Question about RCA D52W23 52" HDTV CRT TV
WHY DOES'NT MY RCA MENU HAVE CONVERGENCE PROGRAM R56WH78 TURNED IT OFF FOR 10 HOURS TO REBOOT STILL NOT THERE
  • RCA Master
  • 5,138 Answers
Blowed fuse on the deflection board FL231.06 amps it will be located on the right hand side of the FBT flyback Transfomer
there will be 3 of them in a roll small brown or gray rectangler looking caps but they are fuses it will be the one in the middle
Partstore.com has them. Deflection board is locted on left hand side of bottom chassis.
Posted on Jul 01, 2010
  • RCA Master
  • 8,617 Answers
Very common problem. You can get the repair kit called ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com the kit contains the parts and the CD with instructions.
Posted on Jun 05, 2010
The picture on my RCA R56WH78 is blurried
thats the ITC222A chassis which is famous for deflection board issues which cause misaligned colors. You can get free assistance to figure it out by responding to this same post and leeting me know if you still have the auto convergence option still listed under the setup menu or has it disappeared from the setup menu options.
Mar 18, 2013 | Televison & Video
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Oct 19, 2009 | RCA R56WH76 Projection Television
3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
May 26, 2009 | RCA R56WH76 Projection Television
Convergence problems with rca r56wh78 how can i fix it?
go to the following link and leave them a email with your model and symptoms and they will assist you with the proper component that will need to be replaced to correct the issue and they help with free instructions when you order the components.
http://servicemanuals.vstore.ca/
Apr 25, 2009 | RCA P52926 52" Rear Projection Television
RCA HD R56WH78 projection TV, picture just got ascew,
You are haveing form the sounds of it convergence problems. I see this all the time on this set at the shop. FIrst question in customer menu under setup do you have the convergence option if not consult the tips and tricks section under fl231 problem. if you do have this you may have other troubles the convergence is controled by three seprate boards.
Nov 08, 2008 | RCA HD52W56 52" Rear Projection HDTV
R56WH78 convergence problem
Get a new TV , i have had problems every year and now its off warranty, I will never buy an RCA again as long as I live,
May 13, 2008 | RCA R56WH76 Projection Television
Warped 3D vision on the screen
convergence is out? convergence is not available in setup menu? this points to eather convergence power supply out or you might wont to look at fl231 fuse.
Mar 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence on a r56wh78 rca projection tv
I located the problem with this set and wanted to pass it on to help anyone with this problem. the chassis # is ITC222A and the problem turned out to be a fuse on the High voltage board. There are 3 fuses that sit next to the flyback transformer and the middle fuse (400 ma 125v) was blown.
Mar 21, 2008 | Televison & Video
RCA D52W23 52" HDTV CRT TV Logo
480 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
