Question about Dryers
I have a Kenmore model 41792702200, it was squeaking very bad so I researched via the internet and figure it is probably a bad bearing. I have the dryer all torn down but can't remove the drum, how do I get the drum off?
    President:
  • 1,554 Answers
The top cover and the front panel must be removed first to remove the drum. Once these parts are removed, release the drum belt from the idler pulley then pull the drum out through the front. You don't have to accept or reject and rate this post to add information or post your comments and follow-up questions.
Posted on Jun 05, 2010
Kenmore stackable dryer squeaks So loud. How can I fix this.
A model number would greatly help, the dryer is most likely made by Frigidaire for Kenmore, your squeal is probably from a dried our drum support bearing at the rear center of the drum. If this is the case, an experienced repairman is advised to make this repair. Pleazer Appliance...
May 18, 2014 | Dryers
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Kenmore clothes dryer squeaks loud to get going
Sounds like a bearing or the drive belt. Try turning the empty drum by hand. If it sounds normal you probably just need to replace the belt. If it make strange sounds when you turn it by hand then its probably the bearing.
The belt isn't a big deal but a bearing probably is.
Feb 16, 2013 | Dryers
Whirlpool model 110.88752792 dryer runs but does not heat
Concerning the Kenmore 11088752792 model where the dryer spins but does not heat. I had that problem a few years ago with the same model.
I replaced the fuse (part No. 3399849 about $10.00) and the thermostat (part no 3398128 about $25.00). Dryer worked fine the first try.
FYI. Today, I'm searching for what makes the dryer squeak when I came across your issue (though 6 months since you posted, but I figure there are other Kenmore stack-able owners out there searching for a fix). I haven't taken the dryer apart yet but have ordered the dryer belt, rollers, pulley (a package deal with RepairClinic) and the felt bearing/seal. May as well do a full replacement of the likely components that are causing the squeaks and not spend any more time going through trial and error repairs.
If you haven't already, the dogs on your agitator are probably due for replacement as well. RepairClinic has an agitator package deal with replacement dogs and seals.
Jul 14, 2011 | Kenmore 94802 Front Load Stacked Washer /...
Squeaks & takes longer to dry
The squeaks are normally a sign of dry drum roller bearings. You either need to lube the shaft and bearing of the roller or replace the roller completely.
The drying problem sounds like you have a least one bad thermostat, need to check and replace the faulty thermostat
Sep 22, 2009 | Kenmore Dryers
Need to know how to remove the motor on a Series 80 elec dryer.
The motor should be removable from the back and will require removal of the back panel. The bearings on these motors are brass "bushing" type, not ball bearing. You may have some success oiling them with a straight weight oil like 30w, but it may not last too long. Once the bushings start to go, it's usually time to replace the motor. You should be able to get another motor for the unit from Sears Parts Direct. I applaud your efforts!
Mar 28, 2009 | Kenmore Dryers
Kenmore washer/dryer combo (Model# 41792702200)
I cannot remove the dryer drum from my Kenmore washer/dryer combo in order to remove the bearing, how do I do this???
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Dryer Model 970-C82062-10
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Jan 25, 2009 | Kenmore Dryers
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Dryers Logo
Top Dryers Experts
