Question about Acer eMachines 520-2890 Notebook
After only three months, the touchpad on my E627 no longer works. I have to use a conventional mouse. What can I do? Take it back?
  • wap tek
    wap tek Jun 05, 2010
    as the puter starts up press the bios setup key
    its  Tab on many  eMachines. but if that fails try  one of thease
    Delete   Esc   F1 - F10   Insert
    look in the bios setup for mouse options
    please post what operating system it is, 98 9x xp vista etc
  • wap tek
    if its xp
    right click the start menu and select explore all
    navigate to "my computer"
    right click and select properties , hardware,  device manager, and then
    mise and other pointing devices,
    see if 2 are listed and if one has an X or check mark over it
  • 192 Answers
Touchpads are notorious for going out. Many people put too much pressure on them and they get stuck in a down position or think of two pieces of paper glued together. Most of the time you can tell because the mouse cursor (arrow) will move on the screen by itself either top to bottom or left to right. You try and put it on something and it is shaky and wont stay. If you are getting no response at all from it you should try reinstalling the driver from ACER support or Synaptics.com (they make the touchpads) You can try the following and then yes if under warranty take it back. Taking your finger and with medium pressure go around the outside of the track pad surface and then work way to center. Dont use any type of cleaner but see if any crumbs or debris has gotten lodged along the edges where the pad meets teh laptop case. Good Luck
Posted on Jun 05, 2010
Why did my touchpad mouse disable?
Either the hardware itself has failed or perhaps the driver has become corrupted. Go into the device manager, locate the trackpad driver and delete it. Exit the device manager and reboot. The device driver should be reloaded (trackpad seen as a new device), you may need your Windows CD but then again sometimes you don't.
Aug 16, 2014 | Acer Emachines E525 E625 E627 E630 E725...
Touchpad scroll
JUST TRY SOME DIFFERENT MOUSE, IF IT IS WORK YOU NEED CHANGE TOUCHPAD IF NOT SOMETHING WRONG WITH MOTHERBOARD
Jul 03, 2014 | Acer Emachines E525 E625 E627 E630 E725...
My aspire D255E netbook is only about 2 months old, the mouse pointer moves, but i am not able to select anything using the touchpad or the touchpad buttons. I was wondering if there was a solution for...
Check if the drivers for the touchpad is installed. Usually you can find an icon at the system tray for your touchpad. Check device manager if there is a problem under mouse and other pointing devices. You can also try double clicking the device under that category and try to roll back the driver if possible. If it still does not work, try running a hardware diagnostics on the touchpad. It could be a hardware problem.
May 12, 2011 | Computers & Internet
Touchpad is off on eMachines E627
Check out the button on the left of the power button that disable it. If the
light is on the mouse pad is locked.
Hope this helps!
CreativeTECH
Nov 19, 2010 | Gateway Computers & Internet
The TouchPad on my three month old E627 (Vista Home Premium platform) has stopped working. I've tried 'cleaning it' - using pressure on the pad to release any debris and re-installed the driver. Is it...
Try using the function keys to enable the mouse. I'm unsure which of the 'F' keys it is, but if you can locate the picture, then hold down the Fn key + the appropriate 'F' key and hope that the mouse starts to work. Also you can try loading into the BIOS, hitting F9 to reload refaults, and then F10 to save and exit. Failing these both, best option would be to go back to retailer. Good luck
Jun 09, 2010 | eMachines eMD620-5133 Notebook
I have an e machine E627 and my mous pad seems to be locked the mouse won't move what should I do
Hi there please follow these key. Press FN+ F7. these key use for mouse pad enable / disable purpose. F7 key should marked a mouse pad symbol. Otherwise please watch those symbol in below the image & press that key with FN.
9c654de.jpg Thanks & waiting for your feedback.
Feb 09, 2010 | Acer eMachines 520-2890 Notebook
Mouse has stopped working.
there is a Touchpad toggle button with power button it Turns the internal touchpad on and off.
Feb 04, 2010 | Acer Aspire One PC Notebook
Touchpad no longer working
go to control panel and click on devices. click mice and see if it has been disabled.
Feb 28, 2009 | Dell Precision M60 Notebook
Touchpad
You could clean it.
Personally I plug a USB Mouse, Cos I cannot be Bothered with a lot of wasted energy in using a touchpad. Far faster with a mouse. The other answer is Statutery rights.
Feb 10, 2009 | Compaq Presario C700T Notebook
Touch pad center click button no longer works
Near your clock, you'll usually find an icon for your touch pad (probably synaptics). Open this & select mouse properties, in there look under Device Settings & try the "Reset Devices" icon.
If that don't work, Click start>control panel (classic view)>mouse.
On the Touchpad tab, make sure the 'tapping' box is checked . Click apply, click ok.
If that doesn't work, click start>run, type devmgmt.msc
and click ok.
Click the plus to expand Mice and Other Pointing Devices.
Right click and uninstall any mouse or touchpad listed.
Reboot.
Let Windows rediscover and reinstall the touchpad drivers.
Good Luck!
Jan 09, 2008 | Acer Aspire 3680 Laptop
Acer eMachines 520-2890 Notebook Logo
441 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
