Question about Samsung SCX-4216F All-In-One Laser Printer
SCX-4216 "No Paper" message
I have a full paper tray (and have tried it half-full), but the display reads "[no paper] Add Paper". I've taken the tray out repeatedly, ensured that all the guides are tight, but no luck. It will print single sheets that I feed through the single sheet slot, but not from the tray.
  • 2 more comments
  • Anonymous Jun 06, 2008
    I have the same problem, the paper tray is full yet the display constantly says there is no paper. Have also tried to only half fill the tray, turning the printer on and off all to no avail.
  • kerrychrys Jun 27, 2008
    I have tried different levels of paper, have checked that all flat, nicely stacked, etc. Turned the printer off then on. For some reason it seems that printer is not detecting the paper. Time to buy a new printer?
  • guardiancare Sep 19, 2008
    I have the same problem that the display says that there is no paper in the machine yet I have attempted to print with half of a tray and a full tray. I tried to flip the paper upside down and backwards to no avail.
    I ended up feeding a few pieces of paper thought the feeder and after a few sheets (10 to 15) the printer recognized the paper in the tray and continued printing.
  • Anonymous Dec 02, 2008
    Printer says no paper even when it has paper.
I've had this happen to my scx4521f a few times. I think I had too much paper in it. Or maybe it was poorly loaded paper. Take the stack of paper out and turn it around so you have no dings or dents on the inward facing side. You need to make sure that the paper is stacked evenly. Good luck. And now I will post my problem.
Posted on Jun 14, 2008
"add paper" message but full of paper
jaha par paper laga rakhe waha ki paper tray select karo
Aug 01, 2012 | Toshiba 2060 Copier
I have a samsung SCX 4824 FN printer- message
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Jan 19, 2010 | Office Equipment & Supplies
Paper tray full and message no paper add paper flashing
Your paper sensor is damaged, replace your paper sensor.
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 23, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Problem for Samsung SCX-4216F All-In-One Laser Printer No paper message, yet the paper tray is full
chek paper sensor, he is a small plastic peiece near thne paper feed roller. you can found it when you remove tray and look at the bottom side of ptinter. Sensor must be able to move free (up and down)
Oct 08, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Panasonic Workio 1810 - Tray 1 Add Paper Message
First why is the tray set for size A4 Paper. That is metric size paper for oversea locations. Should be set for 81/2"x11, or 11"x81/2.. is there any paper stuck behind the 1st tray? are the guides that hold the paper in place in the draw snug up aganist the paper in the draw. is the bottom sheet of paper in the stack/rem of paper benton the edge. All sheets of paper in the draw must be flat.
Jul 20, 2009 | Panasonic Office Equipment & Supplies
Pinter tray is showing as empty when full.
Hi
I had the same problem, what you need to do is ruffle up the paper abit dont put it in so neat , for some reason the sensors are notrecongnising the paper (dont know why) i have used the same before...
good luck
Abdullah
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Printer displays 'No paper - Add paper'
That is if the lens present in your printer ( above the paper Tray) must have filled with dust. just clean the lens and try it out.
Aug 11, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Check this link it has a step by step solution that you can try http://www.fixya.com/support/t216317-no_paper_error
Hope that helps..........
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
"Out of paper" error message
i would try clening the paper feed tires and roller and if that dose not work i woudl replace them.also pull the paper tray out adn look in top of the printer where the paper feeds out of the tray to see if the is a peice paper is blocking the sensor that reads that the printer has paper.
Apr 03, 2008 | HP Photosmart 3210 Printer
[no paper] in SCX-4200
there 9is a paer sensor which senses when there r papers ,prob might b that either it is not functioning or on of the sensor is depressed
Jul 29, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
212 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
