Question about Video Game Consoles & Games
I need yaimer yahoo pool aimer serial number yahoo aimer is a software,, thorugh we can play game on yahoo pool with good aim...
2 Suggested Answers
key-kun
  • 83 Answers
SOURCE: i have the new dawn of war 2 game but with no serial number
Its dawn of war two yeah?
not like the pic shows,
I got a brilliant CD Key Generator.
email me at key-kun@hotmail.com and ill send you the link
Posted on May 02, 2010
How do you say je taime in English?
its spelt right n pronounced je tem
Jul 21, 2014 | Je e t'aime Je e taime
I need a serial number for the ncis pc game
I have download the NCIS game but i dont have the Serial Number to play the game can you help me.
Dec 29, 2011 | Gamehouse NCIS The TV Game
How to adjust headlights, 05 ford 500
Headlamp Adjustment
Headlamp Aiming
  1. The headlamp aiming procedure depends on what type of beam pattern the headlamp is equipped with. Vehicles may come equipped with visual optical left (VOL), visual optical right (VOR) or SAE only (includes sealed beam type) headlamps. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is 1 of the following:
    • SAE
    • VOL and SAE
    • VOR and SAE
  1. Once the headlamp beam pattern is identified, aim the headlamps using 1 of the following methods as applicable.
    • Photometric aimers can aim VOL-, VOR- and SAE-type headlamps only. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim VOL-, VOR- and SAE-type headlamps only.
    • Mechanical aimers cannot be used with VOR- or VOL-type headlamps. Aerodynamic lamps that can be aimed mechanically have 3 nibs molded into the lens of the lamp.
    • Photometric Aiming
      1. For the photometric aiming procedure, refer to the appropriate photometric headlamp aimer instruction manual.
      Screen Method Aiming
      All headlamp types NOTE: Horizontal aim is not necessary for VOL or VOR headlamps.
      NOTE: Consult your state vehicle inspection manual for recommended tolerance ranges for visual aiming.
      NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
      1. Before starting headlamp adjustment:
        • check the tire inflation.
        • check that no other load is in the vehicle other than a half tank of fuel.
        • check that the headlamps are clean.
        • check for correct headlamp operation.
        • check that the vehicle is on level ground.
        • if the vehicle is equipped with air suspension, make sure that the switch is on.
      1. NOTE: The vertical wall or screen must be a minimum of 2.4-m (8-ft) wide.
        Park the vehicle on a level surface approximately 7.6-m (25-ft) from the vertical wall or screen directly in front of it.
      1. NOTE: The center of the lamp is marked either on the lens (circle, crosshair or other mark) or on the bulb shield internal to the lamp (crosshair or other mark).
        Mark a horizontal reference line on the vertical wall or screen.
        1. Measure the center of the headlamp height to ground and record the measurement.
        1. Make a 2.4-meter (8-ft) horizontal mark (using masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
      1. NOTE: This procedure should be done in a dark environment to effectively see the headlamp beam pattern.
        Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
      1. NOTE: For SAE-type headlamps, the appearance of the beam pattern may vary between vehicles.
        On the wall or screen, locate the high intensity area of the beam pattern. Place the top edge of the high intensity zone even with the horizontal reference line.
      2. SAE-type headlamps
        1. In addition to the horizontal line marked in Step 3, a pair of vertical lines must be marked at the center line of the headlamps on the wall or screen.
          1. Mark the center line of the vehicle on the wall or screen.
          1. Measure from the center of the headlamp to the center line of the vehicle.
          1. Make two 1.5-meter (5-ft) vertical marks (using masking tape) on the wall or screen at the same distance from the vehicle center line as previously recorded.
        1. On the wall or screen, locate the high intensity area of the beam pattern. Place the left edge of the high intensity zone even with the vertical line corresponding to the headlamp being adjusted.
How To Aim Headlights EricTheCarGuy
Jan 15, 2011 | 2005 Ford Five Hundred
I have a 2000 ford mustang can you adjust the headlights and how do you do it
SECTION 417-01: Exterior Lighting 2000 Mustang Workshop Manual GENERAL PROCEDURES Procedure revision date: 12/09/2002 Headlamp Adjustment Headlamp Aiming
  1. The headlamp aiming procedure depends on the type of beam pattern the headlamp is equipped with. Vehicles may come equipped with visual optical right (VOR), visual optical left (VOL), or SAE only (includes sealed beam type) headlamps. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is one of the following:
    • SAE
    • VOR or SAE
    • VOL or SAE
  1. Once the headlamp beam pattern is identified, aim the headlamps using one of the following methods as applicable.
    • Photometric aimers can aim SAE, VOR and VOL type headlamps. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim SAE, VOR and VOL type headlamps.
    • Mechanical aimers can be used only with SAE type headlamps. Lamps that can be aimed mechanically will have three nibs molded into the lens of the lamp.
Photometric Aiming
All headlamp types
NOTE: Horizontal aim is not necessary for VOR or VOL headlamps.
    • Check the tire inflation.
    • Check that no other load is in the vehicle other than a half tank of fuel.
    • Check that the headlamps are clean.
    • Check for correct headlamp operation.
    • Check that the vehicle is on level ground.
    • If the vehicle is equipped with air suspension, make sure that the switch is on.
  1. NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
    Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
  1. NOTE: The center of the lamp is marked by a 3 mm (0.12 in) circle on the headlamp lens.
    1. Measure the center of the headlamp height to ground and record.
    1. Make a 2.4 meter (8 foot) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: For SAE type headlamps, the appearance of the beam pattern may vary between vehicles.
VOR type headlamps
  1. NOTE: The appearance of the VOR beam pattern may vary between vehicles.
    Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam will need to be adjusted.
VOL type headlamps
  1. For VOL type headlamps, there will be a distinct cutoff in the left portion of the beam pattern. The edge of this cutoff should be positioned 50.2 mm (2 in) below the horizontal reference line.
    1. Horizontal reference line.
    1. Top edge of the beam pattern.
    1. High intensity zone.
Mechanical Aiming
  1. For the mechanical aiming procedure, refer to the appropriate mechanical headlamp aimer instruction manual.
2010&c18=modelyear&c20=n304745&c35=wsm%2cheadlamp%20adjustment%2csyb%2c417-01%2cgeneral%20procedures&pid=wsm%2ctitle%20page%202000%20mustang%2csyb&pidt=1&oid=functiononclick%28%29%7bdosearch%28%29%3b%7d&oidt=2&ot=img&oi=27&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=582&ct=lan&hp=n&[aqe]
Apr 07, 2010 | 2000 Ford Mustang
Virtual Pool2 is not compatible with win 7. Is
how play gta4.i dont have serial number???please help me
Mar 16, 2010 | Interplay Productions Virtual Pool 2 for...
Need to adjusted headlights how do you do it on a
there are little screws with hex head or torz head. one for lateral, one for up/down.
shine on garage door.
Headlamp Aiming
  1. The headlamp aiming procedure depends on what type of beam pattern the headlamp is equipped with. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is one of the following:
    • SAE
    • VOL
    • VOR
    • Photometric aimers can aim SAE, VOL and VOR type headlamps. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim SAE, VOL and VOR type headlamps.
    • Mechanical aimers can only be used with SAE type headlamps. Lamps that can be aimed mechanically will have three nibs molded into the lens of the lamp.
Photometric Aiming
All headlamp types
    1. Make a 2.4 meters (8 feet) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
VOR type headlamps
VOL type headlamps
Mechanical Aiming
Jan 18, 2010 | 2000 Mercury Grand Marquis
Nero6.6.1.4 serial number
1A23-5072-9041-6736-3332-2338
1A23-1063-7019-5145-4403-3265
1A23-4018-7027-5654-0171-1596
good luck.
May 11, 2009 | Ahead Software Nero 6.0 (60045) for PC
Aiming headlights
if you don't see little bubble levels near the headlight under the hood then you must have them aligned with an optical aimer, if you do have the bubble guages then park the car on a level pad and set the bubbles to center with the little adjusting screws near them.
Nov 05, 2008 | 2002 Toyota MR2 Spyder
No sound on yahoo messenger games
its the game try looking around for the sound option box there should be one if not i dont think there is one on yahoo messenger built in pool
but why would u need sounds in pool anyway all u hear is a click noise who cares
Sep 26, 2008 | Compaq Presario 5000 PC Desktop
Video Game Consoles & Games Logo
769 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
