Question about Mustang Rzt 50" Zero Turn Riding Lawn Mower
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Posted on Jun 05, 2010
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
I have a John Deere X304 that mows unevenly.
Make sure that your gauge wheels are not running on the ground during mowing,they should only hit the ground when you engage a high spot on one side.also when you level the deck the front should be a 1/2" lower than the rear.
May 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Mandrel on right side has broken 3 times have only done 7.3 hours
It sounds like your blade is hitting the ground when you are mowing.If you have high spots in your yard the blade will cut into the ground and the mounts on the mandrel will break. Make sure the mower rake adjustment is set correctly,the mower blade should be level or a maximum of 1/4 inch lower in the front.This adjustment is done with the adjuster bolt that runs from the front of the mower to the frame under the muffler, it may have one or two rods connecting the mower at this point. Also make sure the wheels are set down far enough so they can prevent the deck from scalping,they have five different mount holes,if they are up in the highest they will not do anything.Unfortunately these mower mandrels will not take a lot of punishment and they can break when the blades contact anything like dirt or tree roots. Your ultimate action may be just to mow the grass a little higher to keep from scalping. Hope this helps.
Aug 04, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Uneven cut
1-----------tire pressure? 14 front 10 rear
start with a level mower on a level surface
2------------deck level side to side?
3------------deck level front to back? (front can be 3/8 lower than back)
4-----------deck hangers bent or hung up?
5------------blades even when pointing at each other? no more than 1/8 high or low
6------------blades dull or upside down? turned up ends go towards deck
7---------------incorrect blades for mower?
8------------deck lifting mechanism should pick up deck evenly and drop evenly?
9-----------under the deck need cleaning because it is packed with grass?
Jun 15, 2009 | Garden
Mowes unevenly. Blades don't match up.
make sure when you replaced the spindles that you used all the washers and spacer bushings back identical to the ones you took off.
Make sure your deck isnt bent for some reason where the spindles mount and or the deck itself
level the deck when its on the mower on a level suface,side to side(level) back to front the back just a little higher than the front 3/8 inch or less
proper air pressure in all 4 tires
Also you could add a washer or take away a waher to allow the blades to become level at mid point meeting?
be sure to torque the blade bolts to 35 ft.lbs also
May 31, 2009 | Husqvarna Garden
Mustang Rzt 50" Zero Turn Riding Lawn Mower Logo
572 people viewed this question
Top Mustang Garden Experts
Dennis Key
Dennis Key
Randy Schumann
Randy Schumann
Paul Sikkema
Paul Sikkema
Are you a Mustang Garden Expert? Answer questions, earn points and help others
