Question about RCA HD52W59 HDTV Projection Television
Loss color I've loss blueon my tv
    Sergeant:
    Champion:
  • 301 Answers
I suggest to check connections. if you are using component cables and one of the cables has been disconnected then it could pose this problem
Posted on Apr 10, 2008
No picture but there is sound i can turn it on but no picture
el televisor lo prende y se oye, pero no se ve. hay veces que lo prendo y se ve.
Jul 22, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Why does my dvd player have two pictures with PSCAN displayed across the screen?
The progressive scan it´s for high definition Tv´s and if you´ve got standard tv need to disable that function
Jul 16, 2010 | Memorex MVD2022 DVD Player
Poor picture no color
OUCH! LARGE DARK SPOT IN CENTER IS NOT GOOD FOR PROJECTION TV. YOU BURNT THE TUBES. THE LOSS OF COLOR IS THE ROOT CAUSE SOUNDS LIKE A DEFLECTION CIRCUIT PROBLEM. THE TIMING FEEDBACK IS USED TO SYNC THE COLOR CIRCUIT. IF THE TUBES LIGHT WITHOUT DEFLECTION THEY BURN THE CENTER PHOSPHOR COATING INSIDE.
Dec 24, 2009 | Televison & Video
Screen keeps losing colour and ends up with a blue tint
On this model there tend to be two problems. One is that the power supply capacitors fail early and often. While this typically caused no power or slow power-on, it can cause other issues as well.
Loss of color typically means the 'Main Scaler board', which is the main board where all the inputs are attached, is having an issue.
There are some problems reported with a faulty crystal on the board causing loss of color, although most techs would just swap the board as these TVs are meant to be serviced at the board level, not the component level.
I assume that this loss of color happens on any input source, including when using the internal setup menu of the TV? This would help to confirm that the loss of color is not related to a faulty input signal caused by a bad cable.
Oct 16, 2009 | Philips 32PFL7332D 32 in. LCD HDTV
DVD player only plays in black and white on Soniq 42'' Plasma TV. (Have tried 3 different players all have the same problem)
The color loss is most likely due to a NTSC/PAL compatibility issue. If you bought the players overseas in a PAL region (http://upload.wikimedia.org/wikipedia/commons/0/0d/PAL-NTSC-SECAM.svg) and the TV is NTSC or vice-versa, there will be a color loss. Thiss because the different regions have different formats and when you go from one to the other, the color does no transfer over. You can buy a PAL to NTSC or NTSC to PAL converter to fix this issue.
Oct 06, 2009 | Televison & Video
I have a older tv so i pluged it in with the
plz ask complete qstion bcoz i cant understand ur qstion.........as u know that three cords . 1 for +ve & 2nd for -ve & one is for neutral.......try combination of different wires............& ur tv will work normally
Mar 08, 2009 | Sony Playstation 3 (PS3) Console
TV COLOR WENT BROWN IN COLOR
It could not be the playstation that would cause the fault. The set was probably going to fail anyways.
A brown casted picture sounds like there is a loss of the blue colour drive in the set.
Some TV sets have colour temperature adjustments in the user menu. Check to see if your TV has that option, and that the colour temperature is properly set up. You can refer to the TV's instruction booklet for details.
A loss of blue drive can be from failed components in the video path, or in the bias circuits that control the CRT's cathold current.
It is also possible that the CRT is going defective, and is losing emission from the blue colour electron-gun.
You will have to bring the set to a service center that has an experienced TV tech who can make proper diagnostics, and give you an estimate for the cost of repair.
Jerry G.
Apr 29, 2008 | Philips 55PP9352 55" Projection Television
Picture black and white , no color
try resetting the tv back to factory settings under within the tv's menu setting you should find a setting to reset the tv, most likely all the color and contract settings may have been tunred down,
Sep 08, 2007 | Sony KP-61V90 61" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
