Question about HP Office Equipment & Supplies
Living in France, I have an OfficeJet printer HP5510 all-in-one "since 2005. Everything works perfectly until today: in fact the leaves start and you will hear the rollers rotate. I regularly cleaned with a damp the roll but it seems that this is the arm and wheel that are failing. Can you give me some solutions? Cordially
    President:
  • 3,085 Answers
Clean the rollers with 99% isopropyl alcohol from a phamacy
Posted on Jun 05, 2010
All photos are printed with a blue tint behind them.
#Perform print head nozzle cleaning from printer properties..
# Do align print heads.. check.. repeat 2-3 times till good result comes.
Aug 02, 2015 | HP CR769A Officejet 7610 Wide Format All...
Officejet pro 8500a premium power light on but touch screen is off and will not respond and the power button will not respond either
hi, Mr Justin Becker
i think its a power supply problem, first you should try another dc adaptor, if your printer works fine with the new one, you have to replace it or take it for repair.
if it is a DC Adaptor problem it cost about: US $29.74
HP OfficeJet Pro 8500 AIO GSA printer power supply ac adapter cord...
Mar 06, 2014 | HP Office Equipment & Supplies
Ford Focus 2005 - cold start backfire - runs great after 5 mins, when hot
White Smoke out the exhaust, is usually a sign
of coolant & most likely the start of a bad head gasket
At this point your use of the car should be curtailed,
to prevent any further damage
You should not use the car at all, until all issues are
diagnosed & resolved
Plan on using other means of transportation
Jun 21, 2012 | 2005 Ford Focus 1.6
My HP6500 worked perfectly until I had to take my HP laptop back to factory settings. Now it will not scan (no scan options). Help. I really need this for small business application. Running Windows 7.
Try uninstalling the printer drivers and reinstall them, setting everything back up the same way as before, also, make sure that you restart before reinstalling, link for the software download here http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=us&dlc=en&sw_lang=&product=3795314 use the one labeled full featured to get scanning features etc. good luck and i hope i was able to help! don't forget to rate
Mar 17, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp 5510 printer/copier/fax/scanner will not print docs. The paper goes through but nothing is on the paper. Tried to print test page, same result. I've checked the cartridge - not empty. Haven't used the...
It sounds like the jets on your cartridge is plugged. I have unplugged some cartridges by soaking the jets in alcohol. I pour some alcohol in a shallow dish and set the cartridge in it with printing jets down. Leave it for 5-10 minutes. If the jets start to unclog you will see the ink discolor the alcohol.
Be careful when wiping off the ink jets so you don't damage them. Use a soft cloth. Try the cartridge and see if it prints. If you need to soak it longer.
Jul 13, 2010 | HP Officejet 5510 All-In-One Thermal...
My printer won't turn on and everything is plugged properly
in that case please follow this step
1) Power Code Check first if its working not perfectly so please change it.
2) if Power Code working fine then other thing is that may be some problem with Printer Hardware may be due to short board its not working need to repair this.
May 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 6110 all-in-one won't print despite new cartridges
make sure that the housing that holds the cartridges are clean at the contacts, this can be done with the machine turned off and unplugged, clean the contacts with warm water and a damp cotton bud not wet and then dry it with a paper towel.
make sure everything is dry before turning the printer back on, if this doesnt work then it needs a service.
Nov 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP officejet 7210 all-in-one printer problem
Printer - Black cartrage reading in window change, I did twice and still will not work.
Sep 26, 2008 | HP Officejet 7210 All-In-One InkJet...
24 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
