Question about Dell 0Y3740 Keyboard
I have a dell xps m1730 a several of the keys on the number pad will not work. 7,4,1,8,5,2,/,*. I think it is software related because the problem started after I reloaded my OS. I called dell and they did some diagnostics and determined that I needed a new keyboard. While I waited for the new keyboard, the problem went away. The technician replaced the keyboard anyway, and now I have the same problem again.(also replaced the mother board)
  • 4 more comments
  • butchwilder Jun 05, 2010
    I tried the recomended repairs. they did not work.
    I reloaded drivers and it did not change problem
    LANGUAGE SETTINGS ARE CORRECT
    Did all 61 updates. problem still there
    VISTA
    drivers are current
  • Dell Master
  • 6,487 Answers
Yes this can be a software related problem , so what you can do here is to download the input device driver including the one for your keyboard since you reload your operating system so all driver needs to be loaded also to the computer to make sure everything will be working. You can download all software from this link.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=XPS_M1710&os=WW1&osl=en&catid=&impid
Posted on Jun 07, 2010
    Guru:
  • 731 Answers
Uninstall and re-install the keyboard drivers via device manager.
1. Click Start --->Run
2. In the run window; type "devmgmt.msc" click OK.
3. Look for Keyboard, Click on the (+) sign next to "keyboard"
3. Right click on "Standard 101/102 Key or Microsoft Natural PS2 Keyboard" and click uninstall.
4. Reboot the computer and try.
Reply back if the problem exists
Regards,
Riztech.
Posted on Jun 05, 2010
  • 1 more comment
    NO LUCK
  • Mohammed Rizwan
    Mohammed Rizwan Jun 05, 2010
    Could you try a Disaster recovery format
    Im not sure what that is. Do you think that it is software or hardware?
  • Dell Master
  • 3,247 Answers
At this stage the best option might be to reload the OS. I don't think Dell has released Windows 7 drivers for this laptop and nor is it tested for it. So if you have gone to Windows 7 that might be a part of the problem.
The latest Dell drivers for your laptop can be checked at
Dell XPS M1730 drivers
You may try to re-install the drivers from here.
Hope this helps.
Posted on Jun 06, 2010
  • Sam Jun 06, 2010
    Are you simply running the driver upgrade through control panel or actually deleting old driver and reloading. Windows does not replace driver files unless it is a newer version. If you do not have recovery CD/DVD for your laptop, then suggest you get one from Dell and then restore the laptop to factory default before applying the updated drivers.
    Hope this helps.
    President:
  • 1,194 Answers
Visit these two links: Link1, Link2 and there you will get all the necessary information.
Follow those steps.
Thanks for using Fixya.
Good Luck and have a nice day.
  • 4,889 Answers
Open device manager. Start->Run-> type in devmgmt.msc and hit enter.
Right click on your keyboard in the list and click update driver. See if it does the trick.
  • Dell Master
  • 4,737 Answers
Have tried the "fn" key trick? if not please let me know let me help you. I hope this is the model you are telling about. http://www.notebookcheck.net/typo3temp/pics/7b58c29b9c.jpg Awaiting.
  • 1 more comment
    no I have not
  • Lebanon Raingam
    Lebanon Raingam Jun 05, 2010
    Ok, Press and hold down "Fn" while you press the "Numlock" key and check each time you release whether the keys are functioning or not. This is sometimes the culprit and most people don't aware of this. Good luck.
    no luck
  • Dell Master
  • 3,866 Answers
This is called "sitcky keys" its where a key was pressed down for a long period of time and the OS ignores it. Now you did not say what operating system you had so there is really not a step by stpe here for you so with regard to that I hope you investigate it.
You need to disable sticky keys. Now if that is not it and it does not work then its more then the keyboard it would not be software if sticky keys was not the issue. So you would look at the motherboard as the culprit.
Del just do not know what there talking about let alone anything else. These people get there certifications from a cracker jack box.
here is the list from microsoft help on sticky keys:
I hope this helps please do click the accept button for my efforts.
  1. I have a dell xps m1730 a several of the keys on - ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Ease of Access Center.
    1. Select the options that you want to use:
    2. Turn on Mouse Keys. This option sets Mouse Keys to run when you log on to Windows. Instead of using the mouse, you can use the arrow keys on your keyboard or the numeric keypad to move the pointer.
    • Turn on Sticky Keys. This option sets Sticky Keys to run when you log on to Windows. Instead of having to press three keys at once (such as when you must press the Ctrl, Alt, and Delete keys together to log on to Windows), you can use one key by turning on Sticky Keys and adjusting the settings. This way, you can press a modifier key and have it remain active until another key is pressed.
    • Turn on Toggle Keys. This option sets Toggle Keys to run when you log on to Windows. Toggle Keys can play an alert each time you press the Caps Lock, Num Lock, or Scroll Lock keys. These alerts can help prevent the frustration of inadvertently pressing a key and not realizing it.
    • Turn on Filter Keys. This option sets Filter Keys to run when you log on to Windows. You can set Windows to ignore keystrokes that occur in rapid succession, or keystrokes that are held down for several seconds unintentionally.
    • Underline keyboard shortcuts and access keys. This option makes keyboard access in dialog boxes easier by highlighting access keys for the controls in them. For more information about keyboard shortcuts, see Keyboard shortcuts.
    • Prevent windows from being automatically arranged when moved to the edge of the screen. This option prevents windows from automatically resizing and docking along the sides of your screen when you move them there
  • Posted on Jun 05, 2010
    • Dell Master
    • 19,396 Answers
    Hi.
    If the problem was Hardware, either motherboard, the keyboard connector to motherboard or the ribbon cable. If the motherboard was replaced (ensure), then the problem must be again the keyboard. A new keyboard can easily break same connector on ribbon cable, while a motherboard giving the same trouble it is highly unlikely.
    If problem is software, it may be caused by an installed software generating the same malfunction or by a corrupted system setting.
    To start press the Num Lock function key to ensure that this is not the problem. The key will enable or disable the whole num pad. If problem is only on certain keys, then this is not the cause.
    You have two ways to test the computer and get a definitive response.
    1) Store all your data and do a complete system reinstall. The computer will be restored to factory. If the problem persists, then it can only be an hardware fault.
    2)Start the computer using a Boot CD. The system that will start will not have any interation with the system installed in your hard disk. If problem persists, then again it is your hardware.
    You will need to download and record your own boot CD:Ultimate Boot CD or MS-DOS Bootable CD images
    Booting from CD will not affect your installed system or data.
    If the problem persists, then it is hardware.
    Hardware problem on motherboard causing this it is likely a BIOS fault (firmware problem). In that case enter BIOS setting on startup and reset to factory settings from BIOS Menu. The BIOS can also be reset by removing the internal coin battery, located on the lower side of the keyboard. This would be a more efficient reset:Coin-Cell Battery.
    Any other motherboard related problem would be highly unlikely if the motherboard has been replaced.
    Other hardware problem is naturally the keyboard. Below instructions to repair keyboard.
    Keyboard
    If the problem does not persist when starting with boot CD, then you have a software problem.
    In that case performing a system restore to a date before the problem started (and after the first repair) will fix the problem. Save your data before doing system restore, program settings may be affected.
    A complete system reinstall is the other way to fix the problem.
    Regards.
    • Ginko
      Ginko Jun 05, 2010
      Keyboard drivers are built in the Windows operative system. I hope you did bother in reading my comment and attempt troubleshooting. I was not guessing . My comment has been refused already. That will pass question to other experts. Unfortunately I keep receiving an email each time you post a comment.
      Can you please read and follow the steps. The only possible outcomes are telling if the problem is hardware or software. If you just vote out without following the steps this will be a waste of time
      Thanks
      I post again:
      Hi.
      If
      To
      1)
      hardware.
      Keyboard
      In
      Regards.
      President:
    • 4,070 Answers
    Hi! It can be a software problem. Try updating your system and it can resolve the problem. Check the keyboard connector pins too if they are bent, they may cause keyboard failure too. If they are, gently straighten it up to avoid breakage. Hope thie helps and have a good one!
    • dj_relly999
      dj_relly999 Jun 05, 2010
      Good luck on this and hope to get it working.
    • 4,281 Answers
    For that first go to control panel->Regioanl and Language option.
    Then make sure in regional option tab First option is "English United states" and location is USA then go to next second tab Languages and make sure that it is also "English United states".
    Then go to last tab name "Advanced and make sure it is also "English United states" then apply and ok.
    Then check.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    • 516 Answers
    The problem might be mechanical, their must be some problem between the connection. You have to open it and check that. Please let me know.
    • VArun dev
      VArun dev Jun 05, 2010
      Control is only saying what the selected type is set as and not what its
      detected as.
      During the install procedure the keyboard type is default at UK Keyboard
      but can be set to US or US International (there's others but I can't
      remember their names). Go into KDE Control Center------->Peripherals------->Keyboards and make appropriate
      settings there.I hope this little extra info helps.
    • 857 Answers
    I will suggest you to update the drivers for the keyboard as the keyboard and the motherboard has already been replaced. To do that go to http://support.dell.com from there go to drivers and downloads and then select your product and your operating system and then from there download the drivers for keyboard also update your chip-set driver.
    This should help to fix the problem.
    Both fans stopped
    Hi
    make sure the funs are working in another machine or using a battery if it works the problem is the motherboard.
    May 05, 2014 | Dell XPS M1730 Laptop Power AC Adapter /...
    Dell xps will not boot ubcd
    The cd-rom in the M1730 might not like the type/brand of disc you are using. An alternative would be to remove the HDD from the laptop and either put it in an external enclosure or get an adapter kit and hook it into another computer all together to recover your data. You can also try to make a bootable USB drive in order to boot the computer.
    Apr 03, 2013 | Dell XPS 1330 1730 M1210
    Backspace key no working m1730
    It is most likely problem with the keypad. contact a good technician.
    Dec 01, 2012 | Dell XPS M1730 Laptop
    Number lock, how to use it
    NUMBER LOCK
    You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
    Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
    Oct 24, 2012 | Dell XPS M1730 Laptop
    Web cam very low fram rate ( regardless of light levels) xps m1730 dell. no one seems to be able to sort this. I am thinking of buying another external web cam. all the rest in the box is superb. the...
    It is a 2007 model laptop. It has a 2 megapixel camera and is expected to be outdated and would not be able to compete with today's webcams. Yes, buying an external camera is the best option for you here. Here is the link of an article in 2007 when the laptop was first released. https://www.engadget.com/2007/08/23/dell-m1730-gets-confirmed-specs-and-release-date
    Feb 20, 2018 | Dell XPS M1730 Laptop
    I don't know how to use the scroll areas to the Right and Bottom of the Touchpad on my Dell XPS M1730
    There is a software that comes preloaded with dell called Synaptics Pointing Software .See to that it is installed.From the software enable the required scrolling mode.by moving your finger up and down slightly pressed along the right most areas of the touch pad allows vertical scrolling while moving the finger horizontally at the bottom side of the touch pad allows horizontal scrolling.Also see to that the synaptics software is enabled at startup
    Sep 29, 2009 | Dell XPS M1730 Notebook
    Key pad doe not work
    This means the number lock is on - in the upper right hand corner of the keyboard is a series of 4 keys.  Far right is delete, then (from the right) insert, Prnt Scrn, and Num Lk.  Hit the Num Lk key, and the number 9 with the padlock should shut off.  Your keyboard should now work normally.
    Any more problems, let me know!
    May 26, 2009 | Dell Inspiron XPS Gaming Mouse Pad KU170
    Lost audio during edit videoStudeo 10 plus
    audio track in ulead video studio 10 plus -attribute volume is set to zero and grayed so i cant activate it.checking it. checking duplicate audio track activates audio by track but mutes again when i play the project-used to work.system dell XPS M1730
    May 21, 2009 | Ulead VideoStudio 9
    Dell 0Y3740 Keyboard Logo
    198 people viewed this question
    Alun Cox
