Question about Dometic Rooftop RV Air Conditioner
I have a carrier air v rv a/c unit in my 93 winnebago and it freezes up sometimes, how do i stop this from happening?
  • 146 Answers
Make sure the filter is clean. make sure the evap is clean. sounds that you may have a defective t-stat or unit is under charged if filter and evap are clean. or you can run a freeze stat or a higher fan speed hope this helps you
Posted on Jun 05, 2010
2008 Winnebago. We get a sewer smell if we roll down a window while driving.
A motor home will pull sewer gas from the holding tank if you cause a vacuum in the vehicle.This will happen to all units but will be more pronounced with a toilet with a bad seal on the flush valve.
Keep the door closed for the bathroom when driving and use the dash vents for outside air with all the windows closed as this will pressurize the RV with air and not allow sewer gases into the unit.
Aug 27, 2017 | Cars & Trucks
Where are the fuses located for the 2015 Itasca Sunstar 36Y?
Winnebago RV Sales ' Itasca RV Sales ' Winnebago ...
www.lichtsinn.com/new-rvs-for-sale.aspx
Location: Main ... The All New Fuel Efficient Fuse with the Ford Transit Power Stroke Diesel! .... New 2016 Itasca Solei 36G The Forza and Solei Offer Diesel Pusher ... New 2016 Itasca Sunstar LX 27N All New Upgrades to the Vista and Sunstar with ... 2016 Brave Returns with Its New Crown as the 2015 RV of the Year Title!
Sunstar ' Specifications ' Winnebago RVs
winnebagoind.com/...a.../2015/sunstar/specificatio...
Winnebago IndustriesSunstar ... Length, 27'1", 31'3", 28'3", 31', 36'5", 35'5", 37'. Exterior Height1, 12'2", 12'2", 12'2", 12'2" ..... 2015 Winnebago Industries, Inc. All Rights Reserved.
Winnebago Industrieswinnebagoind.com/resources/manuals/Winnebago IndustriesIf you are not in a position to visit your dealer, some parts are available online at www.WinnebagoOutdoor.com. Please note that you can look up part information ...Winnebago RV Sales ' Itasca RV Sales ' Winnebago ...
Jan 01, 2016 | Itasca 2015 Sunstar 36Y
Coleman mach rv central air conditioner maintenance
maintaining rv a/c is just a matter of changing filters, cleaning coils and drain lines. visual inspection of wireing for heat damage.
Jun 18, 2014 | Coleman Heating & Cooling
Carrier Air V air conditioner keeps tripping the breaker. Sometimes after two or more hours sometimes after 20 minutes
There could be a number of reasons this is happening. The unit could be on the same circuit with something else overloading the circuit. There could be a problem with the compressor that is overloading the circuit when the compressor licks on.
Regards,
Paul Hill
CT Imaging
paul@ctimaging.com
www.ctimaging.com
May 29, 2011 | Dometic Rooftop RV Air Conditioner
Stops blowing air
remove cover at ceiling so you can see in at fins and see if they are frosting up bad. If they are, I suspect during AC installation, they didn't open up ducts on discharge properly and air flow is restricted, which will cause freeze up, especially if low flow from discharge ducts. I'm assuming it is a ducted system. You may have to remove or drop down entire ceiling assy, to see if the ducts into ceiling have any blockage. Sometimes they don't cut rubber roof material back far enough, or misaligned ducts and cause restricted flow to ceiling vents, which will cause unit to frost up, which kicks out compressor until frost is melted, then compressor kicks back in and cooling happens again.
Apr 06, 2010 | Dometic Rooftop RV Air Conditioner
Compressor won't kick off
What happens when started in just fan mode? Sounds like relay stuck.
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Is an old unit worth fixing?
I recommend going with a new one. Both the coleman and the carrier are excellent and a whole lot more efficient that the 16 year old dometic.
May 01, 2009 | Dometic Rooftop RV Air Conditioner
Freezing up,stops working
It will need to be looked at, sounds like low on charge.
Sep 18, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
97 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
