Question about Kenmore Washing Machines
Door locked model he 2t - Kenmore Washing Machines
F22 error code means that the door lock mechanism is not functioning and the wiring has probably come loose. Open the top (2 screws in back) and you'll probably find (as we have now 3 times) that the wires and door lock mechanism have come loose (no wonder with the vibrations of the spinning drum!). Plug it back in yourself and save the annoying repair bill! Make sure to unplug the washer before you attempt it...
Posted on Jul 02, 2010
Kenmore Door Jam
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Jul 06, 2008 | Kenmore 44832 Front Load Washer
I have a kenmore HE 2t washing machine. It is leaking out the bottom of the front loading door, especially on the delicate cycle. The gasket and door seem to be fine.
Do check the rubber door seal again.
Often you can get a few months' extra life out of the door seal by removing it and replacing it upside down, if it will fit.
Feb 11, 2015 | Kenmore Washing Machines
Odysseyware answer key
Just carry out the indicated additions and subtractions.
5t+t-7t+3t = 2t
-3-5+8 = 0
The result is 2t+0 or simply 2t
Feb 28, 2014 | Office Equipment & Supplies
5t+(t-3)-[(7t+5)-(8-3t)]
5t+t-7t+3t = 2t
-3-5+8 = 0
Kenmore HE 2t washer is leaking from the front
thats called a bellow. from a scale of 1-10 id say a 9. front assy of washer needs to come apart to be able to get to gasket rear. that is why it leaking just a small tear or bend on the gasket bye the door will cause it to leak. ive done about 50 of those and it takes me about 1 hr. good luck .if u need furthur assistance let us know. thank you.
Oct 07, 2009 | Kenmore Washing Machines
Door on GE JTP18 oven does not close tightly.
Not sure if this link will work, but give this a try
http://claimworks.servicepower.com/mfgltr/I404/RC/Wall%20Oven%20Repair%2011-4.pdf
There is a recall on the oven door for a few models
Safety Recall GE Wall Oven Models Included in the Recall
Brand Model Numbers Must Begin With Serial Numbers Must Begin With GE® and GE Profile™ JCT915, JT912, JT915, JT952, JT955, JT965, JT980*, JTP20, JTP25, JTP28, JTP48, JTP50, JTP86 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF GE Monogram® ZET3058, ZET938, ZET958 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF Kenmore
(All model numbers start with 911) 4771, 4775, 4781, 4904, 4905, 4923*
* Lower Oven Only 2T, 2V, 2Z, 3A, 3D, 3F, 3G, 3H, 3L, 3M, 3R, 3S, 3T, 3V, 3Z
and that link shows the door and hinge. Recall info at
http://www.geappliances.com/products/recall/wall_oven_08/
May 31, 2009 | GE JTP20 Electric Single Oven
*** follow up problem
Hi again,
Hard starting could be caused by:
  • vacuum leak (specially since you can not adjust idle lower). Was the original 2T oil injector to the carb plugged?
  • 2T oil pooling at the bottom/bowl of the carb (specially since you are using pre-mix);
  • the sparkplugs fouls fast/easily. You can try changing the plugs in the morning before you start.
Imagine the scenario of the original arrangement of the carb & 2T oil (not pre-mix); on initial start/early morning, gasoline would be drawn in first without much 2T. This ensures that the engine fires. When it is already running, that would be the only time the oil pump will work and therefore inject the 2T to the carb to mix with the fuel drawn inside the combustion chamber. With pre-mix, the first gasoline used (inside the carb's bowl) has already oil mixed.
Good luck and thank you for using FixYa.
Jan 31, 2009 | 2005 Honda Dio
I need a user manual for a Westinghouse security system - model XL4600SM
Here is the link to the Westinghouse XL-2T Security System Owners Manual -model #XL4600SM:
www.adt.com.mx/incjs/download.asp?glb_cod_nodo=20070118085923&hdd_nom_archivo=fbii-xl-2t-user.pdf
This link will automatically ask to download manual to your computer.
6242511.jpgDont forget to rate!!!
Jan 03, 2009 | Televison & Video
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Squire
