Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Why does my 42 inched deck craftsman tractor cut uneven?
  • 2,841 Answers
It needs to be leveled. Level it from side to side and front to back, then drop the front 1/4" lower than the rear. The hangers holding the deck in place are adjustable.
Posted on Jun 05, 2010
    New Friend:
  • 4 Answers
Before trying to level a mower deck that was previously cutting even and now is cutting uneven you may want to check the spindles on the deck for worn bearings. If you haven't hit anything like a tree stump or a partially embedded rock in the yard, most likely the spindle bearing with house the shaft for the blades have worn and one of them is causing the blade to wobble a bit resulting in an uneven cut. Just found this to be the case in my Craftsman LT1000 Lawn tractor. Take a look before you begin adjusting the leveling rods, you may be surprised.
Posted on Feb 17, 2015
    Sergeant:
  • Craftsman Expert
  • 374 Answers
Level left to right then level front to back with owners manual instructions.
Posted on Sep 09, 2014
  • 518 Answers
If deck is level, make sure top of deck is not plugged with grass or sticks. It needs to be clear of debris to make sure it has proper airflow. Next check condition of blades.Make sure they spin freely,by reaching under deck & spinning them by hand. Of course with unit turned off,not running. Are thet knicked,chipped,missing metal,worn or warped? If yes to any of the above. Needs new blades.
Posted on Jun 15, 2010
2 Suggested Answers
SOURCE: My Craftsman 42" lawn tractor
I would suggest checking your owner's manual. There is a leveling process and my Craftsman wasn't leveled at the factory. Once I leveled mine, it cut fine. If you can't find it in your manual, google leveling craftsman mower deck.
Posted on May 14, 2011
May 14, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
42 inch mower cuts uneven, what is the problem?
Several things here could be the problem. Check to see if mower deck is level, measure distance on both side on a level surface. Check tire's for low air. If you've replace the mandrel's lately, some have a left & right side & if not put back together properly this will cause uneven cutting
Aug 03, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Sep 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
One blade on deck gives an uneven cut
Sounds like a bent shaft, or the mounting is not flush.
Jul 04, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Cuts lawn uneven, one side shorter than other
Was it cutting uneven before you changed blades? If so, you may not have gotten the blade on the shaft correctly. There is an adjustment in the center of the deck hanger on each side. You can turn the 9/16 nut up or down on each side to level it out.
May 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
May 25, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
708 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
