Question about Mackie SRM-450 System
We have top but no bass through one SRM450.
Through one SRM450, the sound is fine, but the other has no bass and only top. When vocals are passed through that seems fine? The cones seems ok and I couldn't see any loose connections. Been suggested the driver? If so, are they easy to replace by oneself?
If it needs going to a repair centre could someone suggest one? We leave near Crewe in Cheshire.
Cheers Rob
4 Suggested Answers
  • 8 Answers
SOURCE: mackie srm450 the tops on one speaker is not working
Hi There, This is quite a common problem with the Mackie SRM450's. You will find that you need to replace the diaphram on the top. This can be done by removing the 16 screws from the back of the Mackie (quite a long pain in the **** job) with a long handled cross head screw driver.
Once you have done this you should then remove the hex bolts from the back of the drive where the black and right terminals are. When this is done, pull off the cover and swap the diaphram out. With the new diaphram in place reverse the steps above but before you screw the back on, power it up carefully and check the sound is now working.
If the diaphram keeps going eg every 3 to 4 months then you will need to change the driver which is quite expensive to do. If you need spares and are based in the UK, contact LondonSpeakerShop.com who carry spare parts or can undertake the repair.
Hope this helps.
Posted on Mar 05, 2009
  • 3 Answers
SOURCE: When turned on: srm450 has no sound, but all leds
1 TAKE THE MAINS PLUG OUT
2 Unscrew the fixing screws on the back. (just the outside ones)
3 Take the back off and turn the amplifier circuit board to face you.
4 About 2" from the left and about 4" from the bottom you will see a sort of tab. pull it off gently and widen the 2 prongs slightly.
5 Put the jumper tab back on and re fit the amp.
Posted on Feb 15, 2010
  • 236 Answers
SOURCE: NEED A REPLACEMENT DRIVER FOR MY SRM450 ANY
if ur talking about your subwoofer i suggest buying one that fi in ther or try ebay for a relplacement
Posted on May 10, 2010
Where can i find the schematic for Twin Tube Classic ,it bypassing the sound but when on its channel led switches fine but have no output help is need.
If that schematic is right, you could change C34 and C35 to 1000pf, then change R34 to 220k. That would pass more mids down to around 600hz. That part of the circuit is a treble pass, and the top half is a bass pass.
Mar 02, 2015 | Motorcycles
Bass Guitar Won't Register
The mics I have seen don't have a filter... but a lot of mixers do have a 100Hz mic input filter. Check the other equipment that you are using also.
Apr 27, 2014 | M-Audio Audio Players & Recorders
How to setup a vocals
Turn gain CCW. plug microphone in, mute the channel. turn gain CW until peak LED flashes (while singing loud!) and turn gain back a little bit.
Take the channel fader down, unmute the channel. Put masters at 0dB (near maximum) and adjust the loudness with the channel fader to what you like.
EQ: it always depends on your location. Keep it flat. You might like to reduce at about 200-300 Hz. Cut the low end (Hi Pass Filter = on) or if no HiPass reduce "bass" for about 6...10dB.
ok?
Mar 29, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
My 10 w7 has vocals and bass now my vocals sounds muffled what can i do to get rid of my vocals and keep my bass???
You're going to need what's called in the audio world as a crossover. These can be as simple as a capacitor or inductor in series with the speaker, and can be as complex as you like. I'd advise using an inductor in front of the speaker, of around 8mH. This will leave bass intact, but reduce the vocals.
You can calculate your own crossovers at http://www.the12volt.com/caraudio/crosscalc.asp
There's wiring diagrams to help you.
Jan 10, 2010 | Jl Audio 12W7 Car Subwoofer
Any idea why my Mackie swa1501 bass bin has blown 2 speakers in the last 3 months? Bass Drum is the heaviest instrument going through it, but I never let it clip, I also run a fan on it which keeps it...
does your swa1501 get hot just being switched on ?
sounds like your output transistors breaking down or your dc to dc rectifier is shorting this would dumping high voltage to the speaker. I guess your speaker coil is burnt . check Q4,Q5,Q7,Q12.Q14,Q15,Q17 and Q18 these are all mosfet transistors that commonly break down..
Oct 01, 2009 | Mackie SWA1501 Subwoofer
Mackie srm450 the tops on one speaker is not working
Hope this helps.
Feb 22, 2009 | Mackie SWA1501 Subwoofer
I have a pair of Peavey Impulse 1012 4ohm amp a Peavey XR 696f was not geting enough bass ( use a Yamaha TYROS keyboard & Vocals) so i purchassed a pair of Peavey messanger Pro 15 Sub Cabs 4Ohm cant...
Hi fingers 1
There will be some overlap in bass response that you may need to tune out to tone down the boomy bits. You could tune this out with a 31 band EQ Another approach is to use a crossover or low pass filter to the subs to get some control over your bass frequencies. Another thought, if you're using the rig for stage work, how does it sound out the front. It may be standing waves created by the bass bins, moving them to different monitoring positions may also help.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 18, 2008 | Audio Players & Recorders
My mp3 player went weird on me.
Checked the EQ settings in the Settings part fo the menu, or do a factory reset in the Settings menu.
May 14, 2008 | SanDisk Sansa m230 MP3 Player
Stereo Sound
You could start by adjusting the Treble and Bass. The treble is what makes the high notes more nodicable, so if you turn the Treble up you should be able to hear more vocals. The Bass is what makes the low notes more nodicable, so if you turn the bass down you should be able to stop the shaking which I'm guessing is the low notes. On the other hand if you have an aftermarket radio then there might be a Mute or ATT button. Theses are for instant quiet, just repress the Mute or ATT button and it should be fine. I hope I could help.
-Andrew Hawkins
Apr 09, 2008 | Panasonic CQ-C1100U CD Player
Amp
I think it's a bad switch
Jul 07, 2007 | Pyle Blue Wave PLA2740 Car Audio Amplifier
Mackie SRM-450 System Logo
144 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
