Question about Remote Start System
Cannot program a replacement transmitter.
I went through the programming instructions several times. After each step I received the feedback from the system as given in these instruction but new transmitter will not function.
  • 74 Answers
Unplug your antenna and short out all the terminals on the antenna together then try again
Posted on Jun 08, 2010
How to program New key switch 2000 oldsmobile silhouette
Key switch ? key fob ? Transmitter Programming ?
If you lose a transmitter, program the old and new transmitter(s) into the remote control door lock receiver's memory. Up to 4 transmitters may be programmed.
Important: Once the remote control door lock receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information, requiring the programming of all transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If more than 1 receiver is being programmed at the same time, it is possible that the same transmitter could be programmed to more than 1 remote control door lock receiver.
Perform the following steps in order to program the transmitter:
  1. Remove the ignition key from the ignition lock cylinder.
  2. Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block in Wiring Systems.
  3. Close all of the doors.
  4. Close the lift gate.
  5. Turn the ignition lock cylinder to ACC.
  6. Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second.
  7. Open and close any vehicle door.
  8. A chime will be heard when the system enters the BCM programming/diagnostic mode.
    Important: After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
  9. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
  10. Repeat the previous step on each additional transmitter to be programmed.
  11. Remove the ignition key from the ignition lock cylinder.
  12. Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block in Wiring Systems.
Apr 22, 2016 | Oldsmobile Cars & Trucks
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
I went through programing as far as lock recycling but wont go any further
Remote Transmitter Programming NOTE: All keyless entry remote transmitters must be programmed at the same time.
NOTE: Programming (or reprogramming) the keyless entry remote transmitters into the central security module can be accomplished using a diagnostic tool or by carrying out the following steps.
  1. Turn the ignition switch from OFF to RUN eight times within 10 seconds, ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after Step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the doors will lock and unlock one last time to confirm.
Mar 18, 2016 | 2004 Ford F150
How can I program a key fob
GRAND PRIX KEY FOB PROGRAMMING INSTRUCTIONS Transmitter Programming No Tools Required In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver.Up to 4 transmitters may be programmed Important Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver
Apr 22, 2013 | 2001 Pontiac Grand Am SE
Alreaddy did replace new batteries for key remote but the key remote is not working properly.. What cause is that?? do you know??
I know that this procedure work for Grand Prix and Monte Carlo, tesi it...
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Repeat step 8 in order to program each additional transmitter.
Hope helps.
Jul 16, 2010 | 2001 Pontiac Grand Am SE
The security system won't let car start key not being read
From General Motors Corporation....
Method 1-No Tools Required
Important
Once entering this procedure, programming the first transmitter erases all previous transmitters. You must program all transmitters.
Program one vehicle at a time. One transmitter could be programmed into other vehicles that are also on program mode in close proximity.
Sit in the driver's seat.
Close all vehicle doors.
Press and hold unlock on the door lock switch.
While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure.
Release the door lock switch. You will hear three chimes. This chime feedback indicates that transmitter programming is active.
Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for 12 seconds. You will hear two chimes.
This chime feedback indicates that the transmitter has been programmed successfully.
Repeat step 8 for the rest of the transmitters (for a total of 4 transmitters).
Exit this procedure by removing the ignition key from the ignition lock cylinder.
Hope helps (remember comment and rated this).
Jun 23, 2010 | 1998 Buick LeSabre
I have a problem with opening car doors with remote for 1997 pontiac sunfire. I noticed that when you are in the car and you activate the open and close switch from drivers side the locks at the rear open...
Try this procedure...
No Tools Required
In the event that a transmitter is lost, program the old & the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Program only 1 vehicle remote control door lock receiver at a time. If u program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Sit in the vehicle driver is seat. (actually it’s much ezr from the front pass seat)
Close all of the vehicle is doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body & Chassis.
Open & then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If u do not hear a chime, start again at step 1.
Important
Press & hold the transmitter LOCK & UNLOCK buttons simultaneously for 14 seconds.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body & Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation
Hope this help (remember comment and rated this).
Apr 16, 2010 | 1997 Pontiac Sunfire
Remote wont work
Important
Once the Keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Sit in the vehicle driver's seat. (actually it’s much eazy er from the front pass seat)
Important
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation.
Good luck and hope this helps.
Jun 17, 2009 | 2000 Pontiac Grand Prix
THE REMOTE DOOR LOCK ON A 2000 BUICK CENTURY HAS QUITE WORKING. THE FOBS ARE GOOD BUT WON'T OPEN ANYTHING.
The transmitter may have lost programming,
IMPORTANT:
  • Once entering this procedure, programming the first transmitter erases all previous transmitters. You must program all transmitters.
  • Program one vehicle at a time. One transmitter could be programmed into other vehicles that are also on program mode in close proximity.
  1. Sit in the driver's seat.
  2. Remove the ignition key from the ignition lock cylinder.
  3. Close all vehicle doors.
  4. Press and hold unlock on the door lock switch.
  5. While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
  6. Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure.
  7. Release the door lock switch. You will hear three chimes. This chime feedback indicates that transmitter programming is active.
  8. Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for 12 seconds . You will hear two chimes. This chime feedback indicates that the transmitter has been programmed successfully.
  9. Repeat step 8 for the rest of the transmitters (for a total of 4 transmitters).
  10. Exit this procedure by removing the ignition key from the ignition lock cylinder.
May 07, 2009 | 2000 Buick Century
Remote keyless entry not working
KEY FOBS FOR THIS MODEL MUST BE PROGRAMED USING A TECH 2 SCAN TOOL SO IT MUST BE DONE AT THE DEALERSHIP FOR ABOUT HALF HOUR LABOR HOPE THIS HELPS
Mar 28, 2009 | 2003 Chevrolet Monte Carlo
Remote Start System  Logo
230 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
