Question about Intel Motherboard
Computer Build Problem
I purchased a PC Kit from Tiger Direct that included an ASUS P5N-E SLI motherboard and Intel Quad Core Processor and NVidia 8800 GTS Video Card 2 Gigs of ram a Ultra 550 watt power supply and Ultra case. I put it all together pushed the power button and the system would start up for about a half second and shut down.
I have tried the following solutions:
1 - Called ASUS, they said the motherboard need a new bios for the quad core processor. They sent me a new one. Put everything back together, still had the same problem.
2 - Thought it might be the power supply. Got a new 650 Watt supply. Still had the same problem.
3 - Called ASUS back, they had me pull the processor and power up the system. The fans ran for about 10 seconds the ASUS Tech had me pull the power and said the processor was bad. I called Tiger Direct and they replaced the processor. Got the new processor, put it in the sstem and still have the same problem.
The ASUS Board calls for 6 retaining screws but the Ultra case only had 4 retaining studs in the motherboard housing. Could it be a ground issue?
I simply don't know what to do next????
  • xtimedt69 Apr 10, 2008
    A follow up that might confirm what you have told me. There were about 2 doz little carboard washers that came with the case. I installed them all of the MB mounting screws. I just found this:
    "One of the most common mistakes while installing a motherboard is using these washers on all holes. This cannot be done. The metalized holes were metalized to make the proper grounding with the system case. Actually, you probably won't find any non-metalized holes on motherboards nowadays. And if you do, almost always they don't match any hole on the chassis anyway. So, just leave these cartonboard washers behind! Don't use them!"
    Could this be the primary cause of my problem? This is my first build and there was nothing in the case or MB manual about how to mout the MB properly.
  • 28 Answers
Try taking out the mobo and ps out of its casing, lay it on a table, hook things together and power it up. I had some problems before caused by mounting studs or try insulating all stubs from the mobo. hope this will help.
Posted on Apr 10, 2008
To upgrade to a newer and better CPU processors enabling me to play more quality games Min requirement CPU type and speed Intel 2 duo or equivalent What types and models and specs please. Have at...
You should get a quad core processor, with a minimum of 3 to 4 gigs of ram, and an asus SLI or crossfire Motherboard. This and a nice 1 terrabite drive can be done for under $500.00, unfoutunatelly, thats just the way they make it. I PLAY cod4, and I run a dual core with 2 gigs of ram and a $300.00 asus MB, with twin 7900 video cards in sli. and it just about runs it, the new games are processor and ram intense, let alone video cards. I would suggest a single card if cost is a factor, you can always add a second or even a third card later. But the you don't want to be the slowest guy playing, especially if you like first person multiplayer shooters
Jun 12, 2010 | Compaq Computers & Internet
I have a p5n32-sli deluxe motherboard. Do you know if it suports the intel core 2 quad processor Q8300?
The highest you can go is a Pentium Extreme ED-965(3.73GHz, rev C1), it will not support the Core 2 series
Apr 21, 2010 | ASUS P5N32-SLI Deluxe Motherboard
I want to use two Graphics card in single motherboard
Not on this motherboard, and not with two different video cards. Your motherboard does have two PCI-E slots at x1 speed, but only one slot at x16 speed. And when you use SLI you should use two identical video cards for best results.
Mar 20, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Is it compatible
Hi playboyalive, to answer your question! (Yes) the,
XFX nForce 790i Ultra SLI Motherboard will support Intel's core i7 extreme edition multi-core 3.2GHz CPU. The board can go higher. The highest tested by XFX is Intel's 3.73 GHz multi-core CPU. You can see all supported CPU's at the XFX link below;
The above link was opened from this XFX link;
Thank you for using FixYa playboyalive!
Feb 04, 2009 | ASUS NVIDIA nForce Chipset A7N266-VM...
Msi p4n sli board
The Only CPU's that board supports are:
  • Supports 90nm LGA775 processor package
  • Supports Intel Pentium Processor Extreme Edition
  • Supports Intel Pentium D Smithfield processors
  • Supports Intel Pentium 4 / Pentium 4 Extreme Edition processors
  • Intel Hyper-Threading Technology ready
  • So sadly no I am sorry. However it does Support a P4 with HT which is still a very nice CPU
    Jan 15, 2009 | MSI P4N Diamond nVIDIA nForce4 SLI LGA775...
    Which One To Choose?
    What are you going to use the computer for? Gaming? Or Office use?
    The processor is on the high-end. It's actually overkill for normal word processing / internet surfing. It's pretty good if the computer is for gaming.
    Your motherboard is okay, but not great. Perfect for office use, but I wouldn't recommend it for gaming. It will not be very upgradable. It lacks RAID, and SLI/Crossfire support, and it only has two slots for ram, not four, making upgrading your RAM expensive.
    My suggestion for a motherboard is the Asus P5N-D:
    That one has RAID, SLI, two PCI Express ports, four ram slots, and also has a 5.1 sound card built in.
    If you do decide to upgrade your video card, I suggest an NVidia GeForce 9800 GTX. They're about $200 and quite good for gaming.
    Don't forget the other things your computer needs:
    450 watt PSU or better
    cpu fan, chassis fan
    thermal grease / silicone paste
    Dec 24, 2008 | Office Equipment & Supplies
    HI stukove2000,
    What is the 5200 stand for?
    Here is Asus approved CPU list link for the P5N-E SLI MB:
    The Corsair TWIN2X2048-6400 5-5-5-15, should work just fine on the Asus MB.
    Here is an expanded approved Qualified Venders List from Asus.
    You can also see a smaller QVL list in the manual on page 1-18 & 1-19.
    The QVL insures total compatibility with the motherboard.
    The NVIDIA GeForce 9600 GT will run just fine on the Asus MB. Just make sure your power supply is no less than 500W. A 600W or 650W is preferred.
    Here is a write up of the Asus mother board:
    Asus FAQ's of the P5N-E SLI. Good place to check questions about the board.
    Good luck stukove2000!
    Any more questions?
    Oct 08, 2008 | ASUS P5N-E SLI Motherboard
    No signal
    try taking out a gig of ram and then start computer.
    Jul 03, 2008 | ASUS P5N-E SLI Motherboard
    Insight/Decision help on new motherboard purchase.
    talk about what you want with a computer repair shop
    logically if the mobo is out of date , then you should be looking at the latest mobo and duel or quad core cpu
    next all the os ,files and folders are on the hard drive and that can be installed in any new pc and will start and run
    you have to consider this , the amount of ram has a bearing on the speed or the pc as it is used by the pc as a storage space as it moves data around as it performs the various operations
    new mobo have 2 ram slots for 4gig ram sticks but you say that you only have 1gig of ram--compare 1 against 8 and see how much easier the pc will run
    AS is said , talk with pc professionals ( not retailers ) and get the best advice before you flash the cash
    Mar 05, 2017 | ASUS P5N32-SLI Deluxe Motherboard
    Problem in my asus motherboard
    I don't understand the exact problem you are facing but hope that you are getting your problem due to the processor. If possible, try with dual core processor.
    Feb 14, 2008 | ASUS AI Lifestyle P5N32-E SLI...
    Intel Motherboard Logo
    177 people viewed this question
    Top Intel Computers & Internet Experts
    Alun Cox
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
