Question about HP Compaq nc6000 Notebook
My nc6000 WILL not start up and the fan start up and stop..hard disk light on. It cycles on and on....
    Sniper:
  • 123 Answers
Hi open board and look back side board near proccessor max 1987 heat few secod then close and enjoy
Posted on Jul 07, 2010
  • Igor Mateski
    Igor Mateski Dec 21, 2010
    The Maxim 1978 repair is actually a straightforward process. I wrote a repair manual and sofar hundreds of non-tech people have repaired their laptops in just about an hour. And the repair process is free. It only takes some time, the repair manual and a $10 soldering iron with a fine tip. For more details see this posthttp://ebooksandtutorials.com/toshiba-m3...
  • 192 Answers
This is an issue with the motherboard that is a known error. There is a chip on the motherboard called a MAX1987 chip that has solder problems and comes loose. You may try some gentle pressure on teh backspace delete keys as you press the power button and see if that lets it boot... sometimes this pressure will make the solder connection reconnect TEMPORARILY.. next time you shut down or remove the pressure it will go off. Its a microsolder so the fix is not a cheap one and has to be done by certified tech. Its less expensive to replace the laptop at this point...You can google MAC1987 chip and NC6000 and it will give you details about this. I do believe there is a class action going on about it.
Posted on Jun 05, 2010
Hp nc6000 when pushing on , it will on orange light and off againg
1,check power supply.
2,check battery.
3,check the fan is trying to run.if its not it may need cleaning.
4,over heating can stop it from starting.
Jun 27, 2014 | HP Compaq nc6000 Notebook
Hp nc6000 not booting up
im sorry to say it might be cascading meaning it needs service are you good with a screw driver ? let me know
Mar 04, 2013 | HP Compaq nc6000 Notebook
Were can I buy a cheap or used 40 gig or smaller hard drive to test a HP NC6000
Hi Pat ,
go online to www.drivesolutions.com and see if they have one , if not try www.newegg.com and let me know if they dont , will advise futher......Goodluck Roy
Nov 21, 2011 | HP Compaq nc6000 Notebook
Pressing power button results in power light and hard disk light coming on for a couple of seconds cpu fan spins for same length of time then fan stops lights go off few seconds later lights come back fan...
it seems that you have damage memory card replacing may fix a problem but its better for it that you bring it to a technician in order to check much better because the motehrboard may possible be the problem.
Jun 30, 2011 | Acer Aspire 4315 Notebook
Nc6000 fan noise
your computer notebook requires a thorough de-dusting
the fan may be losing its operability, which means you will destroy the CPU if the fan stops working
i suggest you take to an authorised HP centre -- the heat sink fan may require being replaced
Oct 16, 2010 | HP Compaq nc6000 Notebook
HP Laserjet 4345MFP Backlight on printer display does not light. Counts up the 256MB memory then HP logo (3 sizes) appears (just visible) The 3 lights keep cycling on the display. Thats it, does nothing...
HP Laserjet 4345MFP
The 3 lights keep cycling on the display. Thats it, does nothing else.
It has been left overnight and continues to display the logo and cycling 3 lights.
Rear DC Cont Fan is turning. No other fans or activity with machine.
When ADF/scanner/mfp or hard disk are disconnected it does recognise this and throws an error and asks for reboot.
I have tried cold reset, nvram init. and hard disk init. but no difference.
Your thoughts?
Aug 27, 2010 | HP LaserJet 4345mfp Printer
Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Jan 31, 2010 | HP Compaq nc6000 Notebook
Non system disk or disk error
it seems that your hard disk is not getting in to Operating System. All you need is to check your drive thoroughly and reinstall OS....reason could be any thing, may be some virus has deleted system files or your drive may have develop some bad sector...
Nov 23, 2009 | HP Compaq nc6000 Notebook
My hp compaq nc6000 says nonsystem or disk error wont go further?
If you get an error message - non system or disk error and the hard disk is not detected in the BIOS, then you most likely have a faulty hard disk and chances are you have also lost all your data.
If you are desparate to recover your data, there are data recovery companies that can retrieve data from faulty hard disks but it will cost you an arm and a leg for their services.
To get you computer operational again, you will need to replace the hard disk and install Windows, all the device drivers and your programs.
Jun 02, 2009 | HP Compaq nc6000 Notebook
HP compaq nc6000 Start up problems
cpu is getting over heated because the fan cooling it is slow or not working well or stopped . go into setup , see the cpu temperature, and fan speed , if normal , neglect the above cause.
change ram , use any other working ram .
battery may not be fully charged , or old battery.
battery faulty (current leakage or less working voltage or less current storage capacity,
use mains supply , if lap top is ok on mains supply then charging section or battery is faulty.
Aug 15, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
799 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
