Question about Amana ABB1927DE Bottom Freezer Refrigerator
When the door to the freezer is closed there is a vibration noise from the icemaker. When the door is opened, it is quiet. Also, the ice is not forming solid Thanks
  • Amana Master
  • 909 Answers
Possibly there is a 2 part problem you are experiencing. 1)That vibration i dont think is the ice maker. It is your evaporator motor. 2)The fact that the icemaker is not forming the blocks nicely could be because the freezer setting could be set a little to low. The freezer temp. is what freezes the ice maker blocks. You may want to play it safe and do a 12 hour defrost which may be the reason why the vibration is heard.and reduced freezer temp.
Posted on Jun 05, 2010
I have a maytag msd2656kes. A noise has developed in the ice maker that stops whenever you open the freezer door. There is a momentary switch that I push on the left inside wall of the freezer that...
Looking at your wiring diagram, the icemaker is wired through the light switch. So when you open the door it stops power to the icemaker and the noise stops,push the light switch and it starts back up again.
A lot of times the motor, or module will go bad in the icemaker causing somewhat of a grinding noise like it is trying to do something but cant. 99% of the time it is best to change the whole icemaker to avoid further issues but sometimes you can just change the module depending on the condition of the rest of the icemaker.
Feb 08, 2018 | True GDM-12 Refrigerator Commercial
The ice cube maker makes ice ok but the ice crusher is not crushing properly. The grinder area(teeth) seems to keep geting frozen (clogged) with ice.
The most common problem with this is the door/flapper is not closing snuggly. Usually a piece of ice holds it open but if this is happening all the time make sure the little ice door/flapper is closing all the way open the door and push it open and see how it is closing. If there is not water freezing on the left side of the freezer under the icemaker its self you have to have air getting into the freezer and usually its the ice door. good luck
Aug 15, 2010 | Whirlpool GS6NBEXR Side by Side...
Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
Sep 25, 2009 | Maytag MFD2560HES Bottom Freezer French...
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Kenmore Elite Trio makes creaking/groaning sounds
Jan 30, 2009 | Jenn-Air JFC2089HE French Door...
Strange Noise - Creaking
I had the same problem. My fridge would make a creaking sound as soon as the freezer was closed. I took 10 minutes to trouble shoot the problem and pinpointed that it was coming from the icemaker. After wondering if I was going to have to replace it, I noticed a piece of ice wedged in a way so that the ice maker arms could not fall into the basin to make ice. The sound was the motor creaking because of the jam. Removed the ice and the sound went away. Now, I'm sure the motor will **** out in a few months since it has been jammed for 2 weeks burning up the motor. Oh well. Hope this helps.
May 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
sounds like your icemaker is jammed.
first ofall just feel around the icemaker and see if you can find a peice of ice jamming it that you can remove. if that doesnt work heat it up with a blow dryer until any ice that is there will melt away and it will free up..
there is one other possibility: the stripper could be jammed against the side of the icemaker in which case you'll have to remove the icemaker from the refrig and unjam it..
hope that helps and good luck
Dec 15, 2007 | Jenn-Air JBL2086HES Bottom Freezer...
I was able to solve this problem by doing the following:
1) Carefully (because there may be sharp metal blades in this area) reached into the upper left compartment of the icemaker and pressed down on ice cubes that seemed to be lodged there and were protruding slightly above the slots they should have been passing through.
2) Press down on the cubes, forcing them through the slots and into the cube container below
3) Lift the metal arm, remove and completely empty the ice cube container
4) Return the ice cube container to the freezer, making sure it is seated properly
Close the freezer and wait until the ice cube maker begins to make new ice cubes. The sound should stop in around 10-15minutes.
Nov 06, 2007 | Jenn-Air JCD2389G Side by Side...
The motor for the auger drive runs pretty slow (about 18 rpm), it could be the drive is running continuously (unless the door is open). Check that and let me know some more info, is the noise real loud, soft, etc. Can you feel anything vibrating or running when the door switch is pressed in?
Nov 05, 2006 | Amana ASD 2624 Side by Side Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
106 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
