Question about Watches
Ridgeway grandfather clock pendulum hook up
I have made the mistake of taking the pendulum hook-up off & now I can get it back hanging. I have a small plastic connector that has a very small flat metal "flap" and the brass metal piece with oblong slits at either end. One end is obviously to hang the pendulum. A small detail diagram or explanation would be most appreciated.
Thank you,
David
4 Suggested Answers
escapement
  • 2334 Answers
SOURCE: I inherited a grandfather clock which runs slow
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Posted on Mar 23, 2009
  • 1267 Answers
SOURCE: Re: Galleria / Metro Grandfather Clocck. W/
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Posted on Jan 01, 2011
Testimonial: "Advice was right on the money, very helpfull. Thanks so much."
aquaman987
  • 927 Answers
SOURCE: we have a seth thomas
The clock must be levelled the same as when it was previously set up. In other words, if you didn't check the level of the clock before disassembly and reassembled it and re-levelled it, it may not operate because it might not be the same.
Some clocks have different weights for the clock, chime, and hour strike. Did you mark them and install them in the same location?
My Seth Thomas has a screw to adjust the swing of the pendulum to allow proper escapement on the gear, but you have to be able to determine which way the pendulum needs to swing more to make that adjustment. I may be able to help you with this!
You may need a clock repair service.
Let me know,
Gary
Posted on May 29, 2011
The pendulum on my grandfather clock no longer works .. It is not a problem with batteries . It just no longer moves .
wind the spring up
if is battery operated replace the battery that swings the pendulum
Aug 30, 2017 | The Watches
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
    Hi Pam,
    I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
    Howard Miller Grandfather Clock
    Dec 06, 2016 | The Watches
    Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
    Jan 01, 2011 | Watches
    Coaster model 900723 grandfather clock doesn't keep time
    Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
    Nov 20, 2010 | Watches
    The pendulum stopped swinging...the clock and chimes work well
    Hi
    This clock short of needing a full service may simply be out of beat.
    Taken from my web page located at:
    http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
    "HOW TO PUT YOUR CLOCK IN BEAT"
    -Included below is a 10-second sound <snip> of a clock both in and out of beat.
    IN BEAT ////////\\\\ OUT OF BEAT
    · Turn on your sound and click on the clocks above for a sound clip.
    -One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
    -I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
    -As I'm sure we now realize a clock must be in beat but not always level to function properly.
    · Above is the verge with a slip clutch.
    · Often found on Grandfather clocks and requires only a long swing to get it in beat.
    -To get the clock on the right side in beat you would need to push the verge assembly to the left.
    -If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
    R/ David
    Nov 08, 2009 | Seiko Chiming Pendulum Tambour Mantel...
    Mar 23, 2009 | Watches
    Hi i'll try to make this short,i have a grandffather clock i took it in for repair the part thats up in the clock that holds the pendulum had broken off,that was the only problem with it.when i got the...
    After reading all the explanations I understand that your clock is not overwound or damaged and do not need any further repairs even you've been transporting (carrying) it.
    The reason it does not work is simple - your clock is out of beat and all it needs is just to put it back in beat. This is simple operation for watch/clock repairer, but would be very difficult for you without proper knowledge.
    So, my advice is: Take your clock back to that repair shop (don't forget the receipt for the previous job done). You must carry the clock with the pendulum off, but don't leave it at home. When in shop, ask to put the clock in beat. Simply say: '' My clock is out of beat. Can you correct this for me, please?''
    As this clock was repaired there some time ago (receipt is proof), this is clockmakers responsibility to put it in beat before handling back to the customer. As well as this, clockmaker should have to explain how to carry the clock and how to hook up the pendulum without disturbing the escapement. If it was not done, you have the rights to ask to fix all that.
    Do not be afraid to go and to ask them to finish their job properly. These are your consumer rights and you are not asking for any extra work to be done.
    Do not try to contact them over the phone, as it is allways better to face the person and speek directly.
    Pull your socks up and go!
    Good luck.
    Rate me, please.
    Mar 21, 2009 | Watches
    Watches Logo
    339 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
