Question about Neff 24 in. S5443X2 Built-in Dishwasher
The program has stopped with the pump running to drain
There are no lights showing. Pump stops when power switched off. Have tried manual reset with power turned on several times but with no success
  • 909 Answers
If you have tried the required reset, and no joy, the board will have to be replaced. The micom has gone faulty.(program lost so no sequential running). Remove board and quote numbers on the board to purchase exact one. Look up the Agents and purchase directly from them as buying from the "middle man" will cost you a fair amount more. (PLEASE NOTE. Pull plug out before you attempt this repair.). Take note on the wiring, It is not difficult but must be installed in the correct positions.
Posted on Jun 05, 2010
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Code2 comes up in the manual it says the drain hose is too high
Sure, if the drain pump have worked four minutes, and the pressure switch has not been reset, then the dishwasher will shutdown all the loads, the alarm buzzer will ring for thirty seconds and the dispaly shows E2. After alarming the dishwasher pause for three minutes than drain water for 60 seconds.
Disconnect completely the dishwasher from power outlet, drain eventual water inside the dishwasher, wait 30 mins or so, then plug back machine into power socket.
If the Delonghi has still problem when you restart it, then probably the pressure switch or the acqua stop device, which start up and stop the drain pump, is probably faulty and need to be replaced.
Basically with codee2, if you get water floods in the dishwasher, is usually the pressure switch or the water inlet valve to be changed.
When no water or very scarce water comes inside the machine, then it is the pressure switch or the aqua-stop switch.
Start testing, and eventually changing the pressure switch , this is often the cause for such problem.
If this solution had been helpful, please take your time to click the accept solution button, otherwise fixya will reward the first post published, disregarding its content.
I will be grateful if you can rate the best solution
many thanks
Here is circuid diagram
Mar 17, 2008 | Kenmore 15129 Built-in Dishwasher
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
Constant beep, stops and switch to rinse program
Can be related to a fault in the program controller unit as none of the preset programs are working bbut the fault appears universal in all the programs.
The best you can do is to remove the panel and reset, check on the inlet valve and the sparying arms and pump. check for clogging in the drain or the pump which seems to set off the alarm.
Nov 12, 2011 | Dishwashers
I have a SGV43A03GB Bosch dishwasher that has run perfectly for several years and now stopped. Essentially all the lights remain on, there is water in the pan (indeed it fills after having been emptied...
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect. Also if the Inlet valve is staying OPEN and the drain pump is working as soon as the machine is switched on then it can be fault in the controller unit.
Jul 07, 2011 | Dishwashers
GE dishwasher with tactile board. Worked fine until special fingers caused issue? Now only the CANCEL and timer light-up when CANCEL pressed. Pump runs to drain for 2 minutes. Stops. NOTHING. Dont see...
This should help: PDW8000 series: press the resetbutton once. This will cancel the washing cycle and pump the water out of themachine. PDW9000 series: open the door aninch and wait for the machine to stop. Touch the reset button to cancel thewashing cycle and reboot the panel.
According to the GE Owner's Manual for the PDW9000 series only: If the"start/reset" light is flashing, close the door until the water pumpsout (this takes approximately 2 minutes) and the light stops flashing. When thelight stops flashing, the dishwasher can be reprogrammed and restarted. If the machine is unresponsive, killthe power to the machine by turning it off on the wall switch (if applicable)or turning the circuit breaker off. Leave the power off for 30 seconds,then turn the power back on. If thatdoes not work here is the repair info: Get into the service mode by pressingkeypads #8 and #4 for 3 seconds. Then reset from service mode. LINK to SCHEMATIC
Mar 28, 2011 | Dishwashers
Drain pump runs non-stop. Continues when dial is in Stop position. When disconnected for hours, drain pump starts immediately when power restored. In any wash cycle position, drain pump runs and cycle...
sounds like the flood switch has activated.
You will have to drag the dishwasher out from under the counter after turning off the power to it. Tilt to one side so that any water collected under it is expelled. This will free up the flood switch. Wait about 30 minutes and turn the power back on.
There could be a leak of some sorts from the door seal or hoses which is causing the water to collect.
Hope this solves the problem. It is unclear why none of the lights are lighting up to show a fault condition.
Nov 09, 2010 | Miele 23 in. Novotronic G841 Built-In...
Continuous draining - unable to reset - all lights on
Cut power for minutes, and see if this can stop and reset the machine.
If the machine does not reset, then you need to test the pump and valve solenoid, to ensure it is not stuck on drain position, by energizing the solenoid.
If the pump solenoid is fine, and pump opens and close, then the problem is usually the control panel, rarely can also be a contact on wiring harness to the pump.
Eneter model number here to find parts and diagrams for your appliance.
Here also parts and repair help.
Feb 26, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Bosch SGV43A03 DISHWASHER: pump drains all the time, even if reset!
Typically you could possibly have a leak in the base or sump which activates a little float switch. This in turn switches the drain pump on continuously and deactivates the programing cycle.Sort out the leak.
Feb 24, 2008 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Jan 20, 2008 | Whirlpool AWM8143 Front Load Washer
Neff 24 in. S5443X2 Built-in Dishwasher Logo
95 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
