Question about Logitech Cordless Mouse
Light is off on mouse.
Did not turn mouse off after using. Do I need a new battery or a new mouse?
  • 180 Answers
Most probably your battery is exhausted but usually mouse battery lasts a lot. Any way replace the batteries and check the status, if ithe light is not coming go to your dealer and demand a replacement/repair if still under warranty. If not under repair you will have to pay a small amount for repair
Posted on Jun 05, 2010
WELL, I HAVE DE EX 100, SO SUDDENLY THE RED LIGHT TURNED OFF, SO I CAN0T USE IT ANYMORE, I TRIED PRESSING THE CONNECT BUTTON, AND THE KEY BOARD IS ONLY WORKING AND THE MOUSE DOESN'T HAVE THE RED LIGHT...
Hello, try fitting new batteries in the mouse. The top rear half of the mouse slides back and lifts off. You will need 2x AA batteries. Use good quality ones (like Duracell) Regards, nicam49
Feb 17, 2011 | Logitech Cordless EX 100 Mouse
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Feb 08, 2010 | Targus Wireless Optical Notebook Mouse...
My Dynex Wireless Optical Mouse just stopped working
If the mouse light is not turning ON even though you have new batteries and the mouse is turned on, then you need to contact the manufacturer for RMA.
Thank you!
Dec 22, 2009 | Dynex Wireless Optical Mouse
My mouse isnt responding at all. the weird thing is, when i put the battery in, the light doesnt turn on
you need to press the reset switch ont he recever that connect to the computer and then the mouse so it can sink up.
Dec 04, 2009 | Logitech V220 Mouse
Haven't used mouse in a while. Green light on
Yes, new batteries should correct this problem for you. It's recommended if you will not use the mouse for more than 2 weeks, take the batteries out.
Good luck
C2Solutions
Oct 19, 2009 | Logitech Cordless Click! Plus Optical...
How to turn keyboard and mouse on
make sure there is new batteries in both the mouse and keyboard. Also the wireless receiever that connects to the computer is responding as well.
After you get new batteries put in and also have the receiever plugged in. press the caps lock, num lock keys and see if they light up on the receiver. If they light up then things are working, if they don't then bring up the notepad and see if any of the keys show up in notepad when you type and also see if the cursor on the screen moves for your mouse.
Hopefully both of them will work once you change batteries. If both don't work after changing batteries then you'll need to get a new wireless keyboard/mouse kit.
Jun 29, 2009 | Logitech Wireless Access Duo Optical...
I have a logitech which used to work with window vista home premium 64 bits version. Today it is not connecting although i replaced the batteries and the light in the back of the mouse is dim and sometimes...
THE MFG MAY HAVE A CERTAIN BATTERY REQUIRMENT, NEED TO GO LINE AND LOOK UP THAT INFORMATION, DEPENDING ON THE MFG AND THE BATTERY COMPANY THEY WANT YOU TO USE IF YOU DONT USE THERE BATTERY REQUEST THAN YOU WILL END UP BUYING A NEW KEYBOARD OR MOUSE WHEN THE BATTERIES RUN LOW.
LOOK FOR A LITTLE PIN HOLE ON THE BOTTUM OF THE MOUSE ALSO EVERY TIME YOU CHANGE THE BATTERY YOU LOOSE THE FREQUENCE THE MOUSE USES, SO DEPRESS THE BUTTON UNTIL THE COMPUTER SAYS IT HAS FOUND A NEW PIECE OF HARDWARE, THAN THE MOUSE SHOULD WORK FINE.
GO ON LINE AND SEE IF THERE ARE ANY NEW UPDATE FOR THE MOUSE
RODGANDYSR
Mar 05, 2009 | Logitech Cordless Mouse
The light in the mouse went out and I assumed it needed a new battery so I just opened it up...and no battery.
If this is a USB mouse (which the U0636 is) it will not have a battery. Batteries are only used in cordless mice. If the mouse does not light up, try another USB port. If still no light, you will probably need a new one, which are fairly cheap.
Jan 08, 2009 | Dell U0636 Mouse
Logitech S510 mouse will not turn on
I am assuming since you need batteries that the mouse is cordless. If so you normaly have to sync the mouse with the receiver.If the keyborad and mouse came as a package it will only have one receiver.There should be corresponding sync buttons for these devices.
Oct 07, 2008 | Logitech S 510 (967555) (DH967555)...
Flashing light
cycle the batteries in a external charger a fex times (charge then discharge) I suspect that over the years of using then putting it in its dock the batteries have had a very erratic charge discharge cycle cycling them as I suggest should bring them back.
Jul 25, 2007 | Logitech MX 700 Mouse
Logitech Cordless Mouse Logo
98 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
