Question about HP Pavilion TX1000Z 12.1" Touch Screen TABLET NOTEBOOK LAPTOP PC PC Notebook
Greetings,\r\n Greetings, I have an HP Pavilion Laptop. When switching it on, I can hear the computer powering up but nothing happens on the screen and this remains blank. I replaced the hardrive and the situation is still the same. Do you have any suggestions as to what could be the problem? Many thanks. JDLR
    Scholar:
  • 58 Answers
This issue appears to be due to hardware malfunction of system board of the notebook. However, to confirm the same, I would recommend you to perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
Step 2: Remove and Reseat the memory modules
Please refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
http://h10032.www1.hp.com/ctg/Manual/c00853874.pdf
Refer page no: 43 & 44
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
Further, if the issue persists even after performing the above steps, then it is clear that the issue is due to internal hardware malfunction of the notebook and it requires a detailed onsite diagnosis by a service technician. At this point, if your notebook is covered under warranty, then contact HP to get the notebook repaired under warranty.
I hope the information provided would be helpful to resolve the issue with the notebook.
Posted on Jun 05, 2010
Hi my hp pavilion laptop DV5000 on start up has black screen and one long beep then 3 shot beeps then one long beep and another 3 short beeps. The lights stay on but nothing happens. The pc has been...
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 26, 2011 | HP Pavilion M9040N Elite Desktop PC
My computer won't start. when switch on it beep once and power comes but blank screen and stay that way, nothing happens. pls help thanks
Hmmm.. are u using an LCD monitor?
Did u try to use another monitor?
Even on start up, the BiOS didn't show up?
Tell me more...
Dec 03, 2010 | HP Pavilion dv2000 Series Laptop Full...
Newer HP Pavilion dv6000 turned off while in use and wont turn on
1.Start your computer and see if your hear your fan noise,and cannot see anything on screen then there is problem with your power supply.
2.If you cannot hear your fan noise,and do not see anything on screen,then there is problem with your motherboard
3.if you hear fan noise and can see something on screen,then it is the issue with your hard disk (very less cases)
Mostly it would be the 2nd case that you will have to get your motherboard replaced
Jul 27, 2010 | HP Pavilion dv6000z Notebook
Computer is frozen
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jun 10, 2010 | HP Pavilion DV6700T Notebook
Hallo. The screen of My laptop HP pavilion dv 2000 is
on the boot sector when you switch on youe computer, please press delete or f8 repeatedly. if there is nothing showing on your screen., then you should know that the is a problem with youe laptop scree.
i advise you to go and see a computer sepcialist to check if it is your hardware that has a problem.
thank you,
wonder
Sep 18, 2009 | HP Pavilion dv2000t Notebook
One long beep, two shorter beeps - HP laptop will not start up
Hi...
I had the same problem...
The solution is only temporary and you will have to reapply it after around 5 to 6 boots cuz it'll just happen again (the beep syndrome).
Just heat up the laptop by turning it on and covering its air vents with your hands.
Then after you hear the beeps turn it off.
Turn the laptop on again and immediately turn it over upside down with the lid closed ofcoarse (simply put it on its back).Hopefully you wont hear the beeps and when you open up the laptop lcd...voila display.
Jan 22, 2009 | HP Pavilion dv6000z Notebook
My hp pavilion tx1000series won't boot even at bios
EXTREMELY common failure in the TX1000 line. Problem is the mainboard, part# 441097-001. From HP it should only be about $200 on exchange. DO NOT get this part anywhere else, as the OTHER common failure for this model is the wifi goes out.
I do about 10 of these TX's per day, no im not kidding, and i promise you HP has the most stable parts source around for this.
-Sy
Jan 18, 2009 | Eizo I-Station Networking Hub
Powers up but black screen shows
1st - Try pressing <Fn> + <BrithnessUP> keys a few times, (on HP <Fn> key is between <Ctrl> key and <Windows> key, <BrightnessUP> key is <F8> key and <BrightnessDown> key is <F7> key. If nothing happens try the 2nd one.
2nd - Plugin external monitor, (type and size doesn't matter). Turn on your laptop. If you can see desktop on the external monitor, your drivers are o.k., The problem is your laptop display, NOT the graphic chip.
Oct 21, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Laptop won't power up
HP has a known issue with this model. You might want to check there site here:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&dlc=en&lc=en&cc=ca
Jan 24, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion TX1000Z 12.1" Touch Screen TABLET NOTEBOOK LAPTOP PC PC Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
