Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT 6252 dishwasher will not work
I turned it on and a few minutes in to the cycle there was a burning smell (electrical). The power light on the control panel is off. I replaced the fuse but this has not fixed the problem. I have removed the covers but there is no sign of anything having burnt. When i press the start button there is a clicking sound but the washer will not start. What is likely to be the problem?
  • Zanussi Master
  • 909 Answers
Almost certainly the control board has gone faulty. The favorite is the transformer burns or the thyristor gets very hot and burns due to a bad solder joint. Quickest no noncense repair is to bite the bullet and install a new board.
Posted on Jun 05, 2010
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
MY DISHWASHER WONT START ITS CYCLE THERE IS VIBRATION IN THE BOTTOM AND NO WATER ENTERING
The vibration is probably the electric valve that opens and closes the water supply valve on the dishwasher underside. If you have set a few dishwashers before, you may be able to remove yours to access the solenoid valve on the bottom of your dishwasher and replace this part for a few bucks, then reset the dishwasher and test. The buzz/no water symptom points directly to this part being your problem. DO NOT work on your dishwasher without some previous knowledge of dishwashers in general. The electrical power must be shut off/unplugged, the water supply must be shut off and the drain hose must be disconnected before removal and repair. Be careful and good luck.
Feb 17, 2015 | Zanussi Dishwashers
My zanussi ZDT 6252 has rinse and hold and intensive lights flashing and is humming
Have you proper water pressure or is the water tap turned on or kinked? If so - fix it and try again.
Dec 13, 2014 | Zanussi Washing Machines
Zanussi ZDT 6244 Dishwasher , wash cycle completes , all water drains out , but the dishes are not brilliant clean & dishes are still wet
Try cleaning all the jet orifices in the rotating vanes. Use tooth brush. Check for dish plate is touching the rotating arm in the wash chamber. Rotate by hand for freeness.
Mar 29, 2010 | Zanussi 24 in. DE6544 Built-in Dishwasher
Just moved in and run the dishwasher
Replace the timer.
Most likely it was broken by someone resetting the timer by hand while the unit was energized.
Always open the door(de-energizes the timer) when you want to make an adjustment to the machine while it's running.
Jun 21, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Blows fuze and has burnt electrical smell
Time for a new dishwasher. Had the same problem. Tech came out and threw hundreds at it cause it was under warranty at the time, i didnt pay a dime and ended up buying new one.
Jun 04, 2009 | Fisher Dishwashers
Changing heating element.
You normally access the element from the side , Be careful of sharp edges . meter it before you start spending money it could be a timer fault also !
Maurice
Feb 15, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Humming noise
humming is the motor powered up but not turning. burning smell is the motor overheating. cause may be the motor capacitor which is a cheap part. try replecing it and hope thge motor survived. could also be a foreign object in the pump impellor
Mar 13, 2007 | Zanussi 24 in. DE6744 Free-Standing...
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
530 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
