Question about Watts 75w Power Inverter 12v Dc To 220v Ac With Usb 5v 9803
Power inverter fan don't work
I recently bought a power inverter for own use.. my power converter can convert to 300wtt .. i already test the item.., and it work.., but i think something wrong because the fan not working.. i assume that maybe because the power inverter still on normal temperature , so the fan don't work.. am i right? i think something wrong with my power inverter.. can anyone help me solve this problem,,,...
    Champion:
  • 225 Answers
Fan should come on when the unit has a load on it and it starts to get hot.
Posted on Jun 05, 2010
What can i run with a 500 watt stanley converter
Assuming the output is 120VAC, you can only run items pulling about 4 amps. If the voltage output is 220 VAC, you can only run items pulling about 2.25 amps. Read the labels on the devices you want to use, they should list either watts or amps used.
To convert amps to watts: Current times voltage
To convert watts to amps: Watts divided by voltage
Dec 04, 2012 | Electronics - Others
How can I connect PS3 to ACER X110P Projector
does the projector have an HDMI port?
i would buy the cable that is HDMI from the PS3 (unless it has HDMI already)
HDMI converter (HDMI to DVI or VGA) typically don't work well because you are changing the signal from digital to analog through a cable. you want to use a cable that is the same on both ends.
Nov 09, 2012 | Acer Computers & Internet
I have recently replaced the wiring in my utility trailer and mechanic has tested lights when in the shop and says they're all working fine. Hooked it up to my pathfinder and lights were not working. ...
lights on the trailer are supposed to only work when the vehicle has its lights turned on. brake light problems is easy to figure out. it should run off a yellow wire for driver and a green for passenger. see if you have power with brake on. if so check the bulb. if not then check your 4 way flashers which run off the same general circuit. if 4 ways work but no brake lights double check your converter connections.
Sep 24, 2011 | 2002 Nissan Pathfinder
I recently purchased a schumacher 410w inverter, while it came on right away and powered my electrical device the cooling fan never came on. Is the fan supposed to run all the time, once its connected.
I recently purchased a Schumaker 410/820 watt inverter. I immediately hooked it up to a brand new deep cell batery I had purchased just prior to receiving this inverter.
I plugged in several devices to make sure the inverter worked and to get some idea of what devices I can expect this unit to handle.
I noticed that the fan only ran when I plugged in a device that drew a certain amount of power from the unit. I also plugged in a CPAP unit to make sure the inverter would operate the unit properly, and noticed that the CPAP only drew 38 to 40 watts of power and the cooling fan on the converter never came on. When I plugged in an oscillating fan it drew around 128 watts from the converter and the cooling fan immediately came on when I turned the fan on. Based on that, I would assume that the cooling fan in the converter only runs when there is enough power being drawn through the inverter to cause the inverter to heat up enough to cause possible damage to or failure of the inverter. I haven't taken the time to find out the power draw at which the cooling fan will run. Hope this helps.
Jul 10, 2011 | Schumacher 410 Watt Power Inverter...
I have a 400 watt but as soon as i plug anything into it it beeps untill i unhook it
This sounds like too much load for the converter, test with lighter load items...
Oct 04, 2010 | Electronics - Others
Bought a new vector maxxsst 1200 watt inverter
Inverter run on batteries sir, and if these batteries are not charged, the run time {the number of hours it will work} reduces.
S0, you will need to connect the inverter to a power source.Theses will allow your batteries to be charged and enable it to run for a long period of time.
Make sure your batteries are still OK.i.e working properly
May 03, 2010 | Vector ® Maxx SST 1200 - watt Power...
I have a 39 ford 6 volt battery operated car. I
you need a voltage doubler circuit which feeds from your 6V DC system and converts it to AC and steps it up and converts it to 12V DC. This device might be difficult to find. OR use a 6Vdc power inverter and just use a 120volt AC fan if much easier to source out in your area.
You might want to try a 12VDC high speed fan and see if the 50% reduced speed is already sufficient for you.
Aug 30, 2009 | 2001 Ford Escape
Powering car stereo using AC to DC power converter
your power supply may not have enough power to run the radio.
Mar 31, 2009 | Car Audio & Video
Sanyo TV, older model, tv converter box, terk antenna, will not p
DP models are already digital there is no need of a converter box. connect a outdoor antenna to the tv directly.
Mar 04, 2009 | Sanyo DP32746 32 in. LCD Television
I just bought a 1977 Dodge Monaco Motorhome and just replaced the house battery with a brand new marine battery. Now I'm finding that it runs all the lights and everything except the 110 outlets. I need to...
It is called an inverter, and it may not be hooked up, u will have to trace the source power for the outlets and at the source add an inverter to change 12 volts DC to 110 volts AC.
Dec 13, 2008 | Dodge Pickup Cars & Trucks
Watts 75w Power Inverter 12v Dc To 220v Ac With Usb 5v 9803 Logo
280 people viewed this question
Top Watts Electronics - Others Experts
Mark McGinty
Mark McGinty
David Tickner
Brett Duxbury
Brett Duxbury
Are you a Watts Electronics - Other Expert? Answer questions, earn points and help others
