Just need to find out if a remopte will work with this type of television as it has remote control written on the front where the power switch is
  • book812009 Jun 05, 2010
    ok thank you i will have to chase one for it
    Brigadier General:
  • 7,191 Answers
Please let us know the brand and model number of the television.
From the description of the television, it should work with the remote control provided with it.
Thanks for using FixYa.
Posted on Jun 05, 2010
  • 1 more comment
    there was not a remote with it i brought a universal remote and used there numbers and there auto search it still wont work
    it is a TC-1401ar
  • AliTech110
    AliTech110 Jun 05, 2010
    Many thanks for the feedback.
    Universal remotes are not compatible with all television brands and models. You should purchase the remote control which is compatible with your television. Also, if an original replacement remote is available for your television, you should purchase it so that you can access all the functions on the television.
    Thanks once again.
Samsung picyure goes off after 10- or so min,volume stays on,is this a powerboard issue or as code needed,i have nop remopte witjh this tv but will use SHAW remote,please help,
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 18, 2015 | Samsung Televison & Video
Remote starter not working
Check to make sure the remote start kill switch isn't broken. There should be a switch under your driver seat or gas pedal that turns your engine off if someone tries to drive off with your car while you're warming it up. If that switch is damaged, it can trick your remote start system into thinking there's someone in your car, and preventing the system from starting up at all.
Dec 12, 2013 | Viper 5301 4202V Remote Start System and...
Gva tv code
0173,0198,0175,0199 are the codes to check. If you wish to get more, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 05, 2013 | Televison & Video
Tv power (redlight will come on powering the TV then back off
If the model here listed is correct it may be the actual power switch--it like all the front controls is a tiny micro switch--only supposed to work when pressed but can and does fail in this way--
How to prove/disprove this?
Someone needs to remove the front keyboard and unsolder that 2 pin switch---remote will with the board back still turn set on.
If it works that way either just use the remote or search for the keyboard and replace if can find one.
Only other issue possible is the microprocessor in the set could be bad and we do not want that-----both the front buttons on set and the remote go to the same place inside the set but the keyboard has priority over the remote.
If power button bad, button on the remote will not stop or correct this.
SD TECH
Apr 22, 2012 | Hitachi 53SWX10B 53" Rear Projection...
What is the tv remopte code for sylvania remote
hi! i have here a couple of codes for your tv! just try them 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!
Feb 08, 2010 | One For All URC-5705 Remote Control
Hello, my remote is two wears old, model 98TR7SW-ENT-VSF, few buttons are heavy to response. Any suggestions? I can open it by myself if necessary, thanks, Neno
well open it up and see that all the buttons that were hard to respond have the black gummy worn down get a remote that does not work and cut those black circles and glue them to your remote and close it will work done it to my cars remopte key
Oct 28, 2009 | Televison & Video
I do not have a remopte and need to turn off the
WITHOUT an original working remote I do not think you can do this----part number for this remote is:
RRMCG1324CESA
I looked on the internet and found a few places selling this remote for about 28 dollars ----Google the part number ---it retails from sharp for about 39 dollars---almost any sharp remote made around that time should work and do what you need----I went thru the same thing here with a larger set---could not get into menu-----got my hands on a remote for a different model and it worked perfect.
Let me know if you need more help---I am here to help people.
SD TECH
Oct 10, 2009 | Sharp 19L-M100 TV
Where is the eye for the remote on the TV????
Hi, remote sensor is located behind the front screen, if the remote doesn`t work as well (you didn`t say so I`m assuming it doesn`t) then you either have bad tact switches on the control board (the buttons on the front of the set) or the 5 volt line to the control board is missing, video-tek
Feb 03, 2009 | RCA P52937 52" Rear Projection Television
Our Cinema series 32" TV is stuck on ZOOM and I can't get it back to regular. There is a ZOOM button but it doesn't seem to do anything. Ted Thank you
unplug tv for five minutes then return plug....now press and hold the tv power button for ten seconds(This should reset it!)
Dec 22, 2008 | Televison & Video
Code for Verizon FIOS remote Control
Code 1292 worked like a charm for me!
Vizio SV421XVT
Dec 11, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
