Question about Sony CDX-L400X CD Player
No sound from speakers
Everything works apart from the speakers.... cd looks likes its playing but no sound the radio tunes to stations but again no sound
All help will be gratefully accepted thanks in advance
  • 4 more comments
  • allyt01 Apr 10, 2008
    whats a hard reset?? I've pressed the reset button on it. there is no sound on any of it. sometime theres a pop noise for 1 second when I turn it on at first
    don't have a seperate amp connected. everything is standard, it was working before but the head unit face has been off for a long time because theres been work getting done on the car. the battery has been connected and disconnected lots of times. the fuse hasn't blown at the back either, I checked that. all wires look ok and there is no obvious loose wires
    do you know what the price roughly would be to fix it? Am I better off getting a new one?
    whats a hard reset then?? i came here looking for solution and all i seem to have got is problems lol
  • allyt01 Apr 11, 2008
    CDX-L400X CD Player sony xplod
  • allyt01 Apr 17, 2008
    have you not all the comments??
  • 2,322 Answers
It looks like the audio amplifier could be defective.
I would suggest to get a technician since this devices are not very easy to disassemble to replace the IC.
Posted on Apr 10, 2008
  • 1 more comment
  • Jaime Hernandez Apr 10, 2008
    Do you have a separate amplifier connected to this CD player?
    The pop noise you hear is the power that circulates through the speakers when the device powers up.
    I would say if the fix cost 1/3 of the price of your CD player, still a good price. If the repair will cost you more, it might be better to buy another one.
  • Jaime Hernandez Apr 17, 2008
    Try pressing the DSPL button to cancel a feature call ATT on the front panel and see if that works.
    Genius:
  • 1,142 Answers
Would like to know that are u getting no sound only while playing cd's or the problem is that u are not bale to hear even the windows login\logoff sound
  • 2 more comments
  • Maanita Chadha
    Maanita Chadha Apr 10, 2008
    is it that no sound comes from any channel
  • Maanita Chadha
    have u tried a hard reset ??
    plz explain bit more so that i can provide u a better solution
  • Maanita Chadha
    Maanita Chadha Apr 11, 2008
    Hey Pal if u can provide me the make and the model of the car stereo which you are talking about, i will surely provide you the resolution
    cheers!!!!!
  • Maanita Chadha
    Maanita Chadha Apr 17, 2008
    Please check the antenna is connected or not if not the it will not tune up any stations.
My Sony CDX-M610 will play radio but not CDs
THE CDX-M610 LIKE ALL OF THE CDX-M630, M800, M850MP SHOULD ALL SIMPLY START TO PLAY THE CD WHEN INSERTED. BECAUSE YOU ARE ABLE TO TUNE RADIO STATIONS AND HEAR THEM PLAY SHOWS THAT YOU HAVE EVERYTHING IN PLACE AND ARE DOING EVERYTHING RIGHT. SO IF IT IS NOT PLAYING, THEN IT WILL NEED TO BE SERVICED. AS FOR THE REMOTE, IT IS NOT REQUIRED OF ANY OF THE CD PLAYERS IN ORDER TO PLAY CD OR TUNE RADIO STATIONS. RATHER THAN INVEST IN REPAIRING, I WOULD LOOK FOR ANOTHER MODEL ON EBAY USED AS IT WILL PROBABLY GO PRETTY CHEAP. ALSO HAVE CHANCE TO GET A HIGHER MODEL LIKE THE ONES I MENTIONED ABOVE. I HAVE SEVERAL OF EACH IN MY COLLECTION AND THERE ARE NICE PLAYERS. OK. HOPE THIS HELPS.....V
Jan 04, 2017 | Sony CDX-M610 CD Player
Radio no longer has any volume: Resets suggested dont work. How to pull this sucker apart?
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter follow the steps below.
Turn the unit on
Turn the volume down to minimum, 00, volume
Press and hold power for 10 seconds until volume numbers flash
Turn the volume back up to 50 (max volume)
Press power again to verify new max volume position
Jun 03, 2015 | Boston Acoustics Horizon Solo Clock Radio
2006 infiniti m35 no sound from speakers
Yes an amp that is not working could cause this to happen. But I would check it out a little more because when you did the speaker test and all the speakers worked then that doesn't sound right. Find the amp and it could be just a loose connection that is giving you all these problems. Good Luck
Mar 12, 2014 | Car Audio & Video
Just performed a new install on this. Everything powers up and works fine, including the power antenna. Followed set up instructions including selecting speaker output but no sound at all? Radio station...
It sounds like you may have the negative and positive polarity wrong usually to the speakers. I suggest to use black for negative and red for positive so that each speaker is correct. Speaker wire is good but for self installs its a common mistake.
Oct 23, 2013 | Kenwood KDC-HD455U
I have tried everthing i can to get the dvd player to be heard over the car speakers but can only get the sound on the head phones. Are these Rosen A7 dvd players designed to play over the radio or not?...
Put a cd in the dvd player then tune to the channel and it should work, then try a dvd.
When dvd player does not boot up and display the Kia logo, try moving the door as the hinge turns on the screen and sometimes the connection in the hinge can play up a bit.
Apr 13, 2011 | Rosen A7 Car DVD Player
2008 Nissan Altima radio (AM/FM/CD) does not respond to buttons except on/off volume. It was playing an FM station (cant't tune/scan) and now plays a CD that won't eject.
2008 Altima radio-the sound just quit working. Everything else seems to be OK. I can change the radio stations, but no sound. Is there a fuse that could be bad?
Nov 24, 2009 | 2008 Nissan Altima
Radio
Hello george_nutti,
The model number you posted is for a center channel speaker which has no controls, and not knowing the exact model number it's difficult to be specific.
Some Kenwood KDC models allow you to select one of 3 "tuning modes", 1) AUTO1 - Automatic search for stations; 2) AUTO2 - Search Preset stations; 3) MANUAL - Normal manual tuning control. If your Kenwood is one of these models, you need to set the tuning mode to MANUAL. For Kenwood Excelon HD receivers, direct access tuning is done by using the included remote. 1) Press DIRECT button on the remote; 2) Press number buttons to enter desired channel number; 3) Press DIRECT button again to exit direct tuning.
Hope this helps.
Sep 08, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
Brookstone Wireless Rechargeable Speakers with auto-tuning
its probably the interference with the routers. try getting internet by bypassing the router. much easier sound quality.
Jun 12, 2008 | Brookstone Outdoor Wireless Speaker...
Tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Dec 27, 2007 | Audio Players & Recorders
Sony CDX-L400X CD Player Logo
170 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
