts should be no more than $10. Good luck :) please let me know if you need any other help.
Posted on Jul 07, 2009
SOURCE: asko 10625 will not spin
it is probably the belt, take off the back of the machine and look at the black rubber belt that spins the cleaning drum. The belts break after about 5 years, you can get a replacement belt at you local Asko dealer, I recall that is was pretty easy to change, like doing a bike chain, Talk to you Asko dealer about how to change it.
Posted on Jul 13, 2009
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
My washer won't drain the water when it spins to rinse cycle and it won't drain when it's on the spin cycle
there is a screen that needs to be cleaned out on the bottom under the wash drum
Jan 15, 2013 | Washing Machines
Fast spin not working. drum going round and draining but not spinning. Help!!!!
Possible there is no drive voltage to the motor at this point of cycle, could be due to fault in the controller unit.
Need to check the voltage on the unit to confirm this case as the drain gets connected..
Jul 27, 2012 | Hoover Washing Machines
Washer making loud noise willnot spin cycle or drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Electrolux AWF 1435 Front Load Washer
Fills up with water as normal but wont spin or drain. checked all house plumbing for blockages and height of drainage pipe as stated in instructions, gets to the spin section of program then all lights...
if its just not working on spin cycle, check the door safety switch, if its faulty the machine won't drain or spin,, you can jumper the wires that go to the switch , and set it for spin to see if thats the problem,
Jul 09, 2011 | Washing Machines
We have a howden hja8513.the problem is the machine will not drain or spin.where is the drain on this model?
the washing machine is not heating the water in any wash programme.
what is the cause and how do i fix it.
Dec 02, 2010 | Washing Machines
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Help me to wash!!
hi
    this sounds like a syphoning problem this means the outlet /drain pipe at the back of the machine has been pushed to far into the drain upstand pipe causing the water to syphon straight through the machine make sure that the drain pipe is only part way down the drain pipe, hope this works for you
cliff
Oct 14, 2007 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
598 people viewed this question
Top Washing Machines Experts
