Question about Clarion (NAVSIR) SIRIUS Radio Receiver
Clarion Marine Problem w Sirius CeNet Unit
I have a two year old M455 head unit with a Siius CeNet (I think CL1) attached. I used it all day Moday, Shut off the boat and disconnected the battery, now the headunit will not recognize the attached sirius box. I have tried the reset on the head unit (little button), but no luck. I have also disconnected the headunit from the sirius, the headunit from power.... no dice. Tried calling Clarion tech support, left message, no response.
  • 3 more comments
  • j_bert Apr 10, 2008
    I've disconnect the sirius unit from the radio for a day, and removed the wiring harness from the radio for a few minutes. Since the marine radio tends to hold onto the programming longer (the boat battery is shut off for a days at a time), it still won't recognize the sirius unit. Should I unplug the radio while it's on?
  • j_bert Apr 17, 2008
    still looking for an answer
    the radio/cd/aux work fine. just can't seem to 'see' the sirius box. I even unplugges all of it and left it out overnight. Came back next morning and sill the same, CD?tuner/aux all fine, no SIRI unit. when you say software, you mean the internal programming that should restore after it sits for awhile? is the software in the Sirius unit or headunit?
  • j_bert Apr 18, 2008
    I understand. The unit worked fine for a year and three days. One evening, i shut everything off (w switch), took off face plate, and turned off battery switch on the boat. Next morning, I turned battery on, then the headunit (like i have been for over a year) and the headunit would not recognize the sirius being attached. That's when I started this adventure. I have been able to run the stero fine and have used it for three days w the SIRI unit unhooked, but when I go to re-attach (sing your guidelines), no show. I'm think ing that something crrapped out in the siri unit?
  • j_bert Apr 25, 2008
    I bought another unit and will try it again ASAP (the boat is aobut 150mi away from my home). I'm hoping to give it a try thei week.
  • 3,037 Answers
Yes, unplug it while its on and try leaving both unplugged for an hour or so and connect them while unplugged and see if they recognize each other
If this doesn't work then you may need new software which may have gotten corrupted somehow, just reload it on and see if that fixes it
Please update me on this and I will help you further if the above doesn't work
Thank you for using Fixya and Good luck
Posted on Apr 17, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Apr 17, 2008
    the Siri software most likely would be the culprit
  • Benjamin Patri
    Benjamin Patri Apr 18, 2008
    You could try buying a different one and seeing if that one works on your boat, and then return it.
    By doing this you can determine exactly which device is having the problem.
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
  • Benjamin Patri
    Benjamin Patri Apr 26, 2008
    sounds good, let us know how it goes
  • Clarion Master
  • 19,396 Answers
When a CD changer or Sirius satellite receiver is added to a system, the source unit’s main wiring harness must be disconnected before the changer and/or satellite receiver’s CeNET cable is connected to the source unit. Otherwise, the source unit will not “recognize” that a CD changer or Sirius satellite receiver has been added.
Posted on Apr 09, 2008
One of my customers has a CMD6 with SIR-CL3 Sirius receiver. When powered up the unit displays "SIRIUS NO TUNER" and then shuts off, powers itself up again, repeats display message then shuts...
I am having the exact same problem with my CMD6. The sirius worked fine with my CMD4, but has the same problem with constantly rebooting when I hook it up to the CMD6. Did you find a solution?
Feb 08, 2011 | Clarion CMD6
My sirius reciever in my boat worked fine until this year now it wont work antenna is only two years old and it is a high quality marine antenna could it be the reciever it is hooked to a clarion radio...
Oxidation from humidity could have tarnished a connector somewhere. Make sure all connectors are clean and shiny first. It could be that the receiver is bad. A stereo shop should be able to check that for you easily.
Mar 13, 2010 | Clarion (NAVSIR) SIRIUS Radio Receiver
Constantly goes to "linking" whenever I select Sirius. Sirius tells me that means an antenna problem. However, I have tried a new antenna with the same results.
The unit needs to be replaced. solder pins on the PC board of the unit are broken. Clarion has about 100,000 of these units with the same problem. You can find a replacement online for $50 that's been fixed & the problem should not re-occur. Sorry for the bad news. Hope this helps
Jun 02, 2009 | Clarion SIR-CL1 SIRIUS Radio Receiver
No Sirius function available.
I have the same problem. When scrolling through the source options, the display goes from tuner-cd-aux and back to tuner...no sat. radio. need help.
May 29, 2009 | Clarion XMD3
MY CLARION DXZ545MP W/CL1 HAS STOPPED TUNING MOST CHANNELS
I have a similar situation ..... And am looking into categories ... will let you know
Jan 29, 2009 | Clarion SIR-CL1 SIRIUS Radio Receiver
Installation question ??
With the CNET you do mthis, CD Changer to the sirius input, srius output to the Clarion input. It's just a "daisy chain". I hope I understood you right, if not, you can yell at me :-).
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | Clarion SIR-CL1 SIRIUS Radio Receiver
Sirius Starmate Power
My Sirius ST1 receiver froze. It reads "Sirius Radio" with the logs but goes no further in booting up. Any solutions?
Nov 12, 2008 | Clarion SIR-CL1 SIRIUS Radio Receiver
Clarion Marine XMD3 / SIR-CL1 Sirius Troubleshooting
I had the same problem with invalid channel on all channels ! Had to reset the siriuss receiver by removing power for 15 sec and restoring! that means not just shuting it off but removing all power to the sirius unit not the clarion unit itself and reastablishing power to it turning on the clarion head unit and walah! satelite would recieve ESN and 184 and programing! Hope it works for you after 3 long waiting periods on the phone!
Oct 21, 2007 | Clarion SIR-CL1 SIRIUS Radio Receiver
SIR-CL1 WIRING DIAGRAM
Here's the manual http://www.sirius.com/pdf/manuals/SIR-CL1_user%20manual.pdf Hope this helps.
Sep 15, 2007 | Clarion SIR-CL1 SIRIUS Radio Receiver
Clarion (NAVSIR) SIRIUS Radio Receiver Logo
190 people viewed this question
Top Clarion Audio Players & Recorders Experts
John
John
xxxxxx xxx
Graham Lovell
Graham Lovell
Level 1 Expert
Are you a Clarion Audio Player and Recorder Expert? Answer questions, earn points and help others
