Question about Jenn-Air Grilling
Flame near knob
The flame pops out near knob, then goes out to the main burner, very loud when this occurs
    Problem Solver:
  • 16 Answers
Burners are clogged or defective and the flame is "backing up" which may have damaged your gas valves and/or ignitor. Try removing and cleaning the burners with a wire brush or if under warranty, have nexgrill replace them all.
Posted on Aug 25, 2010
PILOT LIGHT COMES ON BUT WHEN YOU TURN THE KNOB TO ON IT DOES NOT LIGHT UP THE CIRCLE PLATE IN THE HEATER. IT JUMPS AND THE FIRE COMES OUT THEN IT GOES OUT.
I'm not sure what unit you are troubleshooting but if the main burner is igniting and that main burner flame is blowing out the pilot flame, it's possible the pilot flame orifice needs to be cleaned. The orifice can get stopped up and produce a weak pilot. And I've seen a pilot lite, but be blown out by the combustion of the main burner igniting. Now you stated IT JUMPS. If you mean the pilot flame jumps, as if it gets large then weak and goes out, then the gas valve is giving you trouble and may need to be replaced.
Mar 09, 2017 | Heating & Cooling
Your Question Preview Fire Magic A790i Logo Problem with A790i Firemagic a790i flames pop and knobs get hot Posted by Author imageGuest on 3/24/2013 Details not getting good pressure to all 3 b
It sounds as if the burners may not be properly seated on the valves. Instead of all of the gas flowing into the burners, some of the gas is escaping behind the front panel and creating a fire behind the front panel which would heat the valve shafts and melt the knob inserts. This call also be caused by partially blocked burner venturi and valve orifices.
Check to make sure the end of each valve is completely inside of each burner.
Mar 24, 2013 | Fire Magic A790i
Frigidaire plef398dca
Hello Bill Robbins - From what you are describing it sounds like a wiring failure or a communication break failure between the power board and UIB has occurred. Error code F5, typically indicates that the EOC will need replacing. A certified technician will need to test the wiring harness between the ESC, UIB and EOC.
Jan 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Pilot light goes out when gas turned on
I am assuming that you are saying that after you have pushed the pilot knob down and the pilot lites and stay lite and then you turn the knob to turn it to ON the pilot goes out...... Then the Gas Valve is bad and will have to be replaced....... Or if you are saying that the pilot goes out when the burners come on then you may need to replace the Thermocouple because the main burner flame is pulling the pilot flame off of the thermocouple and it is weak and will shut the gas off.... Or You could have a cracked heat exchanger that when the burners are on and then the blower comes ON and is blowing the flame around and blowing the pilot flame off of the thernocouple......which will shut the gas off....and then you will need a new furnace or New Heat Exchanger...... These are the most common problems Hope this helps.....
Feb 16, 2011 | Heating & Cooling
When I push down and turn the knob to "on", the knob pops back up causing the burner to turn off. Any ideas on how to fix this? Thank You
You might need to hold it down for a few seconds if the cook top has automatic flame detection. A bi metal strip (or some other form of thermostat) near the burner will need to heat up before the burner can lock on.
Jun 15, 2010 | Jenn-Air JEC9530BDS Stainless Steel ...
Pilot flame lights but goes out when knob is released
i would try cleaning or replacing the thermocoulpe if you did replace it make sure the flame is touching the thermocouple
Jul 30, 2009 | DCS PHFS Phoenix III Outdoor Patio Heater
The burners sounds like a jet plane.
make sure the burners are clean, each and every little hole must be clean. It sounds as though the flame is burning near the inlet of the burner which can occur if the holes are restricted too much.
May 26, 2009 | Ducane 455 inch 2 - 3 Burner with...
When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Lift the top of the Stove up.
Look for a Small line that goes to the Affected Burner.
At the end of that Line you will see a small Flathead Screw.
Turning That screw Clockwise Adjusts your Pilot Light for that Burner.
Be careful not to Adjust to High, it would just be a Waist of gas.
hope that helped.
May 20, 2009 | Gaggenau 11 in. VG 232 Gas Cooktop
Ducane 3 burner medidian
POP OFF A KNOB AND LOOK TO SEE IF THERE IS A TINY SCREW IN THE CENTER OF THE KNOB SHAFT . THAT WOULD BE YOUR ADJUSTMENT FOR GAS FLOW. IF IT'S NOT THERE, THE PROBLEM IS IN YOUR REGULATOR, AND IT'S ADJUSTABLE AS WELL.
Feb 18, 2008 | Ducane Meridian MDBQ-30 Grill
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Grilling Logo
116 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Fred Harvey
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
