Question about Homelite Curved Shaft Trimmer Bump Feed Replacement Line
Remove stuck trimmer head on Homelite String trimmer
3 Suggested Answers
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Posted on May 16, 2009
nova2nv
  • 197 Answers
SOURCE: Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Posted on Nov 28, 2009
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Jul 12, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
How to restring dual feed trimmer
YOU MUST REMOVE THE STRING HEAD YOU SHOULD HAVE TWO PEICES THE IUTER HOUSING YOU SHOULD CLEAN THE INNER SPOOL REMOVE ANY OLD STRING AND LOOK ON THE BOTTOM THERE SHOULD BEARROWS TO TELL YOU WHICH WAY TO WIND THE NEW STRING
Aug 16, 2009 | Homelite Garden
My homelite trimmer string keeps getting stuck and when i tap it to release more string it doesn't the spring in it doesn't spring at all. I constantly have to stop take it apart pull enough string to edge...
It's sticking pretty good. Try what I do: Pull the head off and clean it out pretty good. Also clean where the spool attaches to the trimmer. Before you reassemble it, give it a shot of powdered graphite (I get mine at the hardware store. It's for locks). Reassemble the spool onto the trimmer. Bump it on the ground several times to distribute the graphite within the head. Now, press the head in and pull on the trimmer line. It should dispense a little line and stop, just like when the machine is in operation. If it works, you're done! If it doesn't work, you will need to replace the spool. They are available at the major hardware stores. Even if you have to replace the spool, the graphite trick is a good one. It'll keep the head dispensing line smoothly. I add the graphite probably every 7th or 8th time I rewind the spool.
Best regards, --W/D--
Aug 09, 2009 | Homelite Garden
Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Curved Shaft Trimmer Bump Feed Replacement Line Logo
1,008 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
