Question about Apple iPod nano 4th Generation
Ipod nano 4th gen. 8gb SCREEN LOCKED
Ipod nano 4th gen. screen locked.
I've tried:
- resetting (centre button & menu),
- pulging into Itunes,
- remove or rename of the LOCKED file in DEVICES (file not there),
None of the above worked. Has anyone any ideas?
  • nvzook Jun 06, 2010
    Any other ideas, this didnt work...
  • 600 Answers
restore iPod
  1. Verify that you have an active Internet connection, because you may need to download new versions of the iTunes and iPod Software.
  2. Download and install the latest version of iTunes if necessary.
  3. Open iTunes. Connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
  6. Click Restore.
  7. If you are using a Mac, you will be asked to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun. When this stage is done, iTunes will present one of two messages with instructions specific to the iPod model you are restoring.
    • Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During stage two of the restore process, the iPod displays an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remain connected to the computer or iPod power adapter during this stage.
    Note: The progress bar may be difficult to see, because the backlight on the iPod display may be off.
  10. After stage two of the restore process is complete, the iTunes Setup Assistant window will appear. It will ask you to name your iPod and choose your syncing preferences, as it did when you connected your iPod for the first time.
but unfotunately all your previously synced congs will be lost,,, but its ok then, because you can use your ipod again.
Posted on Jun 05, 2010
My ipod nano 4th gen 8gb was working perfectly a minute ago, i plugged it into my laptop itunes came up and i didn't realise it was updating, i pulled out the wire, and listened to my music, then a black...
Try this to reset the iPod nano:
Hold down the Menu button on the clickwheel and the center button at the same time. Hold these
together for 6-10 seconds. This should restart the iPod nano.
For more information, check out this troubleshooting page:
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_nano.htm
If that doesn't work, you might need to restore the firmware on your iPod. There are instructions here:
http://www.online-tech-tips.com/computer-tips/restore-iphone-ipod/
Good Luck!
-Sean
Feb 21, 2011 | Apple iPod nano
White Screen Of Death
MY IPOD IS IS HAS A WHITE SCREEN
Feb 08, 2010 | Apple iPod nano
I have a 4th generation pink 8gb ipod nano the
To factory reset on my ipod classic...  slide the hold switch to hold  then slide it back  then press the center and menu button for up to 60 seconds.
Nov 10, 2009 | Apple iPod nano
My ipod nano screen is not doing anything its like its frozen its stuck on language section i cant scroll down or anything and it says its locked but its really not
you have to hold the center button and the menu button to reset it...if that doesnt work you will have to plug it into the computer and use the restore function on the iTunes
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
My ipod nano is frozen the screen does not show anything and if it does it says its locked which it isnt on hold
Start by reseting it, hold down the "Menu" button and middle button for about 7-8 seconds. This will most likely work, if it doesn't, try restoring it. Do this by first plugging your iPod into your computer and starting iTunes. Then select your iPod in the list to the left, now click the "Restore" button located under the large picture of your iPod model. Restoring will probably take a little while, maybe 10-15 minutes.
Hope this helps!
Ipod 4th gen nano is frozen on the language selection screen.
That could be one of two problems: Either the cord of the click wheel has been disconnected from its socket which will be an easy fix and you only have to pay labor, or you may just need a new click wheel which should still be cheap.
Jul 14, 2009 | Apple iPod nano MP3 Player
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 22, 2009 | Apple iPod nano
White screen and beeps
Try This next time ....
Not all, but many 5G iPod owners have had issues with the latest iPod updates, I had this problem myself a day ago & was almost ready to send it in for a replacement, some HAVE sent theirs in. Anyways, after updating the iPod the iPod no longer works!! All you get is a blank white screen (White Screen Of Death), 3 beeping tones and you hear the hard drive click. Simply resetting the iPod will do nothing, but get you another three beeps & a click. But to resolve this issue do the following, this had worked for me as well as others...
Extended Reset
1) Move the LOCK to the "ON" position.
2) Move it back to the "OFF" position.
3) Hold the "Centre" button then hold down the "MENU" button until you hear the harddrive make the "click" noise.
4) As soon as you hear the drive "click" press and hold the "Centre" button then press & hold the Play/Pause button, you should then see the Apple Logo" like normal and it should then start up like with no problem.
Apr 22, 2008 | Apple iPod nano 3rd Generation
IPod
try switching the hold key then press the menu and centre button.
peace man!! hope it works
Feb 24, 2008 | Apple iPod nano
Frozen Ipod Nano
  1. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  2. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  3. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  4. Connect it to your computer.
  5. In iTunes, select Restore to Restore the iPod firmware. This erase everything on the iPod.
Dec 04, 2007 | Apple iPod nano
Apple iPod nano 4th Generation Logo
288 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
