Question about Home
I have 2 toilets that the water supply has totally stopped or comes through weakly and sporadic at best. I have replaced the supply lines, thinking they were stopped up. When I turn on the valve the water comes out with high pressure as normal. But after I replaced the supply lines it worked just one time then quit again. I live in SC and we do not have a hard water problem. I have no idea what to do but call a plumber, which I do not want to do.
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. What the problem is is the fill valve for the toilets are getting bad and this will cause the symptoms you are having. You can pick up new toilet fill valves at the local hardware store for $10-$15 dollars to replace this should take care of the problem and they are fairly easy to replace with a few hand tools like a crescent wrench and a pair of pliers.
Posted on Jun 05, 2010
  • KEN CHESHIER Jun 05, 2010
    Are you referring to, what I would call the shut-off valves? If so, they look like they have been soldered on, I guess, because it is copper pipe. I don't feel comfortable with this type of change out. I know nothing about it. Plumbers around here are outrageous for even a small job like this.
  • Heath Moyer Jun 05, 2010
    What I am referring to is the valve in the back of the toilet which should not be soldered in. There is just a nut that goes through the bottom of the toilet and connects to the water supply line under the toilet.
How to fix a toilet flush
if you mean the toilet supply line...replace with braided toilet supply line sold at lowes...they have rubber seals at both ends and work great...good luck
Jun 14, 2014 | Home
Wand will not launch when seat is activated
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism . Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 | Home
Toilet Flushing
Is your supply valve on below the toilet? Maybe the float inside the tank is stuck in the up position? Or else the float valve is stuck. Shut off the supply valve below the toilet tank. Take off the line going to the tank. Slowly open up the valve a little does water come out? If it does, I would replace the float assembly with a new one. If there is no water, then the problem is in the plumbing going to the supply valve in your house. Good luck and please rate my answer so I get points
Jan 16, 2012 | Home
I wont to replace the sealant from around the tiolet waste pipe, what is the best way of doing this?
turn water supply off to toilet and disconnect water line from bottom of toilet tank. flush toilet to drain tank, use towel to soak up water inside that didnt flush.remove the 2 bolts ( 1 on each side of toilet), lift toilet up and move to one side and lay on it side, scrape off old wax ring from bottom of toilet, scrape off excess wax from pipe on floor. install new wax ring over drain pipe. stand toilet upright and lift straight up over drain hole and reset slowly to make sure each bolt goes through the holes on toilet, replace nuts and washers on toilet and tighten. hook water supply liune back up and turn on water.
Aug 30, 2011 | Home
Toilet Carolla takes 5 minutes to refill
Shut water off at toilet and remove supply at tank connection. Get a bucket and test the flow of water by turning valve back on. If it is good then you know the problem is the fill valve. If you can't free any debris from the bottom of fill valve, replace it. Be sure before you reconnect supply to new valve after you flush out supply into bucket.
Should flow out of supply line be weak, the valve and supply should be changed. It is always good practice to replace the supply lines after working on fixtures. Faulty supply lines can cause considerable damage to your home. Always make sure connections are nice and snug (don't over tighten)
One more note: If your home still has galvanized piping, don't waste your money on new updated, high efficiency fixtures and appliances! They will ALL give you problems from the rust and corrosion that flows through your galvanized pipes. Today everything is designed for low flow, water saving and efficiency. That means they contain restrictive components which easily become congested from rusty galvanized piping! Call a professional to replace your entire water system from the source with copper. You can then enjoy the Tank-less water heaters, electronic faucets, pull out faucets and ultra low flow toilets with far fewer problems!
Apr 23, 2011 | Villeroy & Boch Home
How do I adjust the pressure in a Kohler pressurized flush toilet
You cannot adjust the pressure on the toilet. But you can adjust the stop setting screw at the top of the float arm. If the water is coming in too fast you can adjust the valve where the toilet water line connects to the wall water supply. Closing the valve a little will slow down the flow of water and it will take a little longer to refill the toilet water tank.
Mar 06, 2011 | Kohler - Toilet - Two-piece - Highline -...
Hi, we installed the toilet two days ago and it was working fine. It has just stopped refilling. I do not see anything wrong.
there is likely a sediment build up either in the fill valve of the toilet or possibly in the supply line. You can try shutting off the water to the toilet, disconnecting the supply line from the tank and running the water into a bucket to see if the toilet is getting a water supply. If so, then you may need to replace the fill valve. For future reference:
Any time you install a new toilet or remove and reinstall a toilet, it is a good idea to flush the water lines (as described above) before replacing the fixture. This can help to remove sediment from the water lines and the Shut off valve and prevent the sediment from building up (and eventually clogging) the fill valve.
Nov 24, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
Toilet keeps running water in back tank keeps running over top of drain hole
You don't have to replace, You just need to adjust the fill valve. If you have the ball **** type just tight the top phillips screw. If you have the newer type, close the water valve under the tank and Push down a plastic ring at the bottom of the filling valve, Push down the top of the valve, lift the plastic ring to it's place and open the water valve.
Aug 01, 2010 | Toto Home
Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Jan 05, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Home Logo
18 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
