Question about Mtd Garden
I have a 2004 Troy Built Poney 17.5 Briggs & Stratton Riding Mower runs for about 3 minutes with blades engaged then is starts to die on me. Sometimes if I dis-engage the deck blades it will keep running, then it might die also. I changed the air filter, oil, spark plug, rebuilt the Carb. Fuel Solenoid is wirking fine (bench tested) with battery. Could my belts need replacement being worn out, maybe a sencer switch? I need help with this one sir! Randy Reitan
  • 36 Answers
What color is the spark at your sparkplug? If it's red, it's weak,if it's blue it's hot, clean the magneto contacts with sandpaper and wd40 and clean the coil too, let me know how you did!
Posted on Jun 08, 2010
My troy built briggs and stratton 22hp riding lawn mower when I engage it makes a clunk sound but the pulleys and blades wont turn
sounds like you have something stuck on the blades. if not check to see if you can turn the blades by hand all the way around. its possible the spindle bearings locked up. (with the engine off)
Jun 14, 2016 | Troy Garden
I have a Troy-built gtx2654 lawnmower with a Birggs & Stratton engine mod 47777 typ.0229E1 want to troubleshoot charging sys.
You can test the charging system by starting the mower and then unhooking the negative terminal from the batter, if the mower stays running, the charging system is working, if it dies immediately the charging system is faulty, you can also use a tester at the engine to test the voltage at the connectors
Oct 12, 2013 | Briggs & Stratton Briggs Stratton...
Blades wont work on 2004 troy built riding mower
check the belt tension if it has a switch to turn it on check the fuses and see if theres power going to the clutch
May 19, 2012 | Garden
Riding mower 14hp briggs & stratton will not stay running, new solenoid, new spark plug, new air filter, new fuel line and filter. At first it didn't want to start solenoid fixed that. It started ran...
Check the belt/s and make sure they are clear. If they are okay, check the governor spring. If the spring is gone, it will start but as soon as a load is put on it will stall. Good luck...Lee
May 29, 2010 | Garden
I have a model 13aq609g063 troy bilt riding mower. It has a 18hp briggs & stratton, 2 cylinder, ic engine. the engine runs fine, the bottom pulley on the engine for the pto belt turns when running, and...
Another possibility, is a broken spring or a tight/ rusted idler pivot arm.
with the engine off & the deck down, engage the pto & pull on the belt to see which pulley is the tensioner
Nov 07, 2009 | Garden
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have rjdeing lawnmower with a BRIGGS&STRATTON 13.5 OHL WHEN YOU PUT IT IN GEAR AND ENGAGE THE BLADE IT LOSES POWER WQNT RUN. FAMLEY 4BSXS.3442VM 275943
if you mean that when you let off the clutch pedal and/or engage the blades, the engine dies, lift the seat and make sure the connector is firmly plugged into the switch attached to the seat.
Sep 28, 2009 | Briggs & Stratton Garden
Garden Logo
184 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
