Question about Kodak EasyShare DX7590 Digital Camera
Pop up flash does not pop up how to fix it Kodak DX-7590
5 Suggested Answers
  • 9 Answers
SOURCE: Flash does not open when I slide the "open flash" switch.
Try gently lifting the flash with the flash latch held open. It may have grit stopping it or a broken spring. Also make sure the latch is pulling right across to the right.
Posted on Mar 30, 2009
leepania
  • 1099 Answers
SOURCE: Camera will not read memory card
Your camera is only supporting SD/MMC Cards (up to 2 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Posted on Jan 06, 2010
  • 11967 Answers
SOURCE: Zoom won't work on my DX 7590
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 19, 2010
sonicboomele
  • 1557 Answers
SOURCE: kodak dx 7590 camera will not format a memory card?
as a short cut try putting the sd card into your sd slot and format it with your computer
Posted on May 15, 2010
I just got a kodak easyshear dx7500 how do I turn it on??? thanx
To my knowledge there is no Kodak DX 7500. So you are referring to a DX 5700 or a DX 7590. for both, start charging the battery. Then after you put in the battery, press the on / off button for a second the camera should switch on. But considering the age of the camera, it could be the battery does not work. I wonder if it is worth buying a battery for an almost 10 year old camera. So if it does not work, don't try to buy a battery, it could be more expensive then a brand new camera, delivering better results than the camera you now have.
Nov 09, 2014 | Cameras
Flash will not pop up
Alot problems with this...
The pop up flash only pops up half the way. We had a large dinner party the other night and tried to take pics only to find the flash would not go off. Later, I manually lifted the flash all the way open and took pic and flash did go off. Battery fully charged. In auto mode. Camera only 2-3 years old! Really upset. Went to the web to see if others have same problem AND THEY DO!!! Several have the half pop flash and resolve it by holding the flash up manually. So thought this was a global problem and Chatted with Kodak Customer Service (puleeese). They said, sorry, but $150 to fix or 25% off upgrade camera.
Think it before take some choice.
May 19, 2011 | Kodak EasyShare DX7590 Digital Camera
Kodak dx 7590 camera will not format a memory card?
May 15, 2010 | Kodak EasyShare DX7590 Digital Camera
Jan 01, 2010 | Kodak EasyShare DX7590 Digital Camera
Flash dead on Kodak Z710.
It is very hard to order the parts for yourself. If you ask kodak they usually tell you to send it in.
They do sell some replacement parts at this site:
Available Replacement Parts For Your KODAK Digital Camera and ...Find replacement parts for your Kodak digital cameras and printer docks. ... Z1285, Z1275, Z1085 IS, Z1012 IS, Z980, Z812 IS, Z760, Z740, Z730, Z710/ZD710 ...
www.kodak.com/global/en/service/products/replacementParts.jhtml - 40k -
You can also check on ebay!
Apr 23, 2009 | Kodak EasyShare Z710 Digital Camera
Kodak 7590 New SD card will not format
Is this an older camera? If so it will not support sdhc cards. Sdhc is a 4+ gig card. You will need to buy a card 2 gig or under.
Jan 29, 2009 | Kodak EasyShare DX7590 Digital Camera
Dec 02, 2008 | Kodak EasyShare DX7590 Digital Camera
Kodak DX 6490 Flash
Hello, When taking photos in low light or night time,turn the rotary dial that you use to turn on the camera all the way to the right as far as it will turn.the symbol looks like torso of person with a star above it. this is the night setting,exposure time is increased so you may have to rest camera on solid object to prevent blur.This should do the trick.
Best Regards,Russell
Oct 11, 2007 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare DX7590 Digital Camera Logo
154 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
