Question about Apple iPhone 3G
Pin number for blue tooth AT - Apple iPhone 3G
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Feb 21, 2011 | Plantronics Explorer 230 Bluetooth Headset
Hi I have a motorola blue tooth and i got a new phone and the blue tooth won't work with it as i don't have the manual to give it a pin number do you think you can help Thanks
There are two common ones 0000 or 1234 for the number. If this does not work, please let me know what model of blue tooth, and I can help you find it.
Thanks
Mar 04, 2010 | Computers & Internet
How to pair and connect the lg|vx8350 cell phone to the gbh703d bluetooth
you need to long press your blue tooth and from your phone you need to search then you can find the blue tooth device and you need to connect sometimes it will ask for pin number you need to enter 0000 then the device will paired with your phone
Feb 25, 2010 | Cell Phones
Pairing to nokia 6700
both party A and B blue tooth should be on
from nokia 6700. go to settings , connectivity , blue tooth open . turn on blue tooth . and scan .. click on the party B ( buddy phone ) confirm the name from the other person whom u want to pair and then sent a req ( it ll be asking for pin. use any pin of your choice i.e 123 and the party B ll be prompt for a pairing n enter pin. he must enter the same pin u have put in on your phone before sending a req, it ll be done
Feb 21, 2010 | Nokia 6300 Cellular Phone
I can't find the pin number for the Latte Mocha blue tooth to par it with the new phone.
try 0000 or 1234. either of these codes should work.
Regards,
Mike
May 09, 2009 | Cell Phones
BLUE TOOTH H 500 NOT GETTING CONNECTED, CEL IS ASKING PIN CODE
thanks
a friend of mine told me the pin code of h 500 blue tooth
which had solved my problem yesterday
any way thanks
ather m.khan
Apr 10, 2009 | Motorola Cell Phones
Lg bluetooth pin number
try 0000. it worked for my LG bluetooth
Aug 10, 2008 | LG KU990 Viewty
Apple iPhone 3G Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
