Question about Intel D845GVSR Motherboard
Chip Level Guys needed? I know of a guy who can make junk hardware alive: I gave him a toasted RAM, he tested using his multimeter and replaced a resistor, it began working. I gave him a HDD that would show up on BIOS but wouldn't read, he did something to interface card and it worked. I gave him a monitor with alignment issues he... and so on. Whenever I try to find a book detailing Chip Level Troubleshooting, I get repair manuals of a particular model/make PC component that are very tedious and non-generic. Please suggest a good book which details generic chip level troubleshooting for PC components like HDD, CRTs, MainBoards and other components which is simple Step-by-Step kind and deals with most if not all components. Thanks in advance, AskQ.
    Genius:
  • 1,027 Answers
There really arn't many that help in that area. One that I found in a major book store is: "PC Repair Bench Book" by Ron Gilster ISBN 0-7645-2578-6 from Wiley Publishing. That one is a 'generic' help guide. Unfortunatly, many are out of print, but that can give you a start in searches.
Posted on Jun 05, 2010
Fixya guys give wrong info like Auto mechanics.Most of the time theirs nothing wrong with your car. Like if Battery dead. Just recharge it ! You don't need new battery like Stu*** fixya guys say!!
Sorry but batteries don't just go dead for no reason ! A parasitic draw on the electrical system ,do you know what that is ? Do you know what control modules are ? PCM/ECM , BCM , EBCM , SRS , HVAC etc .. After key is switched off these modules power down (go SLEEP) , sometimes they don't . This causes an electrical drain on the system causing a dead battery . I will admit some guys on here do jump the gun a bit . Never I repeat NEVER replace anything on a vehicle without testing . Load test the battery first .
Mar 16, 2016 | Cars & Trucks
Restricted performance mode xf
Did you actually check for voltage with a test light or digital multimeter? Did you check the ground circuit? I don't know much about your particular vehicle, but, the basics are the same, voltage and ground.
The diagram doesn't say aux, but, the basics are there.
Feb 11, 2014 | 2009 Jaguar XF Supercharged
Itower speaker system won't turn on
Hi Peter,
1.power switch.
2.power transformer .
3.fuse (if have)
4.rectifier (dc cct)
5.input voltage to transformer.220v ac or 110v ac.
6.output voltage from transformer .(low ac value 12v 9v 7.5v....)
7.voltage in smoothing capacitor.according to transformer voltage 12v,7.5v etc....
power switch and switching power.
regards,
nuwan
Jan 27, 2014 | Apple Soundlogic Itower Speaker Works W/...
Pls guys i need your help my zinox laptop would on but wont display anything ,initially i taught i was the screen but one day i on it down for some mins and it display and wen d battery went down i charge...
Computer does not boot up
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
May 12, 2013 | Computers & Internet
No video from d9ooTBAT-12 Alienware Laptop
Give more descriptions--does it display the DOS boot up screen (IT guys call it POST-power on self test)? This is the black screen that displays some information about the computer's hardware, and may give you F key options or DEL for setup, etc. Does it beep? Try using a VGA cable and connect it to an external monitor? Remove the RAM and try booting and see what it does? or Reseat the RAM chips located under the laptop.
Sep 10, 2011 | Dell Computers & Internet
No bus
No bus is a serious problem with the Stratus.. Most cases it's the ECM.. You need to check all your fuses.. Disconnect the battery and let it sit about an hour and turn the key on and off before reconnecting.
Use the remote key lock and lock the doors and unlock with the remote key and try to start..
Probably none of this will work... You'll probably need a ECM.. If it has a security system, the junk yard ones won't work.. It'll fire up and then go dead.. Then the ECM is toast. Seems the Dodge guys figured out a way to defeat anybody working on it.
There is hope. There is a ECM repair place in south Florida that knows how to make the ECM work without having to take it to the dealer. They specialize in Dodge ECM's
Jan 17, 2011 | 2000 Dodge Stratus
AKAI MLT168A Power Supply
If I give you the values of Z3, Z4 and Z5, would you return the favor by telling me what are the values for R104, R106, R107 and C17?
I have posted this request 5 times for 2 months and no body gave me an answer. Would you be willing to work with me? E-mail me s69joe@hotmail.com and use MLT168A-fixya as subject
Thanks
Sep 27, 2008 | Akai LCT2715 27 in. LCD Television
Refill toner konic minolta 1350w
hello
i just installed a new cartridge , but i still have vertical streaks on my sheets
do i need to get the toner clean , and what product do i use ?
thanks again for you time / help
Mar 19, 2008 | Konica Minolta PagePro 1350W Laser Printer
Ever since I replace my motherboard to MS9087c it keep freezing
well the problem might be with the heat-stinker ur using for ur processor to remain cool it might not working properly just changed it n i am sure da problem wud be solved!
Nov 10, 2007 | Matsonic MS9087C Motherboard
Intel D845GVSR Motherboard Logo
106 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
