Question about Apple iPod touch
My son set up my ipod with a connection name and password.
I would like to change both but I do not know how.
I've tried in the ipode it self but that didn't work.
Please help!
  • 1,170 Answers
You can open up the connection by tapping on the blue arrow next to it. Then tap on the Red "Forget Network" button to remove the connection and then again connect.
Posted on Jun 05, 2010
Volume limit password reset on ipod nano
Hi
How to Unlock iPod Volume Limit
Your iPod volume can be limited, and in many instances, a PIN number will be necessary to remove the limit. If you've forgotten or misplaced your PIN, you can still unlock your iPod volume limit using your computer.
1 Connect your iPod to your PC. Make sure your hidden folders are visible.
2 Navigate to the "iPod_control" folder. This will be a hidden folder. Once you've found the "iPod_Control" folder, navigate to the "Device" folder.
3 Locate the file named "_volumelocked" in the "Device" folder. Delete this file.
4 Eject and restart your iPod.
5 Navigate to "Settings" on your iPod. Select "Volume Limit." You'll be able to reset your volume limit with a PIN or password.
Tips & Warnings
Do not listen to your iPod at high levels for long periods of time; doing so can damage your hearing.
Nov 23, 2011 | Apple iPod nano
My son gave me an older computer and wireless Linksys-G model WRT54GS router. I bought my wife a ipod for christmas and in the setup of the ipod it is asking for a password for the router. My son does not...
Reset the router to default....the default username and password is usually on the bottom of the router..then open a web page on your pc and connect the router with a network cable..type 192.168.0.1 or 192.168.1.1
Use the generic name and password to logon....once logged in, configure username and password and wifi...once setup..save and exit..disconnect and connect router to internet modem...log onto pc and look for your wifi neteork name..cheers
Jan 24, 2018 | Linksys Wireless-G WRT54GS Router...
I recently purchased a new 4th generation ipod and here's the problem when trying to add apps to my ipod thru my home wi-fi nothing happens [ I had Cox Cable set up my wi-fi ] but when I'm at a Starbucks...
Go into the setting on the ipod and reset network setting, Restart the ipod and then go back into the network setting and when it ask for the password, Enter the password for your home network
Dec 23, 2010 | Computers & Internet
Cannot connect ipod to netgear router. Every time I get same message cannot connect. My son has an ipod too and he has no problems connecting. I called Ipod and they say to call netgear. Netgear wont anser...
First make sure you have the WiFi capability turned on on the Ipod. You can go to settings, and turn it on there. After you have that on, can you see the Network Name? (SSID)When you see the name of the router, select it to connect now you will have to have the Network Key. It is usually located on the adapter(Netgear) itself. You have to make sure that number is the same number unless it has been changed. Your son should be able to see what your Network name is. Once you see that name try to connect, it will ask you for the wireless network key, ou should be able to connect.
Dec 24, 2009 | NetGear RangeMax WPN824 Router
Ipod touch will not accept my network
Go into General settings, then under Wi-Fi settings make sure it's turned on first, then if you can see the name of your next work, to the right of that you should see a blue small arrow pointing to the right. Click that, at the bottom of that screen your HTTP Proxy should be set to off. If you can see the first 4 boxes have your IP address,subnet,router, and DNS information in there, click Renew Lease and try to connect again. Make sure your password is entered correctly, meaning if you have upper and lowercase letters in your password enter them the same on your ipod. You may need to authurize your Ipod on your router before it will allow it to connect, not sure what type of router you have. Hope this helps Cali
Jul 16, 2009 | Apple iPod touch
Locked it by accident
After completing the following, your iPod will become a password recovery disk, which will allow recovering your system password in case you get locked out. Note: This tutorial is only works for WinXP. Required Items:
  • Windows XP Home/Pro
  • iPod Nano or iPod Video
  • USB-iPod Connection Cable
Set Up Procedure:
1) Connect your iPod to your machine and verify that it appears as a standard drive in "My Computer". (ex: "Joe's iPod (G:)")
Note: If it doesn't appear and you have iTunes Installed, make sure "disk use" is enabled.
2) Go To Control Panel -> User Accounts -> Select Your Account -> Related Tasks - > "Prevent a forgotten password". A Wizard should appear.
3) Select Your iPod's Drive Name -> Enter Current Password -> Finish Once complete your iPod should be setup as a password recovery disk. Do not delete the "userkey" file, which you may see when browsing your iPod's contents. To test your recovery disk do a quick Log Off and try logging in with an incorrect password. Select "use password reset disk". Then proceed and select your iPod's drive name. If all goes well it should you will be allowed to create a new password
Nov 24, 2008 | Apple iPod nano
Can't remember password
I had the same problem. And I coudn't remember my SCREEN LOCK Password as your son. So what I did was I just disconnecteed my IPOD while it was connected to itunes without properly ejecting. This method doesn't retrieve or resets the password, it justs opens your ipod out of the screen lock. so your son can hear his music as usual until he can get a password retreive helper.
Nov 20, 2008 | Apple iPod classic MP3 Player
Netgear 834
changed wep to wpa.ipod works great
regards
Jan 05, 2008 | NetGear DG834G Router
Apple iPod touch Logo
22 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
