Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Motor will start but doesnt stay running
It seem if it is starving for gas . i changed the fuel filter and air filter also blew out the fuel lines this is a older model i bought around 1996 or 97 . it has a electrical wire going to the bottom of the carb ?
Did you clean the gas tank cap? That fixed mine. Comes apart in 3 pieces.
Posted on Jun 06, 2010
Chainsaw wont stay running Runs 30sec to about 1 1/2 min seems to be starved for fuel
Initial carb setting is 1 full turn out on both low and high side and retry. If no difference, then turn the low side out and additional 1/4 to 1/2 turn CCW. If that makes no difference, then it's time for a carburetor rebuild.
Feb 24, 2015 | Garden
Changed the fuel pump &fuel filter and the fuel relay starts up wont stay running.
Check the air filter and the duct that goes to it. starving a car for air is as bad as starving it for fuel.
Jun 13, 2014 | Cars & Trucks
Choke Why does does fuel shut off right after I open up manual choke, /198 C-10/350 Chevy with a 1400 series Edelbrock carb , my main complaint was A/F mixtures , when in 1st gear hesitation/ stuble /...
you realise this is posted in motorcycles?? anyway fuel doesnt shut off more air is intaked when you open the choke hence causing a leaner mixture maybe your main jets are clogged. i think they are removeable. do you have any manauls for the carb?? if not try to find some more information on it.
May 12, 2017 | Motorcycles
Ford E350 fires but won't continue to run. Seems to be starved for fuel.
I am assuming the engine is gas..
Have you checked base fuel pressure with a gauge ?
Does the engine use a MAF sensor in the air intake ?
Apr 09, 2013 | Ford E-150 Cars & Trucks
Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Runs 5 mins. and quits seems to be out of gas. cuts out until it
Sounds like you have a stuck float in the carburetor. Sometimes a piece of grit will get in there. You can remove the float bowel location bottom of carburetor , turn off fuel first or pinch line shut needle nose vise grips do a good job for this. First lightly tap the float and blow though fuel line. If it sat a long time might just be a little varnish from old fuel. If still can not blow though line remove float and if need replace needle and seat.
May 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I own the 10685, mowed 6 times this year and on the 7th out of nowhere it developed a problem. Primed as usual, starts, runs about 30 seconds, quits. If I catch it in time I can hit the primer again and it...
Just a suggestion O.K?
Carefully check the small fuel lines. To and from the bulb. Make sure the bulb fills with gas.( at least two thirds full. ) There is a small fuel filter on the end of a small fuel line in the tank. A small hook of stiff wire will dig that out. Good luck !!!!
May 14, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
No/Low Fuel Pressure after replacing in-tank fuel pump & filter
Need to have the fuel pressure checked at fuel rail to know for sure if there is a fuel pressure problem for sure. There may be a in line filter as well, you can also do a check of the pressure regulator by pulling the vacuum line off of it then try starting the car with it off and see if it runs, if it does the regulator is bad, but IF it doesnt run doesnt necessarly mean it is good, a lot of fuel filters have a bypass wich allows the gas to bypass the filter when it is full bad thing is the debris can then plug the injectors causing problems, or there could be a loss of signal to tell the injectors to give fuel to the cylinders from an electrical or a sensor failure. So it is best to test the pressure to know for sure if it is in the fuel line or the injectors if it is truly being starved of gas. hope this helps
Apr 13, 2010 | Hyundai Motor 2003 Sonata
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
My caravan stopped running when i turned a corner. the van cranks but seems like its starving for gas. i sprayed starting fluid through air intake and it will start gas doesnt seem to be going to...
I think the fuel filter is inside the tank, and when they get clogged it is time to replace the fule pump. thy not to drive the vehicle around so close to empty.
Oct 19, 2009 | 1999 Dodge Caravan
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
101 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
