Question about Whirlpool Ovens
Have Whirlpool built-in double oven model #RB276PXV-0. Clock is not working when off. When turn on, clock comes on but cannot be set. Oven lights come on, both heat slighly but not up to temperature. What could be causing this?
    President:
  • 1,469 Answers
Thought I’d run through a fast diagnosis procedure on an electric oven that’s not heating. This is a pretty common problem, and if you’re reasonably handy, not all that tough to figure out.
First, as always, verify that you have power available. Turn on a surface burner and ensure it heats to a nice red glow, and you’ll know you have the necessary 240V.
Be aware that it’s possible for one side of the 240V supply to ‘drop out’, allowing the surface burners to heat slightly and other components to look normal. But if your surface burners get red hot, you know you have 240V.
Next, and I may be dating myself here, but, if your range uses an analog clock, be sure it's set to ‘manual’. There are several different ‘manual’ and ‘time-bake’ arrangements, but the instructions are usually found on or around the clock face.
We have corrected this many, many times over the years and saved running a service call by asking about this on the phone when receiving a ‘no heat’ call. With some ranges it’s really easy to turn the oven off without realizing it, even while cleaning the range, so be sure and check for this if your clock is analog. If your range uses a red light that indicates the oven’s on - and you’re sure it’s been working - you’ll be able to tell when you get the clock set back to ‘MAN’, because this indicator will come on (and you’ll be a hero!)
If your range uses one of the newer electronic controls and it’s not displaying any ‘error codes’, you’ll need to progress further.
First, power the range down and run your hand over the bake element, feeling and looking for any rough areas. If the unit is electrically open, you’ll usually (not always) find a rough, burnt area, and often this will be obvious. In some cases the element will actually be blown apart, and if that describes yours, the element is definitely bad! These aren’t expensive; most cost between $20 and $30.
But if there’s no obvious damage to the element surface, we’ll continue.
The fastest way to proceed is identical to what we discussed on the ‘no heat’ dryer, and the same 240V test bulb is again put to good use. If you’re not comfortable dealing with 240V, though, all the usual disclaimers apply - call a technician!
Power down the range and pull the bake element partway out of the oven cavity, usually by removing 2 screws. Connect your 240V bulb to the element terminals, being sure they aren’t touching the cabinet, and power back up. Turn the oven to ‘bake’ and watch that bulb. Light: open bake element. No light: control or wiring problems.
If there’s no voltage to the bake element, you might want to power down and remove the range back panel, looking for burnt wires. If there doesn’t seem to be any wiring damage, I'd probably recommend you call a pro.
In most cases, you’ll find either a burnt terminal (replace only with high temp nickel plated ones) or an open element, and either of these are well within the capabilities of a handy homeowner.
You can use this site as a guide to the solution.Use this link to check that out.
(home.howstuffworks.com/how-to-repair-an-oven.htm/printable).
and
(stoveclockrepair.com).
Take care.
Posted on Jun 05, 2010
How do i set the clock on Whirlpool built in double oven? Can't find a model number. 5 buttons from left to right. Alarm bell, clock with hand at 12, clock with hand at 3, + and - signs. Pleas
The model number is usually located on the side of the door or on side of the oven cavity area near the door opening. Sometimes if you have a drawer or warmer the model number is located on the oven side of the drawer or warmer (sometimes not directly facing you but on the side of that area. If the oven is electronic you press a clock button or you hold one of those buttons for a couple of seconds like a start or set button. The model number though will help you find a user manual and it for sure should be clear. I hope this helps you.
Nov 16, 2014 | Whirlpool 24" Double Electric Built-In...
The power went off, when it came back on the oven time displayed. when we tried to turn on the oven the message feature not available came on
First try this: In your Household Circuit Panel, Turn the Circuit Breaker to the off position. Wait 30 Seconds and then turn it back on. Try to turn the oven on if it comes on you are in luck, if not look in your manual for first time set up instructions like setting the clock date and time, and go through the settings. Then try the oven again. If it comes on you are in luck.
Oct 15, 2014 | Whirlpool 24" Double Electric Built-In...
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
you have to push 2 of the buttons at the same time. usually - and + for 3 seconds. you will see the display change. good luck.
Jun 01, 2017 | Zanussi ZBF360 Electric Single Oven
I have a whirlpool double oven, self cleaning. I do not know the model number right now. We woke up this morning, and not sure if there was a power failure in the house, but the oven display is out. The...
HI,
Sounds like you need a repair person to check out the power to your display (clock), If your clock has power but will not display you could need either the transformer (low voltage 12 volts) or a ERC (which is the clock). Lately I have noticed transformers have been on the rise in several of these models. Also the transformer is alot cheaper than the ERC. If you can test this, you will find the connection you need is on the board as you tip the control panel, you will find the light blue wire bottom right of the control board. If you have 12 volts to the clock there, your clock is bad, in not your transformer has failed.
If you have never done anything like this call someone to help you, Be safe with electricity!!!
I hope this helps
Jul 26, 2011 | Whirlpool GBD307PDS Electric Double Oven
I have a whirlpool double oven mod GBD 307PDS10. I have just replaced the control board. It was working fine for about 30 minutes and I had the clock set and it was good to go, But now the clock button...
Try removing the ribbon connector and cleaning the end that plugs into the microcomputer. You can rub it lightly with an eraser or use electrical contact cleaner on it.
Jan 13, 2011 | Whirlpool GBD307PDS Electric Double Oven
OVen display is blank and oven won't turn on. Oven has power (checked breaker, oven light works)
Can you supply a model number?
Most likley you have a bad erc control board ( clock). But a model number would help narrow it down.
Jan 02, 2011 | Whirlpool RBD275PD Electric Double Oven
The display is blank, yet the light comes on. The
i'm assuming everything works but you cant see the clock?
if this is the case then you need a new clock board.
very common on these wall ovens
Oct 07, 2009 | Whirlpool GBD277PD Electric Double Oven
Cannot set clock Model RBS245PDB2
you need to replace the clock timer board..
Aug 09, 2007 | Whirlpool RBS245PDS Electric Single Oven
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Ovens Logo
70 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
