Question about Compaq tc1000 Tablet PC
Black screen 3 beeps when i turn it on - Compaq tc1000 Tablet PC
  • donprice459 Jun 05, 2010
    Are the beeps 2 long and one short beeps? if so this indicates a bad bios. If its 2 short and 1 long it indicates a memory error and you can try reseating the ram or replacing it.
    Sergeant:
  • 260 Answers
Firstly, many of your components are highly sensitive to static shock (the poke you get from touching certain things), so take care to avoid exposing computer's components to this.Try changing your RAM\Memory. Or just remove one stick and then try turning it on. If it works, then the stick you removed is causing the problem. If it still doesn't work right after removing one stick, then take out the other stick of RAM and put back in the one you took out to begin with. If you get it to start, then most likely the stick that you have removed is the cause of the problem. Try putting the sticks in different slots (one at a time) as well. Sometimes the slots go bad but not the memory. If you tested the RAM and the slots as described above and it still won't come on, then you may have some more severe problems that may require you to have the motherboard replaced in order for it to work right. Such as, the video chip is malfunctioning (this is affixed to the board and not easy to replace, the chipset is burned out (again, affixed to the motherboard), & etc. Please leave feedback about this solution. Thank you!
Posted on Jun 05, 2010
Advantech PPC-1532T Power Supply beeps
Try a search for Make and Model beep codes and light codes.
Jun 05, 2016 | Tablets & eReaders
Why did the screen turn black?
Hook it up to your pc and try to run an update, or take it in to a local repair shop.
Jul 03, 2015 | Tablets & eReaders
Last night my galaxy tab 3, 10.1 started making a consistent bell ring sound. I was not using it at the time. I picked it up and the screen was blinking and changing colour from normal to black...
Probably because you don't normally turn it off.
It got confused.
I turn my phone off about once a week - it gradually loses battery longevity because of whatever processes started running.
Feb 14, 2015 | Samsung Galaxy Tab 3 16GB 10.1-Inch White...
Zeepad 7.0 - the main screen will not turn on and it is black screen, haven't had it long. How would I fix this problem?
Press the power button for about 3 minutes.
Then turn on the tablet.
If the solution above not work, plug in the Zeepad into a PC.
Flash the firmware.
Jun 30, 2014 | Tablets & eReaders
Tablet will not come on
Leave it on charger for several hours.
Mar 24, 2014 | Motorola Mobility XOOM Android Tablet
Restart reboot
Charge from the wall for 30 minutes.
Press and HOLD the power button in the ON position for a slow count of 30 (ignore anything it does and keep the button held ON.)
Drink a cup of tea.
Touch the power button to turn on normally.
This reset will cure 99.9% of Fire problems.
Feb 10, 2014 | Amazon Kindle Fire HD
I push the power button the kocaso screen comes on and tells you injoy colorful life and then goes to a screen that said android for five or six seconds and then shuts off well it does not shut off it...
I used this link and found it had a 50/50 chance of working...
http://forums.androidcentral.com/android-4-1-4-2-4-3-jelly-bean/347622-kocaso-m1066-tablet-system-ui-has-stopped-working.html
I know it's not for your exact model, but manufacturers often have the same method of hard reset for all of their devices. Specifically:
"The button to hold down is the menu button next to the home button. With it powered on hold down tthe menu and power buttons until it goes off, then release the power button and then hold it again while holding the menu button. An android with an exclamation and triangle will appear. Tap the power button and the menu for reset or updates appears. Select factory restore and follow instructions then select reboot at next screen and you`re done."
Hope it helps u too
Chadman
Dec 27, 2013 | Kocaso M M9100 9-Inch 8 GB Tablet
Cannot Start
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Apple:
https://mediawiki.middlebury.edu/wiki/LIS/Apple_Computer_Beep_Codes
http://www.techbase.iofm.net/tips/applemac/tip1.htm
http://www.user-guides.co.uk/download/apple/applebeep/apple-beep-code.html
Jul 30, 2008 | Toshiba Portege M205-S810 Tablet PC
Compaq tc1000 Tablet PC Logo
200 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
